20 Most Recent
HP DeskJet 840c InkJet Printer Questions & Answers
Blinking lights on my hp deskjet 840c printer
There should be some error .So you know how to remove the catridges just remove it n re insert it properly.If there are any paper jams try removing it also.and by the way if you haven't installed the drivers for HP deskjet this problem may arise.So make sure you ahve don this.Also this can be happened if the printer have some hardware problems.So none of this solutions are working its better to consult it with an expert.
I have an 12 year
Hi I think your printer has a parallel connector ( big D shaped socket with wire clips each end) on it if your pc also has a parallel plug get a parallel lead and install the drivers to use LPT1 this should remove the faulty USB plug from the problem
good luck Ian
Printer hp deskjet 840c blinking
Depends which red blinking light. I assume the red light is the resume light. The green light is the power light. If the Power
and the Resume
light are blinking alternately, then you have a paper jam somewhere in the printer. remove the paper jam and you should be fine.
My hp deskjet 840c is not printing, can you tell
this link will show you how you can properly clean your printer.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bud02948&tmp_task=useCategory&lc=en&dlc=en&cc=us&lang=en&product=59868
assuming that you are using windows 7 this link will show you how to check the ink levels
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?tmp_rule=23455&tmp_task=useCategory&lc=en&dlc=en&cc=us&lang=en&product=59868
Dont have disc
HERE is the direct download link form HP. just select your operating system and download the drivers and install from there. no CD needed.
Color cartridge #78 will not
Hello, if you lift the top cover there should be a little label with the correct ink cartridge numbers that you need to buy. I've got a Deskjet 845c, which is similar to your 840c, and the label shows 17 colour; 15 black. I suspect yours will be the same. No others will work as the printer was designed for those particular cartridges. They are still readily available in the shops or online. If you're in the UK try
www.inkrite.com
Regards
nicam49
