20 Most Recent Grindmaster CTH-3311 Frozen Drink Machine counter model wair cooled Questions & Answers
You might be low on gas in your compressor. If compressor comes o b but doesn't cool chances are gas is too low. Make sure coils are clean and air gets to the back of the unit
Grindmaster... | Answered on Sep 14, 2014
Only place leaking by tray could be the boot seal is bad.Check also the rear shaft bushing.Front door gasket may be bad or plexi door.
Grindmaster... | Answered on Feb 12, 2011
hi kostas.
Condensation runs down the back of the fridge and collects in the gully sitting at the back of the fridge where the water is then channelled through the drain hole into a container which sits on the compressor, it's then evaporated away.
How to Stop Water Collecting in Your Fridge ' eSpares
https://www.espares.co.uk/advice/.../how-to-stop-water-collecting-in-your-fridge Water accumulating inside the fridge Google Search
Refrigerators | Answered Yesterday
Most frost free refrigerators take water from the freezer so you do not have to defrost the freezer. That being said there should be a drain under the crisper. Check to see if it is clogged.
you may need to put something under the refrigerator to collect the water..
Diagnosing Walk-in Coolers & Freezers Problems
blog.uscooler.com/walk-in-cooler-freezer-problems/
Jun 7, 2013 - Diagnose Walk-in Cooler & Freezer Refrigeration Problems ... For many evaporator units, the ice isn't melted, or the water isn't .... It works for few days (2-3 days) and it stop and does not run until I shut off the power .... My walk in compressor seems to be running and not shutting off. .... outdoor ambient= 85
Maintaining & Cleaning Your Walk-in Cooler or Freezer
blog.uscooler.com/maintain-walk-in-cooler-freezer/
Jan 7, 2015 - Torn gaskets can let warm air infiltrate your walk-in cooler or freezer. Close the door when not in use. Do not block or prop the door open for extended periods of time. ... on suction lines between the condensing unit and evaporator coil. ... Make sure the lights are off when exiting the walk-in. ... clean walkin ...
[PDF]INSTALLATION & SERVICE MANUAL - Polar Leasing
Refrigerators | Answered on Jan 11, 2021
The machine will continue to run water all the time while in harvest mode. The control board blew, and just needs to be replaced. Controls boards can fry without any other signs of anything else being bad. Hoshizaki ice machines dont have a over heat relay that shuts it down upon oerheating if it is the control board
As the harvest cycle (the ice maker fingers rotate to sweep the cubes out of the mold) comes near the end of the rotation, a switch in the ice maker activates to send power to the water valve (located under the refrigerator where the house water supply line connects) and allows perhaps 4 cc of water to flow up a 1/4" plastic line to a fitting on the back of the refrigerator that is aligned with the ice maker inside which then flows into the maker mold. That process refills the ice maker mold and everything shuts off to freeze this water and then initiate another harvest cycle when the entire process is repeated. If there is no water, then there is no ice. Focus on why the water isn't flowing all the way to the ice maker. Look for an ice blockage in the tubing that comes from the back, inside wall of the freezer to the ice maker, or a bad valve. It is rare, but the switch inside the ice maker could be bad. The water valve or a blocked water line are most likely the culprits. Another trick is to pour water into the ice maker mold, wait several hours and see if that freezes and ejects into the pan. If so the ice maker is working, it just has no water to freeze.
Refrigerators | Answered on Jan 09, 2021
The True TSSU-60-16 uses an oversized (134A) refrigeration system with air flow directed at the pans.... if the capillary tube is plugged it will NOT cool at all.. most of the time a restriction (plug) is at the drier where the capillary tube goes into it.. as it is smallest passage in the system...hope it helps
This refrigerator repair video about repair of restricted sealed system. I hope this helps.
I have a Kenwood tall fridge (KTL60X15) which developed similar faults. It was beeping every time the door was opened (the display showed 88 and all other buttons were lit) and it would beep again when closed. Turns out the wiring from the fridge body to the door had worn out and by the time I discovered the problem 3 of the 5 wires had broken. The wiring can be round under the plastic covers at the top of the door and at the top of the fridge body.. I replace the wiring which was easy to do as it comes as a wiring harness kit (HK1495740) and adjusted how the wiring goes across the top hinge by making a small modification to the plastic covering on the top of the fridge body. So hopefully it won't wear out (at least now I can see it and keep an eye on it).
Refrigerators | Answered on Jan 06, 2021
Where is fuse located on mishto fridge
Usually three reasons
Condenser coils full of fluff.
Evaporator is a block of ice, normally caused by a failed defrost timer.
Low on refrigerant gas.
Refrigerators | Answered on Jan 05, 2021
Grindmaster CTH-3311 Frozen Drink Machine counter model wair cooled Logo
3 questions posted
Top Grindmaster Refrigerators Experts
Marvin
Marvin
john h
Are you a Grindmaster Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Grindmaster Refrigerators
Most Popular Question
compressor but wont freeze
  • Refrigerators
