20 Most Recent Casablanca Fan Panama II 50" Ceiling Questions & Answers
The fan button on my Casablanca inteletouch swich will not turn on the fan. The light button works but I have to use the power button to turn on the fan which then turns on both the light and the fan.
There are two source wires coming out of that unit. One is for the fan the other is for the light. It appears from your descriptions that the issue is related to a wiring issue.
3/7/2018 1:56:57 AM • Casablanca Fan... • Answered on Mar 07, 2018
I have three casablanca fans in three rooms. An electrician installing electrical outlets, in the attic says he only accessed the main power line. However, all three fans suddenly malfuctioned in the
Are the fans all on one main line just for the fans and are they plugged into a GFI receptacle. If so you may have to reset the GFi or maybe your electrical box needs to be reset.
6/12/2017 3:48:33 PM • Casablanca Fan... • Answered on Jun 12, 2017
2answers
How do I change the
I'm most familiar with the w-32 control interface, but I bet you mean W-82, instead of W-85.
I am pretty sure since the W-82 uses RF signals that there are a set of dip switches on the side or rear of the control and a set on the fan as well. I pulled up the Operation manual for W-82 here for you, but it does not say how to change the channel on it. I was un able to locate the actual owners manual for the Panama II with W-82 as it was a very- short lived control, only made for about 6 months from what I understand. Does your fan have the XTR200 motor or the XLP-2000?
http://www.casablancafanrepair.com/HTMLFiles/instructionmanuals/Chapter23/IT2OperationHtml/IT2OperationP1.htm
11/10/2015 8:43:19 PM • Casablanca Fan... • Answered on Nov 10, 2015
3answers
I have a Casablanca Panama
There are different parts that might became bad and cause your problem like relay contact, starting capacitor, running capacitor. However all these parts are included in one unit the PCB printed circuit board or electronic board? So you need to replace this parts in attached link is also called RMM.
We have here below a link with service manual for the fan at which on the bottom you will find the parts diagram and parts list. You should try to confirm the part code for your model with Casablanca service department before confirmation of order.
Also please note that you will need a little experience with electronics before proceeding with above operation.
http://www.casablancafanrepair.com/HTMLFiles/do_it_yourself/InteliTouchCommonRep/ConversionKit.pdf
11/10/2015 7:34:42 PM • Casablanca Fan... • Answered on Nov 10, 2015
3answers
Casablanca fan only runs at highest speed
When I turn on any of the fan speeds fan does not come on. When I remove the blades and turn on the ceiling fan on and give it a push the fan stays running. What could it be?
6/22/2013 9:13:24 PM • Casablanca Fan... • Answered on Jun 22, 2013
0answers
The Intelitouch wall control operation is
Your control is malfunctioning. If the fan will sometimes operate normally, it is not a problem with the board in the fan. The replacement control is $50~ through Casablanca, but you can find them on ebay for half that cost, or less. Depending on your model of fan you may have the W-32 control, or the W-33. Most likely you have the W-32, but, reply with the model # and I'll let you know which control you have.
Thanks
4/1/2010 4:34:08 PM • Casablanca Fan... • Answered on Apr 01, 2010
Casablanca fan light works with remote but fan does not respond
Check white black power wire nuts or any wire nuts, to make sure the wires are all connected also cuz its wireless maybe check the yellow, gary, pink, red plug in's.
1/16/2023 8:01:13 PM • Casablanca Fan... • Answered on Jan 16, 2023
2answers
Casablanca stealth fan scraping noise
center of blade bracket mounts scrapping fan housing. Grasp blades and wiggle or shake them to make sure their not cockeyed. Turn it on then to check it.
8/23/2021 3:00:25 PM • Casablanca Fan... • Answered on Aug 23, 2021
I bought a used cascade 40" tower fan. it ran for a couple of hours and when I press the power button it wouldnt turn off so I unplugged it. now it wont turn on.
the switch is broken, so get the Fan repaired or replace the switch, with cord AC remove from the WALL AC power JACK.
6/9/2019 11:56:19 AM • Casablanca Fan... • Answered on Jun 09, 2019
I have oscillating fan was working and stop.I replace both capacitor.I have power to the motor but motor not work. My question is, where I cant find the new motor to buy? just the electric motor.
perhaps it may be a better choice to replace it. The cost of a motor if you could find one will exceed the value of fan.
11/21/2018 2:28:30 PM • Casablanca Fan... • Answered on Nov 21, 2018
Casablanca Fan Panama II 50" Ceiling Logo
14 questions posted
Top Casablanca Fan Dryers Experts
 Jack Jr
Jack Jr
Marvin
Marvin
Paul Bade
Are you a Casablanca Fan Dryer Expert? Answer questions, earn points and help others
View Most Popular
  • Casablanca Fan Dryers
Most Popular Question
casablanca fan only runs highest speed
  • Dryers
