20 Most Recent
Gestetner DSm735sp Printer Questions & Answers
Need a review on the Gestetner SDm735sp
I worked on this model for a couple years and honestly, it was hit and miss. I would visit some that were in immaculate condition despite having +100K clicks on the counter, then I would visit just as many that would have 20-30K that would be filthy from toner blowing and would jam frequently. As I recall, there was one exceptionally large design flaw in these that, when paper would jam, a tech would have to dismantle the paper feed side of the unit to be able to properly clear paper bits from around a sensor.
So...IF you are wanting to purchase this unit, I would suggest you do so on a trial basis so you can see which way the copier is going to fall. It really does seem like a 50/50 shot from my experiences. Oh and my experiences are from when the machine was first released. They may have made some retrofits or mods since then...it's been a little while since I've worked for Gestetner so I can't help out on any possible recent developments.
1/8/2010 7:16:21 PM •
Gestetner...
Answered
on Jan 08, 2010
How to put toner in the printer
Open the front cover .You will see a green leaver pointing downwards , lif te leaver to the upwards position on the left side underneath the toner you wil see a little green pin ,push it downwards to release the toner pull towards you , move the old bottel little bit backwards and lift , it will come out , remove the black turn off screw from the new toner and insert it with the end were you unscrewed the cap pointing towards you.push back the holder until it clicks , move the green handle downwards again and close the cover .
11/22/2007 5:48:52 PM •
Gestetner...
Answered
on Nov 22, 2007
How to delete a pre-programmed fax number
If all else has failed and you cannot change the settings or change the numbers in the program itself, often uninstalling and reinstalling the fax can correct the problem
8/16/2007 8:10:11 AM •
Gestetner...
Answered
on Aug 16, 2007
How would I identify faulty fault sensors in gestetner MP2501L copier and replace them?
You can't. As I said you need the service engineer with the laptop. These Office Machines are NOT consumer serviceable. They hook up the laptop with the Ricoh software and it interrogates the computer, the mainboard and everything on it. The error message you get is from the brains inside it..Original question and answerhttps://www.fixya.com/support/t29802178-am_posting_again_stripped_off_gestetner..
Am posting again. I stripped off gestetner MP2501L 8 times due to problem ' see instructions on right side to solve' but same. No paper inside. What is the actual problem.
Hello Christopher
Are you in the Philippines? I notice that your copier has changed from Ricoh to Gestetner? We are a North American website.
This is a commercial office machine, and from my experience of them is that on the right side you will see on the inside, a list of instructions for where to check for obstructions. It seems you have already done this 8 times! Frustrating! Try this;
Open the right side cover, unlatch all the bits at that side.
Open the straight pass door on the left side.
remove ALL the paper drawers.
Get a powerful flashlight, look in all the spaces you have just created, especially at the edges of drawers and paper pathways. You are looking for a tiny piece of paper that one of your employees carelessly left behind after a paper jam.The one I found was right at the back of the straight pass door. When a sensor is covered, it creates that message.
If that fails, Ricoh will have to come and attach their Laptop scan software to it which will tell which sensor is obstructed or has failed.
Sc 569 for ricoh mp 5500
sc 569 is the pressure roller contact sensor error Troubleshooting Procedures: 1. Check or replace the harness of the pressure roller contact sensor. 2. Replace the pressure roller contact sensor. 3. Replace the pressure roller contact motor
SC 569 Error code in MP 5500
Ink idling problem in gestetner dx 2330 copy printer
Hi Hope this helps.The metal gauze filter (see image) behind the input nipple on the drum unit may become blocked with congealed ink deposits causing the ink not to feed at full flow.Strip and clean the blocked gauze filter in the Ink Supply System.
