20 Most Recent Profile CL1200 Car Audio Amplifier Questions & Answers
Car Amp keeps blowing fuses
The reason why fuses blow is that the current is too much. Is the fuse rating according to the specs ? If yes then ... One or more output power transistor (or audio power IC) may be shorted. have it checked before replacing another fuse as this might cause more damage.
5/25/2007 2:58:26 PM • Profile CL1200... • Answered on May 25, 2007
How do I connect a DVC (4 ohms each) single subwoofer to a Profile California 2600 amp (2 ch. with bridging) for best match?
As long as you are using only one rca signal input, and physically splitting it with a splitter or even just leaving only one channel connected, and the other empty, wire each coil to each of the amp channels. There won't be stereo separation (of your woofer). It should be ok. Better than 2ohm bridged load, or 8 ohm. You will lose output at 8 ohms, but your amp will never overheat and your soeakers will last forever. Lol.
2/13/2015 7:47:05 PM • Profile Car... • Answered on Feb 13, 2015
0answers
2answers
Does the profile mp9300 car
Yes, the mp9300 has axillary in. It has a pair of traditional RCA red/whites coming out of the back of the stereo.
I am assuming you are wanting to plug an iPod or Zune type device directly into it. To do this you would need to pull out the stereo to access the RCA inputs and add an RCA to 3.5mm adapter like this one.These are commonly found at radio shack, best buy, walmart, or any electronics store for typically under $5.
After you install the adapter you can simply route it behind the stereo and out the back underneath a panel in the car so you can access it.
I have included a diagram of the wiring to help you out should you chose to decide to do this yourself.
Good luck!!
5/6/2011 8:05:20 PM • Profile Car... • Answered on May 06, 2011
Help with code radio for my nissan pp2787h
The radio code is a security feature that's meant to deter theft, and it's unique to each vehicle. If you've lost your code, you'll need to contact a Nissan dealership or service center and provide proof of ownership. They should be able to help you retrieve the code. Please do not attempt to use codes from the internet as incorrect attempts may lock your radio.
4/18/2024 1:48:21 PM • Car Audio &... • Answered on Apr 18, 2024
Gathers car audio manual
How to change language to english for Honda Odyssey 2021 Gathers Radio Player
4/16/2024 4:19:39 PM • Car Audio &... • Answered on Apr 16, 2024
Is there bluetooth on nsdn-w59
I have the same radio now with no Bluetooth am trying to get Bluetooth on it too without having to buy another radio. Please help.
3/26/2024 3:40:48 AM • Car Audio &... • Answered on Mar 26, 2024
2answers
No sound from wireless headphones in a toyota sienna
First thing to do is check to make sure that the batteries are properly charged.
Second, make sure that you have a clear line-of-site to the IR transmitter. Infrared (IR) works the same way that your TVs remote control works - if the signal is blocked, then you will not hear any sound.
Third, make sure that you are in the rear seat of the vehicle when listening to the sound. The IR transmitter only transmits to the rear seat, so you will not hear any sound if you are sitting in the front seats. This is a common problem that i see.
Lastly, make sure that the heapdhones you purchased are compatible with your 2006 2007 2008 2009 or 2010 Toyota Sienna. Remember that some older models require RF headphones, not IR headphones. I checked http://www.audiovideo2go.com for compatibility before I purchased my headphones. They have a useful listing of all the headphones and models of vehicles they are compatible with.
3/19/2024 7:56:21 PM • Car Audio &... • Answered on Mar 19, 2024
What demo mode the code for 4.91
'make model (what is is)' as first 3 words in all questions. https://www.google.com/search?q=demo+mode+the+code+for+4.91 ..
3/19/2024 2:42:25 AM • Car Audio &... • Answered on Mar 19, 2024
Xplore Amp 5553. How many watts RMS and impedance loads.
Unfortunately, no one knows or is telling. Companies rarely state power in RMS because Peak Power is a much more impressive. 1000 watt amp, 200 watts RMS x 2 channels at 8 ohms. Look for a sticker on the unit. https://www.google.com/search?q=Xplore+Amp+5553 ..
3/19/2024 12:23:13 AM • Car Audio &... • Answered on Mar 19, 2024
Carrozzeria serial abm760p57 RADIO ON ??
What is your question? Thank you.
2/28/2024 7:23:47 AM • Car Audio &... • Answered on Feb 28, 2024
2answers
I need the code
Your code is 1 3 6 3
2/25/2024 10:20:30 AM • Car Audio &... • Answered on Feb 25, 2024
6answers
Profile CL1200 Car Audio Amplifier Logo
2 questions posted
Top Profile Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Profile Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Profile Car Audio & Video
Most Popular Question
car amp keeps blowing fuses
  • Car Audio & Video
