20 Most Recent Express Mens Digital Bracelet Watch Pitch Black Pitch Black, No Size Questions & Answers
Get the manual, Google it and you should be able to download the .pdf file.
Express Mens... | Answered on May 14, 2016
Need more detail. Model number. This should go from 4.5K to 6K EUR
Watches | Answered on Jul 20, 2020
Request time-setting instructions from Oshen.
Watches | Answered on Jul 15, 2020
Tip
Finding replacement battery for watch (DIY).
If anyone opted out to replace battery in their own watch and do not know what type and size of battery is correct for replacement, just open your watch case back and reed and memorize all the writings on battery your watch allready has in it. All you can do now is to buy exactly the same replacement battery and you will never get it wrong. All that matters is the combination of letters and numbers on battery. Make is not important, so, it can be made by Casio, Maxell, Citizen, Ronda - you name it. Just make sure you are not buying some of those cheap, unknown maker batteries, as they usualy lasts for about few weeks and then they are gone. Choose well known makers name and the battery will power your watch for 2-7 years, depending on each particular watch movement model. In case if you lost your original watch battery, check your watch instruction manual. If you lost both - battery and manual - then there is no other way, but to visit your nearest watch repair shop and ask for help.
on Jul 09, 2020 | Watches
pull stem out a bit and rotate it to the proper time
Watches | Answered on Jul 07, 2020
The big one under the 12 (minutes) hand?
That only moves in Chrono mode. If it is the little dial, take it to a jeweler who does watch repairs
Watches | Answered on Jul 03, 2020
I have one of these, and look for the manual on the 'Net every time DST changes, and eventually figure it out. Here's how: (1) Hold down the ALM/SET button until you get past the alarm setting and you see 24H or 12H. (2) Step through the settings by pushing the ALM/SET button, changing each as desired by pressing the +/CYCLE button. Eventually you'll wind up with the time zone indication flashing (it's really tiny, and appears just below the time indication). Press the +/CYCLE until you get to the desired time zone. (3) After the screen quits flashing, press the -/DST button to get the desired setting. I hope this helps, and that I can find this post again next time change!
Watches | Answered on Jun 28, 2020
The Spy Net Watch was produced at least as early as 2010. Its software struggles with Windows 10 compatibility. You might try attaching the cable to a system which has Windows 7 and see what happens. I am including some links to manuals. Here is a review with some interesting points about the watch:
https://www.thebrickcastle.com/2016/12/spy-net-touch-video-watch-and-eyeclops.html
https://www.gadgetsspy.com/spy-watch-instructions-how-to-use/
Yours is most likely a 'Clip On' type which you lever off.
Most watches use one of three methods to access the battery. 'Clip on' back cover, 'Twist Off' back plate and a 'Screw Down' back cover.
'Clip On' back covers are usually smooth ands round with no notches or holes. They are levered off using a blade style lever. Some watches even have small grooves or a small lip sticking out to lever against. Most common watches tend to use this style.
'Twist Off' covers usually have evenly spaced notches or round dimples around the edge of the cover to mount a special tool to unscrew the entire cover plate like a bolt head. Some higher priced watches use this system.
'Screw Down' cover are the easiest to spot. They are usually more square in shape and held down by four tiny screws, one in each corner. They appear most often on 'Sport' watches.
Watches | Answered on Jun 26, 2020
a jewelry store or a clock repair store
Watches | Answered on Jun 22, 2020
Watches | Answered on Jun 18, 2020
Most don't automatically reset. If the appliance has a reset button, it should just need to be held in for 30 seconds to correct the fridge. Some refrigerators, including Maytag and Amana, need to have the lock button and the reset or auto buttons held at the same time to reset the fridge
Watches | Answered on Jun 17, 2020
https://www.google.com search showed the following link which may show how to set the time on that particular model, but it isn't name in the article.
https://www.reference.com/world-view/set-time-tghk-watch-edd21a32a00ff836
Watches | Answered on Jun 10, 2020
Here are the instructions to view, change alarm time and turn off alarm:
From normal time display:
Press MODE once to display stop watch.
Press MODE again to change alarm time.
Press MODE again to change time.
Press RESET once to display current alarm time.
Press and hold RESET then press START to turn on and off alarm (watch for alarm symbol on top left)
Press and hold RESET then press MODE to turn on daily alarm vs one time (watch day marker lines at the bottom)
Hope this helps.
Watches | Answered on Jun 01, 2020
this is a repair help website. we dont sell buy or value anything here
Watches | Answered on May 26, 2020
To change the clock format, visit the General section of Momentum's Settings ??, scroll down to the Clock Format option and then click 12 hour or 24 hour to the right of it. When you switch to the 12-hour format, the AM/PM unit will display for a moment and then fade away to keep the interface clean.
https://get.momentumdash.help/hc/en-us/articles/360022896993-How-can-I-change-the-clock-format-12-hour-24-hour-
https://www.youtube.com/watch?v=VfthmmTM7Oo
Watches | Answered on May 21, 2020
Express Mens Digital Bracelet Watch Pitch Black Pitch Black, No Size Logo
1 questions posted
Top Express Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
Marvin
Marvin
Are you an Express Watch Expert? Answer questions, earn points and help others
View Most Popular
Express Watches
  • Express Watches
Most Popular Question
change date
  • Watches
