20 Most Recent
Canon PIXMA iX4000 InkJet Photo Printer Questions & Answers
Canon pixma IX4000 printer orange
Resetting Ink-Waste Overflow Counter Canon Pixma iP3000, iP4000, iP5000 Printers
- With the printer plugged in and powered off, press and hold the Resume/Cancel button, then press and hold the Power button. (DO NOT release the buttons. The LED light should be green to indicate that a function is selectable.).
- While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.).
- While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.).
- When the LED light is green, press the Resume/Cancel button 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.).
- Press the Power button. The LED lights in green, and the reset is performed. (When the operation completes, the printer returns to the menu selection mode automatically.).
- Press the power button to exit service mode.
Note: if you accidentally press the Resume/Cancel button more than 4 times in step 4 then just press the Resume/Cancel button at least 10 times and the printer will be returned to step 4 automatically
Canon printer ix4000 have error 5750 why have error like this?
Someone posted So, from my experience, If you received a Service Error 5750 Canon Ix4000 message then there is a97.5% chance that your computer has registry problems.
The Windows Service Error 5750 Canon Ix4000 are easy to repair. By downloading and running the registry repair tool RegCure Pro, you can quickly and effectively fix this problem and prevent others from occuring. Simply click the links below for your free download. Someone else said that they were told to go to a repair shop, and someone else said that it's an error code in a manual. My suggestion is to search online and try to do what costs the least money.
Canon ix4000 error 5c00
error [5C00] & Light Blinking 4 times = PURGE CAM SENSOR ERROR
you may need to replace :
- PURGE UNIT
- LOGIC BOARD ASSY
Not printing
when i send order to my printer ix4000 printer not response ,can not check ink level . when i make print test, the printer print but no result on the paper
Error 5750
open here, maybe help :D
http://translate.google.com/translate?hl=id&ie=UTF-8&u=http%3A%2F%2Fwww.startcopy.ru%2Fbbs1%2Fmsg%2F7549.htm%3F1&sl=ru&tl=en&history_state0=
[email protected]
