20 Most Recent OnDemand Nova Development Invoices and Estimates Pro (GB0U3C0GN0000NE066) for PC Questions & Answers
The easiest solution to this problem is to run this program in Virtual PC, XP Mode. Here is the link for the download: http://www.microsoft.com/windows/virtual-pc/download.aspx . Invoices and Estimates Pro now works perfectly for me. Another solution is to download another PDF writer to your hard drive. Instead of choosing "create PDF" or "email" for your document, choose "print", select your new PDF writer, and then save the document to a file OUTSIDE the program. You can then access the file outside the program, print it or email, whatever you need to do with it. Both of these solutions fixed my "error code 8" problem, or at least made the software usable for me. The techs at Nova told me there was no solution to my problem.
OnDemand Nova... | Answered on May 27, 2014
Hi. Are you getting eny error messages on your screen?
OnDemand Nova... | Answered on Oct 27, 2010
As far as i know this program you are better off if you trow it away, or return it to the company. Good luck
OnDemand Nova... | Answered on Oct 19, 2010
Be carfull because it looks to me that this soft ware has been designed for xp. only
If you have purchased your software. and it says windows vista compatible it is wrong. it is not. and it will not work. Returnet to the store . if you can. ..
instal the acrobat reader the asociate the .pdf file with it in your program.
OnDemand Nova... | Answered on Dec 01, 2009
If that thing is crapping you up, then you've got to reformat it and install a fresh copy of operating system of your choice compatible to your computer. If you don't have any OS to install or probably you want it the way it was, your choice is to delete the folder/directory of the software you want to remove, which is usually located in C:\Program Files. The problem with this approach is if one of any files you deleted is a shared one, the program dependent on it will not be able to start properly and much worse if you delete a different folder or directory. Make sure you permanently delete it and not like just moving it to your recycle bin. If space is really you're concern, you have an option to purchase a brand new one with large capacity supported by your old system - install it with a new OS & applications and turn your old hard disk into secondary drive. Then transfer your documents to your new one. This strategy will ease you of pleading for more spaces.
OnDemand Nova... | Answered on Apr 04, 2007
Refer the page for the information to Fix problems with On Demand:
http://help.sky.com/tv/using-on-demand/fix-problems-with-on-demand
Computers &... | Answered on Nov 19, 2013
Locate the battery, remove the battery, replace the battery.
Computers &... | Answered 20 hours ago
Yes they are. Printers are one of the most common types of output devices but they can also be considered input devices because of the multi-function printers that include scanners and copiers.
Computers &... | Answered 21 hours ago
On what we all wonder. ............
Computers &... | Answered 22 hours ago
Can you logon to your computer in normal mode or only in Safe mode?
This would be the best way to run Chkdsk:
1. Disable any security software before attempting to upgrade or do a clean install.
2. Make sure your computer is updated (devices and applications)
3. Disconnect any external devices before installing.
4. Check your hard disk for any errors:
Click Start
Type: CMD, from the results, right click CMD
Click 'Run as Administrator'
At the Command Prompt, type: chkdsk /r /f
When you restart your system, your computer will be scanned for errors and attempts will be made to correct them.
There are other fleshed-out ways to run CHKDSK in the following article:
Quick Fix: CHKDSK Cannot Open Volume for Direct Access Error
1. Update drivers, BIOS or Windows of your PC.
2. Run SFC
3. Run DISM
It's tricky to pin down a panacea for this problem since the causes of it vary. You can check out this article to read a more comprehensive and detailed list of solutions:
Fix: Thread Stuck in Device Driver Error [16 Solutions]
Computers &... | Answered 23 hours ago
OnDemand Nova Development Invoices and Estimates Pro (GB0U3C0GN0000NE066) for PC Logo
24 questions posted
Top OnDemand Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you an OnDemand Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • OnDemand Computers & Internet
Most Popular Question
configure pdf
  • Computers & Internet
