20 Most Recent
Jenn-Air JGR8775QDS Gas Kitchen Range Questions & Answers
Clear code
This is a frequently reported problem on some model ranges
and wall ovens equipped with an Electronic Range Control (ERC) or Electronic
Oven Control (EOC). An “error” code
display of “Sabb" or “Sab” will be displayed and the range or oven will
not function. This is called “Sabbath
Mode" and it may be costing you unnecessary charges in service call fees.
This is NOT a problem, but actually a feature provided by some manufacturers to
enable customers of certain religious faiths to honor the Sabbath. The range
will not function at all during this period and cannot be reset by unplugging
the unit or turning it off. In your owner/operator's manual there should
be a section that refers to "Sabbath Mode" under the control panel
features and operation. This "problem" is a minor operator issue
and is not a malfunction of the appliance.
This is commonly reported by customers to service companies to have
corrected, but the repair is unnecessary, and usually NOT covered under the
manufacturer’s warranty. The reason: It
is a designed feature of the appliance and considered “operator error”
in most cases. What this means is you
may be paying someone big money to push a couple of buttons and “fix” something
that could have taken you minutes to correct yourself. Sabbath Mode can inadvertently be activated
by pressing the wrong sequence of control panel buttons, kids playing with the
control panel and also after a power outage. The “problem” can be cleared, but
you will have to find the proper reference in your owner operator manual. Manufacturers provide different procedures
for activating and deactivating the mode, so instructions may differ. I hope this helps you.
7/11/2019 6:44:02 PM •
Jenn-Air...
Answered
on Jul 11, 2019
I have a Jenn-Air gas
remove burner, or take needle and clean all of the holes, maybe hit lite with hammer to knock stuff loose
12/19/2010 5:37:20 PM •
Jenn-Air...
Answered
on Dec 19, 2010
Error code F1
F1
Watchdog circuit
Replace Electronic Range Control (ERC)
10/11/2008 3:32:48 AM •
Jenn-Air...
Answered
on Oct 11, 2008
Installation
I have a jenn air gas range with a convection oven and want to convert it to propane, but can't get an instllation manual to find the part numbers or instructions.
How do I get them?
9/21/2008 7:47:20 PM •
Jenn-Air...
Answered
on Sep 21, 2008
Jenn-air JGS9900 downdraft slide in gas range - no power and electrical outlet IS working
There are several possible reasons why your Jenn-air JGS9900 gas range may not have power:
- Tripped Circuit Breaker: Check the circuit breaker for the range in your home's electrical panel to see if it has tripped. If it has, reset it.
- Loose Electrical Connection: Check the power cord connection to the range to make sure it is secure. Also, check the wiring connections behind the range to ensure they are properly connected.
- Blown Fuse: If your range has a fuse, check to see if it has blown. You may need to replace it.
- Faulty Control Board: The control board is responsible for supplying power to the range's electronic components. If the control board is faulty, it may need to be replaced.
- Faulty Igniter: If the burners are not igniting, the igniter may be faulty and need to be replaced.
If none of these solutions work, it may be best to contact a professional technician to diagnose and fix the issue.
Jenn-Air jgs8860bdp broiler doesn't ignite.
There are a few potential issues that could cause the problems you're experiencing with your Jenn-Air broiler. Here are a few things you can try:
- Make sure the gas supply to the broiler is turned on and that there are no blockages in the gas line.
- Check the gas valve to make sure it is open and functioning properly.
- Make sure the gas burners are clean and free of any debris or obstruction.
- Check the broiler burner for proper ignition. It should ignite within a few seconds of turning on the broiler. If it does not, the burner orifice may be clogged and will need to be cleaned.
- Check the gas pressure to the broiler. If the gas pressure is too low, it can cause the flames to be low or go out.
- Make sure the broiler igniter is properly seated and connected.
Converting jenn-air dual fuel to propane
To convert the appliance pressure regulator from one gasto another, do either (1), (2) or (3) below: Your unit will beequipped with one of the three appliance pressureregulator types shown below.1. Remove the cap, push down and turncounter-clockwise. Turn the cap over and reinstall(figure 10).NOTE: The gas type you are converting to must bevisible on the top of the installed appliance pressureregulator cap.2. Remove plastic dust cover from cap nut on top ofappliance pressure regulator. Remove cap nut fromappliance pressure regulator (plastic dust cover comesoff with nut). "IMPORTANT" remove plastic dust coverfrom cap nut and reinstall on opposite side of cap nut.Reinstall cap nut to appliance pressure regulator andreplace dust cover. "CAUTION" be sure marking forthe type of gas to which appliance pressure regulatorhas just been converted is visible in top of cap nutbefore replacing plastic dust cover. (See figure 11).3. Remove cap and forcibly snap out plastic plunger frombottom of cap. Turn plunger over and forcibly snapback in original location (figure 12).NOTE: Plunger MUST snap into position; the gas typeyou are converting to must be visible on lower side ofplunge
