20 Most Recent
Breezaire WKCE 2200 Wine Cooler Questions & Answers
I live in Rockford IL.
You are on the wrong website for this type of inquiry. This is a community based self-help website for the repair and use of manufactured products made for consumer use..
Unit freezing up when running
The most common causes of evaporator freezing are:
dirty or obstruccted evaporator coil,
evaporator fan not working or working too slow.
and the most frecuent is LOW on R-22 Refrigerant. Check lines, look for wet looking spots and greasy/oily stuff on the lines.
Good luck!! Rate this post!!
Buy whole unit or replace motor
A PAIR OF FAN MOTOR WILL COST YOU$90 DLLRS PLUS INSTALL, ANY ONE CAN INSTALL THE FANS , UNIT WILL HAVE TO BE REMOVED FROM INSTALL, ONCE ON A TABLE DRILL OFF THE RIVETS AND REMOVE COVER, LIFT THE BLUE INSULATION COVER THAT WILL BE EXPOSED AND YOU WILL SE ALL 4 FANS TWO COLD SIDE(EVAP SIDE) TWO HTO SIDE (CONDENSER) USE A PHILLIPS SCREW DRIVER TO REMOVE FANS INSTALL THE NEW ONES AND CLOSE UNIT USING SELF TAPPING SCREWS OR 1/8 RIVETS AND A HAND HELD RIVET GUN.
Unit runs gets only to 62 degrees. Top exhaust clean. 5 yrs old
CONTACT THE MANUFACTURER BREEZAIRE 858-566-7473 THEY WILL CONECT YOU WITH A DEALER THAT STILL MODIFIES UNIT TOP VENT.
BREEZAIRE DOES NOT MODIFY THE UNIT TOP VENT THEM SELF NOR DO THEY SELL DIRECT BUT THEY WILL PUT YOU IN CONTACT WITH THEIR DEALER THAT DOES.
Evaporator ices; unit does cool
TWO POSIBILITIES
ONE IN MAJORITY OF CASES IT IS A SYMPTOM OF A FREON LEAK, ICE FORMS ON COIL, UNIT MAKES NOISES AND IT WILL GRADUALLY LOOSE COOLING RUN NON STOP AND THEN IT WILL PRODUCE HEAT
SECOND
A BAD FAN ON THE COLD SIDE OF UNIT THAT REDUCES AIR FLOW PASSING BY THE COIL AND ALLOWS IT TO FREEZE, IN THAT CASE IT WOULD NEED A FAN REPLACEMENT, YOU MAY CONTACT THE MANUFACTURER FOR A REPLACEMENT FAN
How many ounces of r22
A WKCE UNIT SHOULD BE AN R-134A SYSTEM NOT AN R-22 IF IT IS A R-22 IT SHOULD SAY SO ON THE TAG ON THE BACK OF THE UNIT NEXT TO THE CONDENSER COIL(BEHIND THE WHITE GRILL) IF IT IS AN R-22 IT SHOULD BE A MECHANICAL THERMOSTAT UNIT (SCREW ADJUSTMENT ABOVE THE FRONT BROWN GRILL)
IF R-22 MODEL 2200 13 OZ
IF R-134A MODEL 2200 10 OZ
MANUFACTURER CAN PROVIDE INFO ALLSO AS LONG AS YOU PROVIDE THEM WITH MODEL AND SERIAL NUMBER OF THE UNIT 858-566-7473
It stoped cooling why? can it be recharged?
IF IT IS A WKCE2200 IT IS REPARABLE, BEFORE RECHARGING IT REQUIRES TO BE TESTED FOR A LEAK AND THEN YOU HAVE TO REPLACE THE FAULTY COMPONENT AND THEN VACUME THE SYSTEM BEFORE YOU CAN RECHARGE
Need the compressor or a
REPLACEMENT IS A WKCE1060 OEM (CABINET MODEL) WITH POWER CORD OUT EXHAUST AND POWER WIRES FOR A LIGHT
CHECK WCISERVICE.COM
MODIFIED UNITS
