20 Most Recent
Samsung M8800 Pixon 8mp Gps Att T-mobile Samrtphone Questions & Answers
Samsung S9 turning Samsung Music app on by itself
This seems to be a known issue where the Samsung Music app starts randomly1. Here are a few steps you can try to resolve this issue:
Check if an app you downloaded is causing the problem: Start the phone in Safe Mode. If the problem does not occur in this mode, then you need to find out what app this is and uninstall it.
Wipe the cache partition of the phone from the recovery mode: This can often resolve issues with apps misbehaving.
Perform a factory reset: Please remember to backup your phone data before doing this. Once the reset is complete, do not install any apps in your phone yet. Try to check first if the issue still occurs.
Check Power Saving Mode: The power saving mode could interfere and block your music-streaming app if turned on.
If none of these steps work, it might be a good idea to contact Samsung's customer service for further assistance.
Why do samsung tab 10.1 when i put the sim card it goes out
- SIM Card Tray Issue: The SIM card tray might be damaged or not properly aligned. Ensure that you are inserting the SIM card into the tray correctly and that the tray is properly seated in the device.
- Incompatible SIM Card: The SIM card you're trying to use might not be compatible with the Samsung Tab 10.1. Ensure that you're using a SIM card that is supported by your device and is of the correct size (micro-SIM or nano-SIM).
- Dirty or Faulty SIM Card Contacts: Dust, dirt, or debris on the SIM card or SIM card tray contacts can prevent proper connectivity and cause the SIM card to eject. Clean the SIM card and the tray contacts with a soft cloth and reinsert the SIM card.
- SIM Card Slot Issue: There could be an issue with the SIM card slot itself. Inspect the slot for any physical damage or debris that may be causing the SIM card to eject. If you notice any damage, you may need to have the device repaired by a professional.
- Software Issue: Sometimes, software glitches or conflicts can cause the SIM card to eject unexpectedly. Try restarting your Samsung Tab 10.1 or performing a factory reset to see if the issue persists.
If none of the above steps resolve the issue and the SIM card continues to eject, it may indicate a hardware problem with your device. In this case, you may need to contact Samsung customer support or visit a certified repair center for further assistance.
Why is there 2 Apps on my samsung device, Phone 12.00KB Phone 12.45MB
Pode haver v?rios motivos pelos quais voc? tem dois aplicativos no seu dispositivo Samsung com tamanhos diferentes, mesmo que ambos estejam relacionados ao telefone. Aqui est?o algumas poss?veis explica??es:
1. **Atualiza??es do Sistema ou Operadora:** ?s vezes, as atualiza??es do sistema operacional ou da operadora podem resultar em duas vers?es do mesmo aplicativo. Uma pode ser a vers?o anterior que ainda est? no dispositivo, e a outra ? a vers?o mais recente.
2. **Pr?-instala??o e Atualiza??o:** Alguns dispositivos v?m com aplicativos pr?-instalados de f?brica, e esses aplicativos podem ser atualizados posteriormente atrav?s da loja de aplicativos, resultando em duas instala??es coexistentes.
3. **Armazenamento Local e na Nuvem:** Alguns aplicativos possuem a op??o de armazenar dados localmente no dispositivo ou na nuvem. Isso pode resultar em duas instala??es, uma para dados locais e outra para dados na nuvem.
4. **Configura??es Diferentes:** Dependendo das configura??es, um aplicativo pode ter duas instala??es separadas para lidar com diferentes contas ou configura??es.
Para resolver esse problema, voc? pode tentar o seguinte:
- Desinstalar a vers?o mais antiga ou menor do aplicativo, especialmente se voc? tiver certeza de que a vers?o mais recente ou maior ? funcional e atende ?s suas necessidades.
- Verifique se ambos os aplicativos s?o, de fato, vers?es diferentes do mesmo aplicativo. ?s vezes, nomes semelhantes podem ser enganosos.
Lembre-se de que o processo espec?fico pode variar dependendo do modelo do seu dispositivo Samsung e da vers?o do sistema operacional. Se voc? tiver d?vidas ou n?o se sentir confort?vel fazendo essas altera??es, ? sempre urgente consultar a assist?ncia do suporte t?cnico do fabricante ou do seu provedor de servi?os.
How do i remove lock screen on my samsung j4 core,
HardReset.info:
How to hard reset SAMSUNG Galaxy J4 (2018)
- Hold down the Power key for a few seconds to switch off the device.
- Then start pressing Volume Up and Power buttons together for a couple of seconds.
- Let go of all buttons when you see the SAMSUNG logo.
- If the Android Robot with "No command" image pops up you should tap on the screen.
- In this menu choose "wipe data/factory reset" by using Volume keys to navigate and the Power button to accept it.
- After that select "Yes -- delete all user data" with the Power key.
- When Recovery Mode appears select "reboot system now" by using the Power button.
