20 Most Recent Mintek MDP-1070 Questions & Answers
0answers
0answers
0answers
The DVD keep spinning but won't play
see the next steps and fix it. God bless youClean a DVD disc:
  1. Hold the disc by its central hub and outside edge.
  2. Blow dust from the bottom surface with a can of compressed air.
  3. Clean dirt and fingerprints from the bottom surface with a lint-free cloth dampened with CD/DVD-cleaning fluid or denatured alcohol, wiping from the center outward.
  4. Clean the objective lens:
  5. Remove the housing and lift the hold-down clamp to expose the lens.
  6. Remove dust with canned air or soft brush. If needed, use a foam swab or a camera-lens tissue dampened with lens fluid.
10/3/2012 3:19:12 PM • Mintek MDP-1070 • Answered on Oct 03, 2012
My DVD keep spending and it won't start I cleaned it but nothing happened
see the next steps and fix it. God bless youClean the objective lens:
  1. Remove the housing and lift the hold-down clamp to expose the lens.
  2. Remove dust with canned air or soft brush. If needed, use a foam swab or a camera-lens tissue dampened with lens fluid.
Clean a DVD disc:
10/3/2012 3:17:14 PM • Mintek MDP-1070 • Answered on Oct 03, 2012
Error message bad disk or no disk
I dont know ,why it gives me a message no disk? what should i do ?
9/22/2012 4:52:23 PM • Mintek MDP-1070 • Answered on Sep 22, 2012
I need to buy a
Here it is
http://www.amazon.com/Dvd-1710-Dvd-5820-Dvd-5830-Dvd-5861-Mdp-1810kit/dp/B001R2ERFY/ref=dp_cp_ob_e_title_3
6/24/2011 6:43:13 PM • Mintek MDP-1070 • Answered on Jun 24, 2011
We get sound but no
try to check the region code setting of the player found in your users manual
5/24/2011 7:28:19 PM • Mintek MDP-1070 • Answered on May 24, 2011
I need a manual for my MDP 1070. Where can I find
Hello
Visit these sites:
www.manualsonline.com/ex/thread/view/idThread/2222007
deltamanual.com/result/mintek-mdp-1070-problems.html
3/26/2011 3:36:56 AM • Mintek MDP-1070 • Answered on Mar 26, 2011
2answers
I insert the AC adaptor into the DC IN jack of the
try gently cleaning the 'eye' on the disc player very gently with a qtip and rubbing alcohol
this should get the player to start reading discs again
if not make sure you are using disc formats that are compatible with the player you are using (eg. DVD+R, DVD-R, DVD+RW, etc)
good luck hope this helps
PS dont know about battery issue you are discussing but i would not post my phone number on a public site again if i were you - anybody could be reading these questions
3/25/2011 7:23:03 PM • Mintek MDP-1070 • Answered on Mar 25, 2011
When trying to play dvd,
This might be a lot of things. THE first thing that you need to do is try several disks. If you get the same error on all of them EVEN CD's then you have to check and see if the head is moving and if the laser is clean. You should be able to do this when you open the unit. THe head and the laser should be visible if the lid for loading pops up. The other kind that you have to insert the cd in is more difficult to work with,.. ANyway you can move the head toward the outter area. (CD and DVD play from the inside out). Then you try again and see if the head is moving. If it is then you have an issue with the laser. You can clean it with a q-tip and alcohol. Then try it again. IF this wont work then it is time to see about a new one. NOTE that it can play CD's and not movies as there are two lasers in the unit.
10/17/2010 1:15:56 AM • Mintek MDP-1070 • Answered on Oct 17, 2010
Backlight problem with a Mintek Portable MDP-1070
paper black &lines
3/12/2010 7:58:49 AM • Mintek MDP-1070 • Answered on Mar 12, 2010
Cover broken
Yes. Parts should be available from the manufacturer and/or distributor. To find them, look in the phone book's yellow pages, consult your user manual/warranty or do a Google search on line.
Good Luck :)
2/10/2009 5:00:20 AM • Mintek MDP-1070 • Answered on Feb 10, 2009
Mintek 1070
With the power turned off, open the lid and then open the hatch where you put the DVD into. Locate the laser lens and notice that the laser lens is attached to an assembly that moves diagonally outward in a slot. First, slide this assembly outward. Second, slide it back inward. Now repeat, slide out then back in. Next, put in a music CD and let it play all the way through. (This re-calibrates the laser head assembly movement.) When the music CD is done playing, put in a DVD, you'll have a working unit again. I had to do it twice...
6/26/2008 9:24:59 PM • Mintek MDP-1070 • Answered on Jun 26, 2008
Mintek MDP-1070 Logo
Popular Tags
27 questions posted
Top Mintek Televison & Video Experts
Jaime Hernandez
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Mintek Televison & Video
Most Popular Question
u get parts
  • Televison & Video
