20 Most Recent
Samsung SyncMaster 510N (Silver) 15 inch LCD Monitor Questions & Answers
Monitor goes black
Does it show a picture in safe mode? If it does you might want to install drivers specific to the Monitor if you can find them.
6/10/2011 5:39:06 AM •
Samsung...
Answered
on Jun 10, 2011
I have sam 51on lcd
The screen displays is dark/ dim because there is no backlight.
There
are two parts responsible for lighting the display. First is the CCFL
(Cold Cathode Florecent Lamp), which is the back light and the second
is the Inverter board, which provides high voltage to the CCFL. Either
of the parts can be faulty or in some rare cases both. In most of such
cases that I received for repair, it was Invertor. Inspect
the Invertor for any apparant physical damages (burnt coil or circuit
components etc). Inverter can be checked by disconnecting the present
CCFL and connecting a fresh/ working CCFL (Backlight) before actually
removing the CCFL as it is difficult and unnecessary to take it out if
its not the fault.
I SUGGEST THAT YOU SEEK PROFESSIONAL ASSISTANCE FROM AUTHORISED
SERVICE/ REPAIR CENTER FOR REPLACEMENT OF CCFL OR INVERTER.
Hope it helps! Good Luck!
CreativeTECH
4/12/2011 11:09:08 AM •
Samsung...
Answered
on Apr 12, 2011
I have a SyncMaster 510N,
power cable and data cable connection may be loose
tight it
2. your wall socket of power may not having earth connection properly
9/8/2010 5:38:49 AM •
Samsung...
Answered
on Sep 08, 2010
Display skcrin black but LED not blinking
First, connect this monitor to another computer, if you still do not get a Windows image on the Samsung LCD monitor then it is faulty. The fault could be a faulty inverter board that supplies high voltage to the CCFL lamp or the fault could be a faulty CCFL lamp.
Parts for this monitor could be avaiable from LCD Parts, theie WEB site is :-
www.lcdparts.net
6/23/2010 9:54:20 AM •
Samsung...
Answered
on Jun 23, 2010
Samsung SyncMaster 510N LCD TFT Monitor
Does the monitor remain on does it switch off?
Problem seems to be hardware related ie monitor itself is defective.Try connecting to another known working system.If monitor is defective it could be a power/inverter related issue or panel could be defective.
Please provide feedback and rate the solution.
Samir
1/21/2010 1:03:52 PM •
Samsung...
Answered
on Jan 21, 2010
SyncMaster 510N 15
It might be the connection loose of power cord problem or check your TFT power connector inside the TFT if you can open the TFT screen!!! It may be dry solder….
Other wise go to repairer and do the same….!!!
12/7/2007 4:50:08 PM •
Samsung...
Answered
on Dec 07, 2007
How to fix pink colur screen on sync master 794 mg samsung
The connecting cable or the video card would be the first suspects. Try a different cable to connect the monitor first, if there is no change, the video card in the computer would be second to look at. Can simply connect a different monitor to your computer to troubleshoot this. If the testing monitor works, it will be the graphics card that is the issue.
6/19/2022 1:41:48 PM •
Samsung...
Answered
on Jun 19, 2022
