20 Most Recent McCall 2-2045 Stainless Steel Commercial Refrigerator Questions & Answers
We have a commercial freezer and where the temp should be showing it reads LLL can anyone tell me what that means. it is a MaCall 4-4070.
thanks Lisa
McCall 2-2045... | Answered on Sep 15, 2011
Same problem here with no manual for Davina Cross Trainer. Lost the instruction pack during house move. Any kind soul who can scan and send to me or take a photo. I am just stress out looking at the nuts and bolts in the bag. Thanks
McCall... | Answered on Sep 21, 2012
Hi there!
Yes you can order a set from most locksmiths that cut keys to code.
You may be able to order a set by phone for this.
Alternatively, the manufacturer will keep replacements, but may cost slightly more.
I hope this helps you resolve this problem. If it does, Please spare a moment to rate as Fixya! Thanks.
McCall... | Answered on Jun 16, 2008
Make sure that the cooling coils are free from dust bunnies and other debris. Plastic bags are a big problem.
Refrigerators | Answered 2 days ago
It is best not to cut the fan blades if it can be avoided - best to cure the original fault if you can.
If you need to trim the blades it is very important to remove exactly the same amount from each blade to maintain the balance. The weight might seem insignificant but over time even a tiny imbalance can cause an increased noise level.
Refrigerators | Answered 3 days ago
First, I'm not a Dynacool Tech,
* I remember having one as a kid. You need to fill it with water for the circulator (pump) to work and drip water over a filter that has a fan blowing through it. The water evaporates and cools the air as it flows through (It also increases the humidity).
* here is a Honewell manual. Check out page 12. There should be enough information to get you started.
https://www.sylvane.com/media/documents/products/honeywell-cs071ae-evaporative-cooler-owner%27s-manual.pdf
* Final, Check your warranty and call for service. (though I can't seem to locate a current phone # or web site. May have gone under or bought out.)
* about upgrading to a newer model. There have been many changes to Air conditioning and heating. Many are more efficient and built with newer technology as this evaporative cooling method was used in the 1940's and popular in the 1970's. Check out your local stores and show rooms. Also check Home Depot and Lowe's for home air conditioners
Aloha, ukeboy57
McCall 2-2045 Stainless Steel Commercial Refrigerator Logo
Popular Tags
6 questions posted
Top McCall Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
Are you a McCall Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • McCall Refrigerators
Most Popular Question
lll code mccall 4 4070 refrigerator
  • Refrigerators
