20 Most Recent Dell Dimension E521 PC Desktop Questions & Answers
2answers
Dvd burner not detected
Sorry, but that model is not a DVD writer. It can only write and rewrite CD's. It can only read DVD's.
Here is a page with specs:
Sony CRX310S Specs
Note under DVD>Write DVD it says N/A. (Not applicable.)
5/8/2019 3:16:05 AM • Dell Dimension... • Answered on May 08, 2019
Inspiron 530 goes into a
Hello Tony! Simply test. Switch to High Performance in your Power Settings and reboot. Tell us if that helps.
10/2/2018 11:54:01 AM • Dell Dimension... • Answered on Oct 02, 2018
Using Windows Vista on Dell Dimension Desktop:
try method 5 listed on this site: https://support.microsoft.com/en-us/help/314060/your-cd-or-dvd-drive-is-not-recognized-by-windows-or-other-programs Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/larry_1fe25e09c54eece2
5/23/2017 2:24:57 AM • Dell Dimension... • Answered on May 23, 2017
How to download pictures from my memory card to my dell ?
insert the memory card in memory card reader and connect it to the USB port and select the photos ctrl + c and then ctrl + V where u want to paste it
12/27/2016 11:50:33 AM • Dell Dimension... • Answered on Dec 27, 2016
No sound thru HDMI PC to TV. The HDMI Output is the default device. When I test error msg says device is in use by another app. No other apps running. Can you help me figure this out?
You can try going into the properties dialog of the audio device, under the advanced tab (the same place you set it to the default device) and uncheck the "allow applications to take exclusive control of this device" box. Restarting the computer after doing this wouldn't be a bad idea.
7/29/2016 12:48:30 AM • Dell Dimension... • Answered on Jul 29, 2016
0answers
"Please insert a writable disc into drive E:."
Windows thinks E: is a CD/DVD drive ...this maybe becasue it can't understand the USB stick 'format' (especially if it's come from a Tablet/smart phone) Try a different USB stick (they are cheap enough these day to just throw away when they start acting up)
3/30/2016 9:43:48 AM • Dell Dimension... • Answered on Mar 30, 2016
2answers
How to erased password
I'm sorry to say you'll probably have to take it to a tech
3/22/2016 3:55:42 AM • Dell Dimension... • Answered on Mar 22, 2016
Dell Ispirim will not boot after power failure. Fans run, mb light on. Dtartup buttom amber.
A steady or Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
1/3/2015 12:09:02 AM • Dell Dimension... • Answered on Jan 03, 2015
Cds wont work on e521 with vista
You're CD drive is defective. See if the CD works in you're DVD player. If so then the CD drive in you're computer is defective.
1/2/2015 11:46:40 PM • Dell Dimension... • Answered on Jan 02, 2015
The motherboard components are hot, an cpu fan is on high speed.
First check make sure all vents are clear. If unit is under warranty send it in to Dell. If not you can try a few things. First unplug unit then remove the access side panel and check to see how filthy it is. If just light dust you can use a lint free cloth or a Qtip and lightly dust it out. Do not use any form of vacuum or compressed air as these can damage sensitive areas. If there is a bit of build up (residue) lightly dampen cloth or Qtip. DO NOT SOAK. Remove fan carefully as to sometimes they can be secured in ways we don't see. Take the a Qtip dampened and remove the build up on the fan. Allow to air dry a little to remove any left over liquid before reconnecting and plugging back in. Build up inside a unit can cause it to overheat and thus the fan(s) tend to work harder to try and reduce the temp A desktop temp should not exceed 121 degree Fahrenheit. If this does not solve the problem I would first check with dell as to how to slow the fan down... I have tried a program called speedfan but never could under stand how to use it. Worth a shot maybe, Last would be replace the fans all together and maybe invest in a separate cooling system for inside your unit. *If your unit accumulates a lot od build up inside cover the outside of the vents with a dryer sheet. This will act as a filter. cut it to the size of the vent leaving enough to tape it the the unit. Do this all around the unit with the exception of the power supply. Hope this helps. I have a Inspiron 560 that was doing the same thing ended up the fan was busted but that was due to build up and not having cleaned it in quite sometime.
10/10/2014 12:14:52 PM • Dell Dimension... • Answered on Oct 10, 2014
Where is the location and how to remove the hard drive for Dell Dimension E521
Here is a link to Dell where you can find your model. http://www.dell.com/support/home/us/en/19
10/9/2014 9:54:02 PM • Dell Dimension... • Answered on Oct 09, 2014
Numbers 1, 2 and 3 are green on front of dell dimension e521
psu or short on the pcb,try reinstalling cpu and press well that ram module into place,sometimes it just doesnt make contact.
8/3/2014 6:00:41 PM • Dell Dimension... • Answered on Aug 03, 2014
Keypad numeric unlock
What about it??? you don't tell us anything..... you only have a subject line with out any explanation of what your problem is. If you dont supply any more information, your problem will remain on the unanswered list FOREVER.
8/1/2014 5:44:54 PM • Dell Dimension... • Answered on Aug 01, 2014
MY DEL dimension e521 fan is making alot of noise, is there a way to solve this?
First you need to see what kind of noise is that, does it sound like a squeal noise and the fan wants to stop? or is it like the fan is going super fast? If its the first one the you gonna need to replace your fan, now if its the second one your processor its overheating and that could be for many different reasons.
6/8/2014 12:55:08 PM • Dell Dimension... • Answered on Jun 08, 2014
How do i reformat my dell dimension e521 computer
The easiest way is to boot from the Windows installation CD and select format hard drive.
3/22/2014 1:50:36 AM • Dell Dimension... • Answered on Mar 22, 2014
My dell 521 just blinks when I turn on
A Blinking Amber or Yellow power button means that the power supply is receiving power from the source but is unable to properly distribute it to the components. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
3/22/2014 1:46:58 AM • Dell Dimension... • Answered on Mar 22, 2014
0answers
Dell Dimension E521 PC Desktop Logo
224 questions posted
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
View Most Popular
Dimension Dell
  • Dimension Dell
Most Popular Question
forgot adm password system password
  • Computers & Internet
