20 Most Recent
Jenn-Air JEC9530 Electric Cooktop Questions & Answers
I took out an old cooktop which only has the
sounds like the old one is 110 volts , and the new one is 220 volts. incompatable, as the 220 ones would work, but at half power if you didnt use the red wire. might work fine. omit the red wire and wee what happens
Burner temperature is always on high heat even at low setting
not related any further then sounds as if you have 2 burner switches gone bad,and actually the front right burner is controlled by a electronic control circuit board part retails for about $160-$200 part number 12002723, and left rear switch about $30 part number 74007841 . uint needs to be uninstalled from counter and parts changed by removing the bottom panel
Jenn-Air Expressions Downdraft Gas Stovetop Model CVGX2423B - Unable to Get Nut Off Burner Base to Replace Igniters
It is possible to use WD-40 to help loosen the nuts, but it may not be enough on its own to remove them. Here are some steps you can try to remove the nuts:
- Turn off the gas supply to the stovetop and unplug the unit from the electrical outlet.
- Use a wrench that fits the nut snugly and try turning it counter-clockwise to loosen the nut.
- If the nut is stuck, try spraying a generous amount of WD-40 onto the threads of the nut and let it sit for a few minutes.
- After the WD-40 has had a chance to penetrate the threads, try turning the nut again with the wrench.
- If the nut still won't budge, try gently tapping the wrench handle with a hammer to help loosen the nut.
- If all else fails, you may need to call a professional technician to remove the nuts safely.
It's important to note that improper removal of the nuts could cause damage to the stovetop or cause a gas leak, which could be dangerous. If you are unsure about how to proceed, it's best to call a qualified technician to help you.
4/23/2023 7:31:56 AM •
Jenn-Air...
Answered
on Apr 23, 2023
