20 Most Recent Jenn-Air JS42SEDBDA Stainless Steel Side by Side Refrigerator Questions & Answers
I have a jen air JS42SEDBDA built in. It is dumping all of the water inside the freezer when it defrosts. I have checked continutity on all line heaters and made sure that the line is free and attache
Just a thought. I don't know this fridge, but where the water is coming down, there should be a small gully. In the gully is a small hole, where the water should run out, to a hot spot. If some food or alga came in the tube, cleaning it, could solve the problem. I don't think this will be in the manual.
7/15/2014 7:49:52 PM • Jenn-Air... • Answered on Jul 15, 2014
0answers
0answers
Defrost timer
Be the first to answer 2/9/2014 4:16:42 AM • Jenn-Air... • Posted on Feb 09, 2014Be the first to answer
0answers
2answers
Jenn Air JS42SEDBDA, bought in
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned warmer which makes REF. colder or vice versa.
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
NOTE: This
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
7/24/2012 7:29:30 PM • Jenn-Air... • Answered on Jul 24, 2012
Turned off and I dont know how to reset
IF YOUR REFRIGERATOP have water dispencer push at the same time the light buton and the water buton
1/6/2012 5:55:32 AM • Jenn-Air... • Answered on Jan 06, 2012
Jenn-Air Refrigerator JS42SEDBDA Model 12606032GJ
Remove the compressor cover to locate the filter.
www.appliancepartspros.com has the filter.
http://www.appliancepartspros.com/Appliance-Parts/whirlpool-refrigerator-water-filter--puri-clean--item-number-ap4343710.aspx
10/16/2011 1:13:31 PM • Jenn-Air... • Answered on Oct 16, 2011
Jenn-Aire side by side door
NOTE: This
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
If
you need more help go here:
http://www.applianceaid.com/procedures.html
MORE
TIPS AND TRICKS:
Leo Ponder
imufo2
9/7/2011 2:09:51 AM • Jenn-Air... • Answered on Sep 07, 2011
Hi, we have a Jenn-Air JS42SEDBDA built-in
Here is a tip that I wrote about refrigerators and the fan noisethat they develop sometimes...
RefrigeratorFan Noise
heatman101
5/6/2011 2:33:21 AM • Jenn-Air... • Answered on May 06, 2011
Model JS42SEDBA Jenn-Air built in
I have this exact problem as well. Have replaced so many parts I'm at the end of my rope with this. Can somone please help!? var fctb_tool=null; function dL3xtGT_mvAT(t) { fctb_tool=t; start(fctb_tool); }
1/12/2011 5:02:41 AM • Jenn-Air... • Answered on Jan 12, 2011
0answers
Original cost of my fridge from 1999
2389 model Jeff of Clayton, CA Original review: June 2, 2006 We purchased a Jenn-Air JCD2389GES side by side four years ago. We thought we were buying a quality refrigerator, with a name brand that was respectable and with the idea that you get what you pay for. We went ahead and spent $2200 on purchasing this and within a year noticed that it made noises, the refrigerator side didn't stay cold and the freezer side froze food that developed freezer burn with in a week. Just this past week the refrigerator was on the coldest setting and the food was slightly above room temperature. A hundred dollars of food had to be thrown away. ---------------------------------------------------------------- The best way to find old prices is to find reviews. The best ones are on websites that do reviews themselves as they always list the price. https://www.google.com/search?q=jenn-air+jcd2289atb+review ..
5/30/2022 4:00:51 PM • Jenn-Air... • Answered on May 30, 2022
Jenn-Air JS42SEDBDA Stainless Steel Side by Side Refrigerator Logo
21 questions posted
Top Jenn-Air Refrigerators Experts
john h
ZJ Limited
ZJ Limited
Jose Ramirez
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Jenn-Air Refrigerators
Most Popular Question
jenn air refrigerator js42sedbda model
  • Refrigerators
