I suggest taking a look at the manual here which requires a like or a tweet to view.
Hampton Bay Lighting Manuals
They are very good also at locating manuals that are not listed if you just a comment specifying what you need.
Possible that the logic control within the fan unit is defective if is seems to switch on both. For a start you can try to clean the remote pads to confirm if the pads are accidentally contacting when pressed for one function. If dimmer works then the selection mode could be the culprit.
Hey there, how are you? Can you post the model of the Hampton Bay fan that you have?
We will be able to help you better that way.
If you aren't sure what model of Hampton Bay fan that you have, please check this article for more details which describes how to find the model of your fan. Once you figure that out, please post it here and we'll help you:
https://hampton-ceilingfans.com/hampton-bay-ceiling-fan-troubleshooting/how-do-i-find-my-ceiling-fan-model/
They are just a low-end fan for Home Depot. The Hunters in Home Depot are also low-end. I personally would never buy Hampton Bay. Did you ever notice that the fan problems on here are mostly Hampton Bay, Harbour Breeze & Hunter?
You may have a stuck button so it is operating a signal all the time
A CR2032 is better.
Is a CR2025 the same as a CR2032?
For as long as either fits in the battery compartment, the CR2025 and CR2032 may be used interchangeably with minimal effect although the CR2032 would probably last slightly longer simply because it has a higher capacity (mAh).
