20 Most Recent Power Acoustik PADVD-610 Car DVD Player Questions & Answers
Look on the harness of your video player there will be a wire marked parking brake that has to be hooked to the brake so when the the brake is applied it supplies a ground, you can also ground that wire and you should get a picture.
Power Acoustik... | Answered on Aug 20, 2010
Check that the contacts of the button are not bridged inside.
Power Acoustik... | Answered on Apr 12, 2010
you should check the speakers next. did the speakers work prior to installing the radio? check the wire harness used to connect the radio to the car speakers that is behind the panel and make sure everything is connected correctly. please rate me if this helps. thanks and good luck!
Power Acoustik... | Answered on Sep 18, 2009
  • Smart Control enables select Mobile 8 models to communicate with the media player of most Smartphones and tablets
  • Smart Control sends playback commands by the AUX cable connected to the headphone output of your smart device
  • Control track selection, play/pause, and even answer incoming calls. AUX cable included. Variable Subwoofer Pre-Amp Output
  • Play audio, video, and picture files through Mobile 8 from DVD, CD, or 32GB SD/USB flash drive. Supports MP3 & WAV audio files & MP4 video files, and JPG pictures.
  • Safely make and receive hands-free phone calls, scroll contacts lists, and stream MP3's via A2DP from your enabled Smartphone. Most Bluetooth enabled Smartphones seamlessly pair
Power Acoustik... | Answered on Apr 17, 2020
MP4 is a codec that is not compatible with this DVD player. Your DVD player will play store bought DVDs just fine. Please read the specifications in the owners manual to see what codecs are compatible with your player.
Power Acoustik... | Answered on Nov 28, 2019
Okay I am assuming that you are referring to a USB thumb drive aka memory stick which contains mp3, wma (YOUR STEREO ONLY PLAYS MP3 AND WMA VIA USB NOTHING ELSE MANUAL SAYS) audio tracks and a certain specific format (formatting is done on computer, windows and different types of formats are supported on different devices). NTFS, fat32, exfat. Typically I think they like fat32 before but I have had all of my drives formatted for NTFS on newer equipment and had no issue with it. Um since you checked the drive and its working it's probably not that. It could be the connector on your stereo there. But if its new it's probably a formatting/compaitbility issue with the stereo. Heres the manual http://www.poweracoustik.com/pa2012/manuals/PD-710-T.pdf Also this stereo is a really cheap brand so they don't work as well and dont have that great of support. A Google search of that an similar stereos from them came up with several issues. There is very little USB power coming from that port so it's probably only enough power to connect a thumb drive. Some people have cables connecting to other devices and that is probably not going to work. I would get a different usb stick reformat it on the computer and copy some mp3's over.
Power Acoustik... | Answered on Nov 01, 2019
It may connect to another if receiver, if you have a second screen in the back of the vehicle you can control the unit from there.
Power Acoustik... | Answered on Jul 12, 2019
Search google for a schematic should be able to find one. I repair amps. Marks Car Audio & Amp repair
e-mail skinnman33 @gmail.com I can be reached at 727-266-6398 Let me know
Power Acoustik... | Answered on Apr 01, 2019
It depends on how many channels are on the Amp. If it's a 2 channel you can bridge it using the positive on one channel and use the negative on the other channel. The Amp will give the sub more power bridging the sub.
Power Acoustik... | Answered on Mar 10, 2019
Power Acoustik PADVD-610 Car DVD Player Logo
6 questions posted
Top Power Acoustik Car Audio & Video Experts
Marvin
Marvin
Professor_V
Professor_V
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Power Acoustik Car Audio & Video
Most Popular Question
get sound
  • Car Audio & Video
