20 Most Recent Humminbird 561 Fishfinder Questions & Answers
Best precaution is an in-line fuse of a Slow Blow 5 amp near the battery or power distribution terminal.
Humminbird 561... | Answered on Apr 07, 2016
The signal loss is due to the transducer not in the water. Suggest remounting the Xducer an inch or 2 lower to be in water when you plane out at full throttle.
Sounds like main board fault. Check the battery voltage too. If it is less than normal, this kind of fault can occur. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Humminbird 561... | Answered on Jul 01, 2014
they have longer power cables at hummingbird call em order you one
Humminbird 561... | Answered on Dec 19, 2013
don't splice them bad bad bad call hummingbird order you a set of power cables
All electronics when they age the electrolytic capacitors dry up and need replacing, and you get aging solder joints that increase in resistance... this could be giving you false readings.
Humminbird 561... | Answered on Nov 30, 2013
Transducers usually have a 6 degree tilt down looking from the boat .
Humminbird 561... | Answered on Dec 31, 2012
If its under warranty, send it back. They will say you grounded it or hit log. If not, buy a new one. You can't fix them.
Humminbird... | Answered on Feb 26, 2020
You cant change time since is gps controlled. All you can do is to choose correct time zone For example NY should be GMT -5 hrs
Humminbird... | Answered on Sep 02, 2019
Remove the plug at the back and look for corrosion. Check you have power.
Try Mikes Reel Repair for repair.
Mikes Reel Repair is a certified Humminbird warranty and repair facility located in British Columbia, Canada. We accept new and old Humminbird sounders for repair, from all over the world.
While recent model years are easier to find parts for than older units, we still have some success in repairing some older sounders as well. Things we cannot repair on older units are broken cases, displays, keypads and such...if the parts are no longer available.
We don't have a fixed charge for repairs but you will find us very reasonable compared to the factory pricing. Need more info? Drop us a line on our Contact Us Page, or call us Toll Free 1-888-404-1119!
https://www.mikesreelrepair.com/humminbird-service-repairs
Humminbird... | Answered on Jul 20, 2019
Humminbird 561 Fishfinder Logo
18 questions posted
Top Humminbird Boating Experts
Mike
ray gallant
Are you a Humminbird Boating Expert? Answer questions, earn points and help others
View Most Popular
Humminbird Boating
  • Humminbird Boating
Most Popular Question
install transducer
  • Boating
