20 Most Recent
Thermador SECD302BPSS Electric Double Oven Questions & Answers
F34 error
coolingfan/air flow issue on the upper oven
2/3/2015 1:36:34 AM •
Thermador...
Answered
on Feb 03, 2015
Thermador Built in oven scd302 not heating upper
Hi.
Problem is usually either temperature probe or heating element.
Grab a multimeter and set it on impedance (Ohms).
Remove first temperature probe and then heating element.
If either probe or element is reading open (ohms infinity), then replace the part.
If both probe and elements are not open, then the problem is either wiring or oven electronic control. The most common fault resulting in no heat is the temperature sensor located inside the oven cavity.
Regards.
Ginko
5/31/2011 8:04:32 PM •
Thermador...
Answered
on May 31, 2011
Error code F64 on lower
Hi, i found out from Thermador customer service that error code F64 means that the lower fan switch (located inside the bottom trim on the right side) is not being detected as closed. In my case, this was because the header (P4) on the Display panel had broken loose from the PC board and was no longer making contact. P4 is where the lower fan switch wires connect to the control boards (actually the display panel).
