20 Most Recent Jenn-Air JGC8430 Gas Cooktop Questions & Answers
Hi look for adjustments to the lighter and also there should be a sensor tat sees the fire , this sesor allows the main gas to turn on, but only if it feels the heat , kind of like a thermocouple , if you think about about any type problem like this: what is it not doing ? then think what could cause this >/? if you go about any repair this way there is nothing you can't fix unless you need a part !
Jenn-Air JGC8430... | Answered on Dec 06, 2011
First you need to brush out the end tip of the sparking electrode and the burner metal part facing the electrode so they can create a spark. If not any result the you should remove electrode and check if the ceramic cover is broken and the sparking goes in wrong way and you will need to replace it.
Jenn-Air JGC8430... | Answered on Sep 11, 2011
We have here the parts diagrams and parts lists and also is an online shop and you can buy all the parts you need. Just clik on the excact model.
Jenn-Air JGC8430... | Answered on Sep 07, 2011
Hi
After reading the question it seems that the issue is with the spark module however, please elaborate and post back for further assistance.
Daniel
Jenn-Air JGC8430... | Answered on Jul 02, 2011
The switch in that main burner is bad and is causing the ignition to stay on....you will also have to replace that one burner switch.
800x600
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Jenn-Air JGC8430... | Answered on May 23, 2011
Look for clogged arifice holl,or rusty burner,clea burner and holl.
Jenn-Air JGC8430... | Answered on Jan 09, 2011
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Jenn-Air JGC8430... | Answered on Aug 18, 2010
OK, the best action is to call for service, if the unit was just installed, and purchased. This unit should be covered at this time, by the manufactures warranty, or store 30 day warranty. This repair should be free. The culprit will be a faulty spark ignition switch, and module. Testing is required. Once this switch, or(module), is replaced, the unit will operate correctly.
Jenn-Air JGC8430... | Answered on Nov 04, 2009
you can get it paint but the company which u buy u can fet a new top
Jenn-Air JGC8430... | Answered on Jul 22, 2009
A gas range requires minimal electric current. "Any ole" circuit will do.
Charlie
Jenn-Air JGC8430... | Answered on May 26, 2009
I've purchased from this Co. many times.
Excellent service.
http://www.repairclinic.com/Appliance-Parts?s=t-JGC8430+-%3d%3dc272
Jenn-Air JGC8430... | Answered on Apr 04, 2009
hi im gerbee fr.phil, much better to replace the part(igniter wire) coz that part cannot be repairable dont try to repair coz more dificult problem if u repair.to replace the part dismantle the unit or remove all the screw at the top of ur cooktop.before that unplug the unit fot ur safety.buy the part from the brand u carry.tnx i hope i help u
Jenn-Air JGC8430... | Answered on Dec 02, 2008
Hello & Welcome to FixYa
Part PHS120A-3377 has been replaced by part# 74009254 which you can buy from either this link or from sears. Please get back to me if you have any other questions.
Kevin
Jenn-Air... | Answered on Apr 28, 2020
sounds like you may have a bad harness or bad infinite switch, you can test it with a multi meter.
Surface burners
are typically either a coil type, solid type or a ribbon coil as used in smooth top ranges. All of these consist of a heating wire that uses electric current to produce heat. Coil type elements can be checked for continuity by removing them from the terminal block and testing them with a multi-meter.You should also inspect the terminal ends for signs of heat damage or corrosion, and if present, you should replace the terminal block or receptacle at the same time. You will need to remove power from the range to change the terminal block. Solid elements and smooth top elements require raising or removing the main top to gain access. You will need to remove power from the range before lifting the main top. Continuity can then be checked with a multi-meter, once you have removed the wires from the element terminals.
On modern electronic control ranges,the oven temperature sensor
is the part thatregulates the oven temperature. If it is not working properly it could be the reason why the range or oven won't start. This part can be found inside the oven on the rear wall near the top. Most modern ovens will display a fault code if the oven sensor is at fault. If you think the sensor may be the issue you can check the resistance with a multi-meterbut will need to know the correctresistance of the sensor at room temperature. Remove power from the appliance before performing this test.
The infinite switch
on the control panel controls the power to each surface element. If you have no heat at an element and the element and terminal block check ok, then you may have a defective infinite switch. Disconnect power to the range and remove the console back panel. Locate the switch and check foroverheated wires or faulty terminals first.Test the switch's contacts for continuity with a multi-meter. If defective, replace the switch.
  1. If the infinite switch does not appear to be defective, then you should check for proper voltage to the switch. This is a live high voltage test and should only be performed by qualified persons.(Locate the suspect switch for testing. Label all wires and terminals before disconnecting. A close up digital photo may be helpful.
  1. On the burner control switch the terminal labeled "P" leads to the burner indicator light. The terminals labeled "H1" and "H2" lead to the burner element and the terminals labeled "L1" and "L2" (sometimes "N1" and "N2") are the power supply wires.
  1. Set yourmultimeterto ohms setting x1. Turn the burner control to the highest temperature setting. Place one probe on pin "L1" and the second probe on pin "H1". The resistance measurement should be very low, zero to twenty ohms. If the test shows high or infinite resistance, the burner switch is defective.
  1. Repeat the step above for the terminals "L2" and "H2".
  1. If the control passes that test, turn the temperature setting to about the middle of the range and repeat the previous two steps. This will test for an intermittent problem with the switch. If the test does not show continuity with very low resistance, the switch should be replaced.
  1. With the switch turned to the "Off" position, the resistance on each of the pairs of terminals tested above should now show no continuity or a reading of infinite resistance.
  1. A test for continuity between "P" and "L1" when the burner control switch is on should show continuity. The light should be on whenever the control is turned on. If your test shows continuity, but the light does not operate, it is likely the bulb has failed.
If the burner switch shows high or infinite resistance, the switch is not passing along current to the burner and so the switch should be replaced. )
Most modern ovens usean electronic control board
to control the oven functions. These models will use the control board to operate the oven safety valve on a gas range or oven, and the bake and broil elements on an electric range or oven. If there is no power to the igniter circuit, or the element circuits, then you should check the control board to verify that there is power at the appropriate output relay. These are live voltage checks and should be performed by qualified persons only. If there is no output voltage then the control should be replaced.
The oven burner igniter
commonly known as the hot surface igniter is used in modern gas oven burners to open the gas valve and to ignite the gas. As the igniter draws electric current it will heat to a high temperature and glow, as well as cause the bi-metal in the oven safety valve to warp and open the valve releasing the gas to be ignited. This sequence normally takes about a minute. Igniters come in both flat and round styles and are very fragile. If the burner does not light then you should check the igniter first. If the igniter does not glow at all, then check for power to the circuit. This is a live voltage check and should be performed by a qualified person. If power is present then the igniter may be open circuit and can be checked for continuity with a multi-meter.If the igniter is glowing, but the burner is not lighting, the igniter may be weak and still be at fault because it requires a certain amount of current draw to open the valve.This check requires the use of an amp meter and should be performed by a qualified person. If the igniter is defective then it must be replaced.
http://www.partselect.com/Repair/Range-Stove-Oven/Will-Not-Start/
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Range-Stove-Oven/18---/Oven-won-t-turn-on-
if the harness is damaged it may effect any of the others down the line as well causing the burners to act up as they are wired in series
Jenn-Air... | Answered on Mar 17, 2020
The infinite switch
Jenn-Air JGC8430 Gas Cooktop Logo
22 questions posted
Top Jenn-Air Cooktops Experts
Marvin
Marvin
Paul Carew
Michael Thomas
Michael Thomas
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
View Most Popular
Jenn-Air Cooktops
  • Jenn-Air Cooktops
Most Popular Question
one burners not
  • Cooktops
