20 Most Recent X-Gaming X-Arcade PC Joystick (XGMPC) Questions & Answers
hi you can only play PAL dvd's on the xbox360 hope this helps
X-Gaming... | Answered on Mar 21, 2010
VR353 is a 200k pot that feeds directly in to the vertical oscillation input of the chip on the main board at connection B1. If this pot is broken, you must replace the pot in order to get any vertical oscillation at all.
X-Gaming... | Answered on Sep 21, 2009
First, I'm going to assume this controller is usb and not wireless, blue-tooth, or gameport. Second, if you have a usb mouse or keyboard and it works fine, then its going to be that you need to find vista drivers for your device and install the drivers before plugging it in. If you have another usb device, try plugging it into the usb port and if it doesnt work either your computer is faulty or you need to update it. Vista is rather fickle when it comes to drivers and what not. Instead of windows coming out with the drivers, they let other people come out with them then they endorse those drivers. Try going to logitechs site, they are usually extremely helpful and easy to navigate. You can probably find drivers for your device easily. If you need any more help, let me know, I'll find you a few other solutions.
X-Gaming... | Answered on Jun 04, 2009
Play Recordable CDs Containing MP3/WMA Audio Files
To play recordable CDs containing MP3 and/or WMA audio files:
Press the eject button on the Xbox 360 console (or select Open Tray from any area of the Xbox Dashboard) to open the disc tray.
Place a data CD-R or CD-RW containing MP3 and/or WMA media on the disc tray with the label facing up (to the right if the console is vertical).
Press the eject button (or select Close Tray from any area of the Xbox Dashboard) to close the disc tray.
Go to the Media area of the Xbox Dashboard. Select Music, Current Disc.
To play all tracks on the CD, select either Play All or Add to Current Playlist.
If you have an existing playlist open, Add to Current Playlist will append all tracks on your current CD to that playlist. Selecting Play All will clear a current playlist and create a new one consisting of all the files on the current CD. (Be sure to save your playlist, if desired, prior to selecting the Play All option.) Files are added to a playlist in alphabetical order by file name. Playlists start again from the beginning once the final track has played.
riz.
X-Gaming... | Answered on Jan 05, 2009
Disk space provides a lot of storage space for us to store files on our computer but if you are getting the message: there is insufficient disk space to complete operation, then it means that you have no space available on your hard drive and you need to free up some immediately.
Method 1: Delete Unused Files Sometimes this error message appears simply states that your hard drive doesn't have the required space to accommodate the new files. So, the easiest way is to delete some files from the drive to clear space. Search your drive and remove any unused or old files from the drive.
Method 2: Disk Cleanup
Disk Cleanup is another very effective way to clear some space on your hard drive. This procedure will remove all the temporary files from your computer. Check out the steps below to perform disk cleanup:
Step 1: Click on the Start menu and locate Windows Administrative Tools.
Step 2: Select Disk Cleanup.
Step 3: Choose the drive you want to clean up and click OK.
Step 4: Wait for the process to complete. After that, select the files you want to remove and click OK.
If the two methods don't work, check out this article for more solutions:
5 Methods to Fix There Is Insufficient Disk Space To Complete Operation Error
Video Game... | Answered 6 hours ago
buy it. we cant pass it out.
Video Game... | Answered Yesterday
I am guessing that maybe it could be the ac adapter or that it is a bad video games console that you have purchased. Always buy authentic NES and SNES and Sega Genesis and Nintendo 64 consoles then because clone systems are not as good like the genuine consoles are.DKOldies and Lukie Games and JJ Games and East Starland games.
Video Game... | Answered on Feb 19, 2021
Ask the Software Vendor direct. Fixya does not approve of PIRACY!
Video Game... | Answered on Jan 27, 2021
Your system configuration in memory card maybe corrupted then or deleted.Or the disc drive and the lens and the reading laser is going bad and needs to be replaced.
Video Game... | Answered on Jan 24, 2021
I’m having the same problem but my copy is a digital download.
Video Game... | Answered on Jan 07, 2021
    -Open Minecraft game from games and app menu
    -Tap centre button on xbox controller twice
    -Select snap an app-Do this by pressing up on the D pad of your controller
    -Select Twitch-scroll through apps until you find Twitch, once you find it, press A button
    -Choose broadcast-when you find it hit a
    -Name broadcast, go down to text field and hit a button.
    -Begin broadcasting-scroll down to bottom of twitch screen and hit a on "start broadcasting". Tap centre button on Xbox controller one more time.
Video Game... | Answered on Jan 05, 2021
Get CD Cleaning disc from Walmart. They have little brushes that clean the optics.
Or it is a counterfeit copied disc!
Video Game... | Answered on Dec 26, 2020
Seems impossible unless you jailbreak it
Video Game... | Answered on Dec 19, 2020
Error Code: 150-3039 means there is a problem with with your external storage device. It is most common when you are using an external hard drive that does not have a separate dedicated power supply. It either isn't getting enough power or the hard drive has other problems. Try powering off your Wii U, disconnecting your external HDD, and running the system without the drive. It should work. Then power off and reconnect your external drive. If you receive the error message again then you should look into getting new external storage. This link lists Nintendo approved devices: http://en-americas-support.nintendo.com/app/answers/detail/a_id/1359/~/what-external-storage-devices-can-be-used-with-wii-u%3F
Video Game... | Answered on Dec 09, 2020
I got you on that code
GL19-Y15U-72FO-U5SW<br>
Video Game... | Answered on Dec 08, 2020
Confirm the message with OK.
The automatic spout adjustment will be deactivated during drink preparation whilst the machine remains switched on.
You can still make drinks.
Video Game... | Answered on Dec 07, 2020
Video Game Consoles & Games Logo
Popular Tags
7 questions posted
Top X-Gaming Video Game Consoles & Games Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Tom Chichester
Are you a X-Gaming Video Game Console and Game Expert? Answer questions, earn points and help others
View Most Popular
  • X-Gaming Video Game Consoles & Games
Most Popular Question
region dvds uk xbox play
  • Video Game Consoles & Games
