20 Most Recent Insignia IS-PDVD10 Portable DVD Player Questions & Answers
0answers
How to connect a dvd to an insignia hdtv
just use an rca connector, connect one end of the connector usually 3 wires for video and audio L/R.hooked up to the video/audio output jack of the dvd player and then the other end to the component input jack of the tv unit either input 1, 2 or 3.
9/18/2012 11:29:25 AM • Insignia... • Answered on Sep 18, 2012
WHITE SCREEN NS-P10DVD11 PLAYER....Plays sounds no picture....Has a 1 year warranty...can i get a replacement..
The fault is with its video processor section. If the set is in waranty period, it will be best for you either get it repaired by its authorised service center, of replaced it by an other one. The second stated will be best, rather than get it repaired as it is new.
5/22/2012 5:12:12 PM • Insignia... • Answered on May 22, 2012
2answers
I need a battery for my Insignia NS-PDVD10
Tries websites like Amazon.com,Ebay.com to buy an exact battery replacement.Never buy generic battery,because will not fit in ur battery compartment.Buy a generic battery only when ur user manual said so,and it allow u to use other battery brands,beside it own brand.
11/27/2011 10:51:34 PM • Insignia... • Answered on Nov 27, 2011
2answers
Portable dvd player insignia ns-pdvd10 screen problem
Check the screen switch on the right top side where the door closes there is a little circle and the release switch usually gets jammed (this is a common defect) you will need a small thin flat head screwdriver to pry out the switch.
9/7/2011 3:10:11 AM • Insignia... • Answered on Sep 07, 2011
2answers
SATELLITE SIGNAL
This is a problem with the shielding on the television the other signals are interfering with the reception. Call the television maker and ask the for advise on how best to shield the television from the other signals. You could also try shielding the television with tin foil wrapped around the critical area of the television. This might work, but it better to talk to the television customer service they may have some filters that can block the noise causing your interference problems or go online and check their website for the frequently ask questions and see if a problem like yours has been answered. Hope this helps you with your problem.
6/5/2011 11:09:46 PM • Insignia... • Answered on Jun 05, 2011
Not reading disk>
Hi cleno,
Click this LINK to help you fixing the symptoms.
Hope I helped you.
Thanks for using Fixya.
4/18/2011 12:43:46 PM • Insignia... • Answered on Apr 18, 2011
Insignia Portable DVD cannot be
I had the same problem. There is a fuse in the cigarette lighter that probably needs replaced. It's a slow blow fuse, the only place I was able to find it was Radio shack
11/27/2010 4:03:24 AM • Insignia... • Answered on Nov 27, 2010
0answers
Won't turn on.
Be the first to answer 10/1/2010 2:04:33 AM • Insignia... • Posted on Oct 01, 2010Be the first to answer
I will put in a
When you get No Disc, it normally occurs for one of two reasons. Either dust has built up on the lens of the laser mechanism, or the operating voltage of the laser has drifted off slightly due to heat and age. Of course, occasionally there are actual failures of components, which cause this, but these are the main two reasons.
Tools required by this guide are (not all are required for all parts however):
1) A normal sizes star (Phillips) screwdriver.
2) A very small Phillips screwdriver.
3) A small, flat screwdriver.
4) Some isopropanol alcohol (IPA)
5) A few cotton buds
6) A little mechanical grease. (I've used Vaseline before)
7) A can of compressed air.
8) An oscilloscope.
Cleaning the laser lens
1) Remove any CDs from the unit and unplug all leads and memory cards. Turn the unit upside down and use the small, flat screwdriver to pop out all the little plastic and rubber screw covers.
2) Take your normal sized Phillips screwdriver and unscrew all the screws.
After removing them the step is to clean the laser lens
Take a cotton bud and careful place some of the alcohol on it (but not so much that it is dripping everywhere). This alcohol is the same (or similar) to the small bottle of alcohol which is in audio and video cassette cleaning kits. This is probably the best way to locate a source. Locate the lens (the circular glass part) and very gently rub the cotton bud around the lens in circular motions for about 30 seconds, being very gentle. Once done, flip the cotton bud over and dry the lens with the other end for about 10 seconds.
But if otherwise you will need to change the lens to a new one .
Take care.....
10/1/2010 12:01:18 AM • Insignia... • Answered on Oct 01, 2010
Need replacement screen for insigns NS-PDVD10
If you contact these guys, they might be able to run it down for you:
https://www.mcmelectronics.com/browse/Insignia%20/%20Dynex/0000000182/p/49
If you can't locate the screen through them, you will have to go through the manufacturer or find a compatible replacement, which hopefully they can suggest:
http://insigniaproducts.com/support.html
Good luck, and hope this helps.
9/18/2010 5:47:29 PM • Insignia... • Answered on Sep 18, 2010
Insignia PDVD10 works fine from outlet but battery won't charge
You must get a new battery. If the unit is still under warranty take the back to the place of purchase and tell them that the battery will not charge and ask them for a replacement. if this is not under warranty then you will have to buy a replacement battery. Call these telephone numbers for technical service and parts replacements. Service :1-877-467-4289. Parts replacement : 1-888-237-8289. Make sure you give them the model number or the unit and the part number of the battery that needs replacement. Hope this helps you with your problem.
8/25/2010 7:56:31 PM • Insignia... • Answered on Aug 25, 2010
HOW DO I KNOW IF MY INSIGNIA DVD IS CHARGED?
When the battery is charging, the CHG indicator turns orange. When the charging is completed, the indicator turns off. More information can be found in the owner's manual.
7/1/2010 12:42:06 PM • Insignia... • Answered on Jul 01, 2010
Why would the dvd play some moves and not all of
the DVD will not play some movies because of the movies are pirated, which is substandard and not compatible with DVD
Thanks.
6/19/2010 11:20:39 PM • Insignia... • Answered on Jun 19, 2010
It keeps saying no disc
If you are trying store bought discs and more than 2 are not playing, and all of the discs are clean of smudges then the issue is the dvd reader in the player. The unit will need to be replaced/repaired. Repair however is usually more expensive if not just as expensive as replacing the unit.
5/7/2010 3:30:44 PM • Insignia... • Answered on May 07, 2010
When i put a dvd in it the screen just jumps.
how long have you been using this player? The problem should be from the lens (laser).
The lens is weak and that's why it cannot read/load DVD's. The weak lens is the cause of he problem and not battery.
The lens reads the files/data on the disc inserted into the player and once the lens is weak, there is no way it would load discs.
Get a lens cleaner and use it to clean the lens, but if the lens still does the same thing even after using the lens cleaner, then it means you would have to change the whole lens completely to a brand new one.
By so doing your player would play all DVD's with no problem at all.
Good luck.
4/22/2010 11:49:38 PM • Insignia... • Answered on Apr 22, 2010
I NEED A CHARGER FOR MY INSIGNIA
the IS-PDVD10 takes a 12v wall-wart and should be available from any electronics retailer (like Best Buy ;) ).
It will work with a 9v power pack, but there will be issues with image quality and volume since the device is underpowered. This is not recomended.
Hope this helps!
4/21/2010 11:41:23 PM • Insignia... • Answered on Apr 21, 2010
2answers
Screen goes black.
I would say an inverter problem, you will need to have a qualified tech. do the repair. Julio [email protected]
3/20/2010 2:27:04 PM • Insignia... • Answered on Mar 20, 2010
Insignia IS-PDVD10 Portable DVD Player Logo
77 questions posted
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Insignia Televison & Video
Most Popular Question
need replacement screen insigns ns
  • Televison & Video
