20 Most Recent Toshiba Equium 2000 (PV1065E0-011FR) PC Desktop Questions & Answers
This error is not the same as a CMOS Checksum Error, which refers to corrupted values of the CMOS settings, the ones you set through the BIOS setup program. This error means the contents of the BIOS code itself are damaged.
The BIOS ROM chip on the motherboard is probably faulty. It could also be another component on the motherboard.
You should make sure that all of the BIOS settings in the system are correct, by rebooting the system, going into BIOS setup and double-checking all the values (hopefully against a recent
If you have reset the CMOS memory you need to go into the BIOS setup screen and reconfigure the BIOS. To do that you need to press a key while the computer is booting. Usually F2 but can be other keys. It should tell you on the bottom of the first screen which key to press to enter BIOS setup.
If you don't know the settings the should be one for optimal defaults - use that one. You will also need to reset the time and date.
Save, Exit and re-boot and everything should then work.
During the boot process you will see on the screen a certain key to press to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
You will also need to set the time and date
In the main or system setup screen you should be able to see the date and time Using your arrow keys navigate to the date and change the date. Once highlighted on the month, day, or year, press your arrow keys or your page up / page down keys to change the date.
hope this helps you
Toshiba Equium... | Answered on Nov 18, 2011
It looks like the screen inverter has failed. It is repairable, but check the cost of repair against the cost of replacement to see if its viable.
It's a component on a circuit board which has died.
You've not lost your information, that is still on your PC, a separate unit.
But what I would suggest is, when you've got a screen sorted out, you back up your information. I would back up Music, Photo's, Movies and Documents you need to keep to DVD's. Then you've got the for years to come and they're not going to suffer a mechanical failure.
Toshiba Equium... | Answered on Jul 19, 2010
Shouldn't matter so long as your computer uses usb 2.0. If it is using or only capable of 1.1 then you just might want to consider a new computer. But to tell you the truth never noticed much difference between 2.0 and 1.1 on a webcam. Hope this helps
Toshiba Equium... | Answered on Jun 20, 2010
check bios settings and enable kboard usb settings is ok, save to cmos and reboot
Toshiba Equium... | Answered on Feb 19, 2010
When you install your operating system it will load your mouse and keyboard when you restart your computer.It will set up your hardware and install your drivers as it installs your operating system. Hope this helps--Ken
Toshiba Equium... | Answered on Dec 07, 2009
use a PS2 keyboard/mouse
if they work fine then there is problem with your wireless equiment keyboard/mouse having some signal interfearance from some other equipment like you mobile phone etc...
If you spill drinks on a keyboard, something is bound to break, and apparantly only the O key did... The only way to fix it is to get a new keyboard, I'm sorry. I hope this helps, Yannick.
Toshiba Equium... | Answered on Jun 09, 2009
are you able to start in safe mode?
if you can good,then after that you look for what ever you added last and remove it.
Toshiba Equium... | Answered on Oct 24, 2016
it might be just letting you no there is no battry connected,try putting battery back and see what happens.
Hi, there are usualy good videos on you tube for everything
Toshiba Equium... | Answered on Jun 10, 2014
Removal of a drive is easy on the bottom of the laptop one or two screws hold the drive in place taking the drive screws will release the drive for desktops open the side of ur PC and some drive screws will be holding the drive in place removing them will let u remove the drive for non-screws tabs hold the drive in place pressing the tab in or out should let u remove the drive
Toshiba Equium... | Answered on Apr 26, 2014
System restore will not do what your asking.
However there is a way but you will need a Installation cd Assume you have Windows XP
Then you need to borrow or buy a Windows XP Home Edition or Pro
You can buy one used from Ebay.
There are two options !.Repair install this will save all files/data on your hard drive.
Follow these instructions to Repair install.
Boot the computer using the XP CD.
You may need to change the boot order in the system BIOS so the CD boots before the hard drive.
Check your system documentation for steps to access the BIOS and change the boot order.
When you see the "Welcome To Setup" screen, you will see the options below
This portion of the Setup program prepares Microsoft
Windows XP to run on your computer:
To setup Windows XP now, press ENTER.
To repair a Windows XP installation using Recovery Console, press R.
To quit Setup without installing Windows XP, press F3.
Press Enter to start the Windows Setup.
Do not choose "To repair a Windows XP installation using the Recovery Console, press R", (you Do Not want to load Recovery Console).
I repeat, do not choose "To repair a Windows XP installation using the Recovery Console, press R".
Accept the License Agreement and Windows will search for existing Windows installations.
Select the XP installation you want to repair from the list and press R to start the repair.
If Repair is not one of the options, END setup.
After the reboot
Setup will copy the necessary files to the hard drive and reboot.
Do not press any key to boot from CD when the message appears.
Setup will continue as if it were doing a clean install, but your applications and settings will remain intact.
2. If you want to do a clean install that will completely wipe your hard drive clean then follow the instructions from this site http://www.winsupersite.com/showcase/win...
You will then need to reload all Microsoft Windows Updates and find all other drivers and software from http://uk.computers.toshiba-europe.com/c...
Then wham bam you should be back in business.
hope this helps
Toshiba Equium... | Answered on Sep 28, 2012
The cable (Wire) stays attached to the Power Button Board,
http://www.ebay.co.uk/itm/2270-POWER-SWITCH-BUTTON-TOSHIBA-EQUIUM-A100-/221111621689?pt=UK_Computing_Other_Computing_Networking&hash=item337b479839
No, I'm wrong? The Flat Flex Cable (FFC) does come out of a ZIF connector on the Power Button Board?
You may wind up buying the Power Button Board, and Flat Flex Cable, then.
Or you may find a 'Mom and Pop' computer store, that can repair the cable.
Regards,
joecoolvette
Toshiba Equium... | Answered on Aug 21, 2012
U need cd key.check my previous solution
Toshiba... | Answered on Dec 30, 2020
check your hard drive. is it connected or not. mostly it is observed that boot able device is not connected with computer or laptop. please check it.
Toshiba... | Answered on Nov 27, 2020
Toshiba Equium 2000 (PV1065E0-011FR) PC Desktop Logo
12 questions posted
Top Toshiba Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Equium Toshiba
  • Equium Toshiba
Most Popular Question
black screen
  • Computers & Internet
