20 Most Recent Thermador SEC301 Electric Single Oven Questions & Answers
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
Thermador SEC301... | Answered on Jan 11, 2017
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Range-Stove-Oven/18---/Oven-won-t-turn-on-
Oven Won Turn on
the broil element
If you have the use and care manual, check to see if your unit has the option to change from farenheit to celcius. If so, make sure yours was not accidentally changed to celcius.
Thermador SEC301... | Answered on Sep 07, 2011
it sounds as if you have a tripped thermal cut out. This is accessed by removing the 5 or so screws on the black grate below the control panel and pulling the grate out. Somewhere in the middle towrds the front should be a little button wiht 2 wires hooked to it. make sure you have the power off to the oven, then reach in with a screwdriver or your hand if you can and push the little red buttton down untill it clicks. The cause for this to trip could be bent door hinges not allowing the door to close fully (common thermadore problem), bad door gasket especially in combination with running a self clean cycle, broiling with the door ajar, or a bad cooling fan (the one behind the electronics, not the one in the oven) Hope this helps.
Thermador SEC301... | Answered on Jun 25, 2007
There is four crimp connectors on the inside at the element. They can go open circuit. I would check them. There is an interna thermal fuse, when the element blows that usually goes too. Good luck
Thermador SEC301... | Answered on Jun 16, 2007
Cannot Read Display or See Temperature Thermador RDDS30
FixYourBoard.com repairs this failure and back their work with a two year warranty.
Thermador Ovens | Answered on Aug 08, 2019
Gave you an F? Give it a "Y" back!
Sensor panels cost more in parts and materials to replace than a new unit!
Thermador Ovens | Answered on Jun 24, 2019
Time to buy a new over bub... you don't want to blow your house up!
start from the beginning, how many circuit breakers did you turn off? how many did you turn back on after the repair?
Thermador Ovens | Answered on Jun 10, 2019
Thermador SEC301 Electric Single Oven Logo
15 questions posted
Top Thermador Ovens Experts
Marvin
Marvin
Ismael Rodriguez...
Charles Tidwell
Are you a Thermador Oven Expert? Answer questions, earn points and help others
View Most Popular
Thermador Ovens
  • Thermador Ovens
Most Popular Question
broiler element doesnt heat
  • Ovens
