20 Most Recent
Luhr Jensen Big Chief 9890 Questions & Answers
Big Chief smoker trips 20 amp GFCI
try to use another out let and see if it is the GFI outlet first if it trip the new outlet then you know it the grill and not the outlet
Do you wet the chips
DO NOT USE THE BOX TO KEEP HEAT IN!!! Mine caught fire and I looked outside and there were 6 foot flames engulfing the whole unit! Had to use fire extinguisher (thankfully keep them handy) to douse.
I need instructions on using
Hi jmcomber..
To use your Brinkman,Luhr Jensen Smoker or Other Smokers
1... Marinate or place a rub on the meat you will be smoking, and let it sit for a few hours or over night in the refrigerator.
2...Cover your wood chips with water(and if you wish you can add some Jim Beam Whisky or other flavorfull liquids in a bowl with the water, 1 inch above the wood chips and use a flat peice of metal (pie pan,etc.)to weigh the wood chips down underwater.
3...Start a fire in the smoker having the fire below the meat, use hardwood or charcoal,
Once they are coated with gray ash, you can place the meat on the racks.
I would place an aluminum drip pan under the center portion of the cooking area on your smoker, to catch the juices from the meat.
4...Place the meat in the smoker on the grilling surface, and place the wood chips over the charcoal and hardwood in the main grilling area Close the lid and do not open it unless you must add wood chips during the cooking process.
5...Continue adding wood chips to the tray as needed during the time you are cooking.
If you have a Brinkmann or other smoker with one chamber for placing the wood chips and the meat, add wood chips only once per hour.
6...Apply your sauce to the meat one hour before the meat should be done.
Test your meat with a thermometer for for an internal tempreture of 160 degrees for medium and 170-180 degrees for medium well to well
Note: Apply the sauce quickly to avoid loosing the heat in your smoker if you leave it open too long it will allow the heat and smoke to escape, increasing the cooking time.
Close the lid if it needs to continue cooking till you reach the right internal tempreture
7...Test your meat with a meat thermometer after a few hours of cooking time.
Make sure your meat is at least 160 degrees internal tempreture for medium and more than 170 degrees for medium to well.
Close the lid and maintain your heat if it needs to continue cooking.
Please take time to rate me.
I have experienced deforming of
Sorry to read about your problem, I hope this helps you out.
It is not uncommon, for plugs that connect direct to heating elements. The left socket is the high resistance side, and heat is generated, so the socket deforms. The cord is made in china, and they are cheap.
The permanent fix, would be to hard-wire the the heat element wiring to a new style heavy duty cord, rated for 20 amps
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
After smoke flavoring salmon i
nope you keep it on, or you can let air dry if it warm outside ..your choice
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Lost the electric cord to the Smoker.
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Big chief smoker
I am on my third cord. I love the smokers, and own 2 but the cord design stinks. You can clean the contacts all you want, but one always heats up, gets soft, loses its spring, and causes a weak contact. When that happens, it arcs, melts, and finally burns out. You can google "smokehouse cord" and find suppliers from $17.00 to $23.00 (smokehouseproducts.com). I'd like to hardwire a solution or make a replaceable head. If somebody has a good, safe design for this, let me know.
Doesnt burn chips very long
Do you soak your chips prior to use? Then pile the chips on the end are of the coals and let the heat grow to incorporate the soaked chips, place the chips in a cone shaped pile, this will let them smoke from the bottom-up.
Is "Halal" meat safe for humans?
Hi, Carole. According to the Wiki article on Halal, it is an Arabic word meaning "permissible," referring to food, objects or actions. With respect to food it is similar in intent to the Hebrew word, "Kosher." In both Islam and Judaism, for example, pork is not considered permissible. There is much more to know about Halal, but I'll defer to our Islamic neighbors to answer more fully. Short answer: entirely safe. Enjoy!
12/27/2023 4:43:31 AM •
Grilling
Answered
on Dec 27, 2023
