20 Most Recent Power Acoustik FUBAR-12W Car Subwoofer Questions & Answers
yes a good speaker shop can do a new coil. but it wont be cheep might want to think about a new one. i dont think they make recones for your model.
Power Acoustik... | Answered on Mar 03, 2016
It is to send a signal to an amp to turn on.
Power Acoustik... | Answered on Apr 06, 2014
You have a case of a blown sub. You will need a recone kit. You ca send it in to a company like fix my speaker or google recone kits for Power Acoustik FUBAR. May be cheaper just to get another sub.
Power Acoustik... | Answered on Oct 22, 2012
Depending on the PA FUBAR you have. The voice coil on those subs are DVC. Dual Voice Coil. You need to know a couple things. What kind of amp are you going to run on it. And what is the resistance (OHM) rating of each voice coil. MY two 12's are dual 4 ohm. Meaning that there are essentially 4 speakers to hook up. My amp currently is not 2 ohm stable in bridged. So what I did is run each speaker in parallel (red2red,black2black) then run to the box terminal. So now the dual 4 ohm voice coils are basically 2 ohm. I have 2 speakers. Now I hook the box up in series. To bring the now two 2 ohm speakers into one 4 ohm speaker. This is called series/parallel setup. My amp sees this box as 1 channel @ 4ohms. The downfall to this is the output of the amp is divided up into each speaker. So instead of sending all 1400 watts to one sub. I will send 700 to each sub. But here is a catch. even though each speaker is half the total wattage it will still be 3db louder. Meaning it will be as loud as 1 sub running 1400 watts. To conclude i need to know how many of those subs you are going to run on the amp.. And the model number of the amp so I can match up your wiring.
Power Acoustik... | Answered on Jul 12, 2011
I suggest to use separate amps to your sub, get a 2 channel amp for your sub and 4 channel amps for your speakers.
Here are my Top 5
  • Lanzar -OPTI4000D
  • MA Audio- HK-4000D
  • JL Audio 1000/1V2
  • OPti 22.2 Power Amp
  • AudioBahn-A5100T
Power Acoustik... | Answered on Apr 05, 2009
  • Smart Control enables select Mobile 8 models to communicate with the media player of most Smartphones and tablets
  • Smart Control sends playback commands by the AUX cable connected to the headphone output of your smart device
  • Control track selection, play/pause, and even answer incoming calls. AUX cable included. Variable Subwoofer Pre-Amp Output
  • Play audio, video, and picture files through Mobile 8 from DVD, CD, or 32GB SD/USB flash drive. Supports MP3 & WAV audio files & MP4 video files, and JPG pictures.
  • Safely make and receive hands-free phone calls, scroll contacts lists, and stream MP3's via A2DP from your enabled Smartphone. Most Bluetooth enabled Smartphones seamlessly pair
Power Acoustik... | Answered on Apr 17, 2020
MP4 is a codec that is not compatible with this DVD player. Your DVD player will play store bought DVDs just fine. Please read the specifications in the owners manual to see what codecs are compatible with your player.
Power Acoustik... | Answered on Nov 28, 2019
Okay I am assuming that you are referring to a USB thumb drive aka memory stick which contains mp3, wma (YOUR STEREO ONLY PLAYS MP3 AND WMA VIA USB NOTHING ELSE MANUAL SAYS) audio tracks and a certain specific format (formatting is done on computer, windows and different types of formats are supported on different devices). NTFS, fat32, exfat. Typically I think they like fat32 before but I have had all of my drives formatted for NTFS on newer equipment and had no issue with it. Um since you checked the drive and its working it's probably not that. It could be the connector on your stereo there. But if its new it's probably a formatting/compaitbility issue with the stereo. Heres the manual http://www.poweracoustik.com/pa2012/manuals/PD-710-T.pdf Also this stereo is a really cheap brand so they don't work as well and dont have that great of support. A Google search of that an similar stereos from them came up with several issues. There is very little USB power coming from that port so it's probably only enough power to connect a thumb drive. Some people have cables connecting to other devices and that is probably not going to work. I would get a different usb stick reformat it on the computer and copy some mp3's over.
Power Acoustik... | Answered on Nov 01, 2019
It may connect to another if receiver, if you have a second screen in the back of the vehicle you can control the unit from there.
Power Acoustik... | Answered on Jul 12, 2019
Search google for a schematic should be able to find one. I repair amps. Marks Car Audio & Amp repair
e-mail skinnman33 @gmail.com I can be reached at 727-266-6398 Let me know
Power Acoustik... | Answered on Apr 01, 2019
It depends on how many channels are on the Amp. If it's a 2 channel you can bridge it using the positive on one channel and use the negative on the other channel. The Amp will give the sub more power bridging the sub.
Power Acoustik... | Answered on Mar 10, 2019
Power Acoustik FUBAR-12W Car Subwoofer Logo
Popular Tags
5 questions posted
Top Power Acoustik Car Audio & Video Experts
Marvin
Marvin
Muntejaya Ginting
Muntejaya Ginting
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Power Acoustik Car Audio & Video
Most Popular Question
fix frozen 12 inch power acoustik fubar
  • Car Audio & Video
