20 Most Recent Franke Evolution Questions & Answers
the coffee-boiler is not heating up. check the clicksons (push the little red button in the middle of the clickson to rest). heating element can be broken too. btw: the coffee-boiler is littlest boiler.
Franke Evolution | Answered on Sep 03, 2019
you can change the battery yourself. it's located on the left side on the upper print. if you change it be sure the machine is in the 'on'-position, if not you will lose all the programming-data. the battery is an 'cr-2032' lithium battery. it is very easy to do :-)
Franke Evolution | Answered on Feb 17, 2017
the installation number in normaly the serialnumber. you can find this behind the door of the coffee-outlet or behind the door of the brewing-group.
Franke Evolution | Answered on Jan 26, 2017
on the left side of the machine you will find 2 electrical prints. on the biggest one there is a fuse 5ATT. that will be the cause of not functioning, replace it.
Franke Evolution | Answered on Mar 23, 2016
I would suspect it has been loaded with calcium from your hard water supply. Cycle it a few times with white vinegar to clean it out.
Franke Evolution | Answered on Jun 13, 2015
May be the milk pipe between the fridge and machine is kinked.
Franke Evolution | Answered on Mar 06, 2015
Is coffee coming out? If yes ,then increase the gram age of coffee.
If no then coffee valve issue not letting enough water.
Franke Evolution | Answered on Dec 12, 2014
wich nr does appear? 030, 032?
Franke Evolution | Answered on Nov 25, 2014
You mean the micro-switch of the brewing unit? he's located on the right side of the machine. he's connected with a orange and gray wire.
grtz.
Franke Evolution | Answered on Oct 16, 2014
yes. but you need a certified technician to get into the programming.
Franke Evolution | Answered on Jul 21, 2014
Check the thermal cut outs on the boiler might have tripped.
Franke Evolution | Answered on Jul 09, 2014
what do you mean?
Franke Evolution | Answered on Apr 22, 2014
Could be faulty design.
Franke Evolution | Answered on Apr 17, 2014
try ebay. password for card once entered is 1000 or 0001. install cards are only given to franke trained engineers.
Franke Evolution | Answered on Mar 04, 2014
if you lower the coffee outlet then pull forward theclear plastic cover over the product menu. there is a slot underneath where the plasic cover clips into place.
Franke Evolution | Answered on Dec 22, 2013
Coffee Makers & Espresso Machines Logo
60 questions posted
Top Franke Coffee Makers & Espresso Machines Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
jonathan Hanson
Level 1 Expert
Are you a Franke Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Franke Coffee Makers & Espresso...
  • Franke Coffee Makers & Espresso...
Most Popular Question
need coffee come out more as discs not
  • Coffee Makers & Espresso Machines
