20 Most Recent
Shure (LX287CC) Professional Microphone Questions & Answers
Radio Microphones.
See the following for repairs:
http://shure.custhelp.com/app/answers/detail/a_id/4053
I have a Shure PG48
That's really hard to diagnose over email with this description. I suggest calling Shure Applications at 800-516-2525. They can help you troubleshoot and ask any questions that might help in determining the problem.
Microphone cutting off
Ensure the battery in the mic is 100% - low batteries can cause all sorts of symptoms. I wouldn't recommend anything other than a well known brand of Alkaline battery and definatley not rechanrgables.
I have only the transmitter
Any Shure receiver that operates exactly at 173.800 MHz will work with your transmitter. These receivers have been discontinued for several years, so it will not be easy finding one on the exact frequency that you need.
My microphone has no sound
Your gain adjustment should be increased in the microphone or maybe the outputlevel from your receiver. If both doesn't solve your problem, maybe the element has a problem. You could turn of the grill and you will find the solderingjoints, just tip it with your finger. If you hear some hum, your element has a problem.
Regards,
Gerard
Battery connection on my Shure SM58
Hiya,
I know they could have come have come up with something a little more durable!!
What we used to do is put a piece of double side tape at the back (the thick 2mm spongy one) and then put paper or something over the front so the battery doesnt stick to it, battery then has alot more pressure on it. The tape sticks into the back of the mic. Its a bit stoneage, but worked pretty well.
Best of luck
Trying to open my Shure sm58 beta
About half way up the body you will see a seam. The body with the cartridge and wind screen separates from the bottom half of the body at that juncture. You have to unscrew one from the other. You will see wires that have to be unsoldered. Make note of where they were soldered and do the same thing for both the mike with the dead cartridge and the mike with the good cartridge. Swap straight across and you're done. Hope this helps.
SHURE BLX4R BATTERY LIGHT OFF AND WONT SYNC - HELP!
please attempt to factory reset your microphone. Also, some companies only allow certain accessories like a battery to be provided by them or special partner companies. So, please verify with your manufacturer that duracell batteries are allowed to be used within their products.
Thank you.
