20 Most Recent Mercedes C-class C230 C240 C350 C55 Exterior Stainless Steel Chrome Pillar Posts Trim Set 2005 2006 2007 Questions & Answers
If they are not working, check the fuses
Mercedes C-class... | Answered on Feb 26, 2019
I take help from online websites that have this service like helping in repair some like reliable-store have instant help.. others are a bit slow which I don't prefer... rest is up to u
U can also get free manuals
Mercedes C-class... | Answered on Jan 29, 2019
You can find the info you are looking for in a repair manual, such as Chilton, Haynes, etc.
If a repair manual is not available, the local garage or dealership can provide you with the info, with their database from MotorAll Data, ShopKey, etc.
Check the library to see if they have the resources, such as the repair manual, or online database to, MotorAll Data, ShopKey, etc.
Have a nice day.
Mercedes C-class... | Answered on Jul 09, 2016
Faulty Braking , Might be leaking fluid , most possible it is Brake Pads worn right dowm..
Mercedes C-class... | Answered on Jan 11, 2016
Maybe you're looking in the wrong area. You said it started to idle rough and kept shutting off. That could also be a fuel related issue. Possibly a clogged fuel filter or weak fuel pressure from the pump going bad. Check your fuel pressure. If you discover that the fuel pressure is correct, then make sure you have a strong blue colored spark from each coil by taking a good plug and plugging it into each coil while its out of the cylinder. Have someone spin it over and watch the color of the spark. A dull orange colored spark could mean bad coils or even the computer itself.
Mercedes C-class... | Answered on Dec 06, 2014
If you want this cheap and easy, I recommend you take it to your local dealer, make them pull out the codes for you, and then you can easily find out what the code means by using google. then you attain and replace the part mentioned for the code
Mercedes C-class... | Answered on Nov 10, 2014
Yes it can. I have heard of smart keys having problems especially after getting wet. Any good locksmith can check and reprogram your key if necessary
Mercedes C-class... | Answered on Jul 22, 2014
Yes the airbag module must must always be replaced. Its most likely located under the mid console. Not sure about location
Mercedes C-class... | Answered on May 08, 2014
If an Alignment was done and the steering sensor angle was not reset properly this can happen.
So a bad steering sensor can as well yes.
Also other things can as well, like an ABS Fault.
On a side note, if the vehicles battery is going bad, the low voltage will cause dozens of random codes through out all of it's systems.
(Learned all of that first hand, it wasn't much fun)
Mercedes C-class... | Answered on Oct 31, 2013
Disconnect the battery for 10 minutes incase the battery charger messed with the computers in the car.
Always disconnect the battery before charging it on modern vehicles (especially German Vehicles) as things like this happen.
Mercedes C-class... | Answered on Oct 24, 2013
try finding it here>>www.discountbargainprices.com
Mercedes-Benz... | Answered on Feb 27, 2019
Becker Code is 22325
________________________________________
  • Radio Codes and advice are always available here
www.ukbookshelf.co.uk
  • Mention FixYa Forum
Mercedes-Benz... | Answered on May 14, 2016
These people might be able to help with that............
Mercedes-Benz... | Answered on Dec 12, 2015
You cannot. They are all expensive as are many other parts for that vehicle.
Mercedes-Benz... | Answered on Sep 26, 2015
one of these models may be the vehicle
http://www.blumke.net/content/m/mercedes-actros-fuse-location.pdf
Mercedes-Benz... | Answered on Apr 20, 2015
White smoke almost always indicates a blown head gasket, or cracked head. A compression test will tell you for sure.
Mercedes-Benz... | Answered on Feb 18, 2015
http://www.fixya.com/tags/po496_code
If you need further help, reach me via phone at https://www.6ya.com/expert/david_1f7d1c330c9dd97d
Mercedes-Benz... | Answered on Dec 31, 2014
The causes for this DTC may include: Low fuel pressure caused by a clogged filter, failing fuel pump, failed fuel pressure regulator or clogged or leaking injectors. Rough running engine due to misfiring plugs. Many engines have misfire codes to indicate the cylinder effected, such as P0304 for number 4. A large vacuum leak would cause a massive amount of un-metered air to enter the intake manifold resulting in an overly lean mixture. A large air leak at or near the number one oxygen sensor would also cause a lean mixture. A plugged converter will cause of host of driveability problems as well as set this code. A severely plugged converter will result in the inability to increase rpm when under load. Look for a code such as P0420 -- catalytic converter efficiency below threshold if the converter indicating a faulty converter. A faulty oxygen sensor. This will set a code in itself, however, a faulty oxygen sensor does not automatically condemn the sensor. The code just means that the sensor signal was not within specifications. An air leak or any of the above will cause an erroneous signal. There is a multitude of O2 codes relating to O2 performance which gives a clue to the problematic area. The Mass Airflow sensor will also cause this problem. It would be accompanied by a code such as P0100 -- Mass Airflow circuit malfunction. The Mass Airflow sensor is a hot wire that senses the volume of air entering the intake manifold. The computer uses this information to control fuel mixture. Rusty exhaust systems, cracked exhaust manifolds or damaged or missing gaskets or donuts will cause air leaks.
Look in your glove box in the owners manual or with the papers you got when you got the car, and see if you have a card or a piece of paper that tells you what the code is. If not you will have to call your local mercedes dealer and give them your vin/serial number and they can look it up for you.
Mercedes C-class C230 C240 C350 C55 Exterior Stainless Steel Chrome Pillar Posts Trim Set 2005 2006 2007 Logo
Popular Tags
10 questions posted
Top Mercedes-Benz Vehicle Parts & Accessories Experts
Marvin
Marvin
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Are you a Mercedes-Benz Vehicle Part and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Mercedes-Benz Vehicle Parts & Accessories
Most Popular Question
signal lights hazard lights
  • Vehicle Parts & Accessories
