20 Most Recent Cnet CSH-800 8-Port Ethernet Switch Questions & Answers
0answers
Ip address
Be the first to answer 9/6/2013 4:16:42 AM • Cnet CSH-800... • Posted on Sep 06, 2013Be the first to answer
0answers
Csh-800
Be the first to answer 11/18/2012 4:58:28 PM • Cnet CSH-800... • Posted on Nov 18, 2012Be the first to answer
CSH-800 8-Port Ethernet Switch Problem When
Switches arnt not detectable by the computer, a switch allows you to link multiple pcs togethers that sit on the same domain/workgroup , and also network subnet, the other lights will come one when you connect a RJ45 cable between the unit and a PC to show a port is in use.
5/11/2011 2:28:43 PM • Cnet CSH-800... • Answered on May 11, 2011
How do i disable dhcp
Hi!
I should mention that network switches don't have any ability to assign IP addresses. In other words, they can't act as DHCP servers - therefore there's nothing to disable!
If your network has a router (or a modem-router), configurations should be made in it...
BTW, you can disable DHCP in Windows (i.e. assigning a fixed IP address to each computer on the network) but following this (the part that should interest you has the title "If Your Router Doesn't Let You Set Static Local IPs").
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Best regards,
Pelu.
12/8/2010 3:33:07 PM • Cnet CSH-800... • Answered on Dec 08, 2010
Which type of cat-5 cable
interConnecting two switches will need a crossover cable. Please use a crossover cable.
10/31/2010 2:25:51 PM • Cnet CSH-800... • Answered on Oct 31, 2010
Check the power adapter with a multi-meter. The voltage on the plug that connects into the Ethernet switch, the voltage reading should be slightly higher than the voltage that is printed on the label on the bottom of the adapter.
If the voltage is zero or very low then the adapter is faulty and needs to be replaced.
If the voltage of the adapter is OK then the Ethernet switch is faulty and you need to buy a new one.
12/11/2009 4:28:08 AM • Cnet CSH-800... • Answered on Dec 11, 2009
Don't have internet connection
This particular 8-port Ethernet switch/hub has auto-negotiation on both speed as well as MDI, MDI-X.  Therefore, the problem is not with your switch/hub, it's probably with the particular port that you're connecting it to on your Router.  Make sure that it's the LAN side, not the WAN side.
4/3/2009 5:40:37 PM • Cnet CSH-800... • Answered on Apr 03, 2009
Hello there, I got a BSOD saying that I had a
sounds like you hard disk is on its way out.
6/29/2017 9:26:55 PM • Cnet Computers &... • Answered on Jun 29, 2017
What is remote access server?
A server that is dedicated to handling users that are not on a LAN but need remote access . The remote access server allows users to access files and print on the LAN from a remote location.
1/11/2017 7:34:18 AM • Cnet Computers &... • Answered on Jan 11, 2017
No tengo el disco de instalacion
Me dieron un router inal?mbrico -g serie CWR-854v pero no tengo el cd de instalaci?n q me podr?a ayudar mi correo electronico es torigallo_123hotmail.com si alguien tiene este mismo router si podria ayudarme con el cd de intalacion q en las pajinas no consigo para descargarlo
1/31/2015 3:23:32 AM • Cnet Computers &... • Answered on Jan 31, 2015
Cnet cgs-2400 fan replacement
it's really not worth the trouble of replacing the fan, but if you really want to fix it then you can just expose the motherboard and use a regular fan on it's highest settings (make sure nothing can mess with the router, little kids and pets might play with it).
2/5/2014 2:45:49 AM • Cnet Computers &... • Answered on Feb 05, 2014
Give password
The router password can be change if you try inputting 192.168.0.1 in the command line of the Internet Explorer. You may need another set of numbers if the router is other than a Cisco product. It could be 192.186.1.1 or 192.168.1.0 also. You did not specify what Router you were using?
12/25/2013 2:11:49 AM • Cnet Computers &... • Answered on Dec 25, 2013
0answers
Cnet CSH-800 8-Port Ethernet Switch Logo
16 questions posted
Top Cnet Computers & Internet Experts
 Mike M
Mike M
NOEL
NOEL
matt
matt
Are you a Cnet Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Cnet Computers & Internet
Most Popular Question
disable dhcp
  • Computers & Internet
