20 Most Recent Samsung GT-P6200 Galaxy Tab 7.0 Plus 16GB, 3G, 3MP, 1.2GHz dual-core, 3.2 Honeycomb 7-Inch Unlocked World Tablet PC Black Questions & Answers
usually if the contacts are not saved on your device it will display that. you can follow this guide on how to save your contacts.
http://www.samsung.com/uk/support/skp/faq/1057753
and other faqs are here
http://www.samsung.com/uk/support/model/GT-P6200UWAXEU
Samsung GT-P6200... | Answered on Apr 08, 2016
hard reset by recovery options,data will be lost
Samsung GT-P6200... | Answered on Dec 22, 2014
Let's start with the most common Hard Reset methods and go from there:
Note: the different types of methods are numbered, method 1, method 2, method 3, etc.
1. When the phone is powered off, press and hold the Volume Up and the Volume Down keys both at the same time, then press and hold the Power key until a test screen that shows some available options appears, usually takes about 15-20 seconds. When that screen pops up you can let go of the keys.
Press the Volume Down key to navigate down through the options until it highlightsFACTORY RESET then press the Power key to select it.
2. Power the phone off all the way, press and hold the Volume Down key and press than release the Power key, still holding the volume down key for about 10-15 seconds. When you see some additional options pop up on the screen you can let go of the keys.
Press the Volume Down key to navigate down through the options until it highlights the reset option; it usually says FACTORY RESET, then press the Power key to make the selection.
3. While powered off, press and hold the Home key, while continuing to hold the home key power the device on by pressing the Power key.
Once the Android Recovery screen appears release the Home key, then while on the Android Recovery screen, press the Volume Up and Volume Down keys both at the same time.
If/when you're on the Android System Recovery screen release all the keys, and then use the Volume down key to navigate down to the "wipe date/factory reset" option. Once it's highlighted press the Power key to select it.
Once you see the "Confirm wipe of all user data?" Press the Volume down key to highlight "Yes-delete all user data", then press the Power key to select it.
4. Power the device off, then press and hold the Home key and press and release thePower key (while still holding the Home key).
From the Android Recovery screen, press the Search key.
Tap to select wipe data/factory reset then select Ok (located in the lower left of the screen). Note: if screen is not responsive use the Volume keys to scroll and theCamera key to select.
Select Yes - delete all user data, and then select OK (again lower left).
Select "reboot system now" and press OK.
5. This is becoming a common hard reset method and can be used to factory reset Samsung's more recent Galaxy smartphones such as the Samsung Galaxy S III, the Samsung Galaxy S4, the S5, the Samsung Galaxy Note the Note II and Note 3, etc.
With the device powered off press and hold the Volume Up key the Home key and the Power key all at the same time.
When the phone vibrates (or you see the GALAXY Logo) release the Power key but continue to hold the Volume Up and Home key.
Continue holding the Volume up and Home key until the "Android system recovery" screen appears.
Use the Volume buttons to scroll to and highlight the "wipe data/factory reset" option, and then use the Power key to make the selection.
Once the factory reset is finished you may use the Volume and Power keys to highlight and select the "Reboot system now" option and the hard reset will be complete and your cell phone will be nice and squeaky clean.
6. Here is an alternate reset for a Motorola Atrix still running on the 2.2 Android OS...
While the phones power is off, press and hold the Volume down button and press and release the power button (note: if it doesn't work after all the steps listed try holding down the power button along with the volume down button in this first step).
A "Fastboot" screen should pop up, press the Volume down key to cycle through the choices until you get to "Android Recovery", then press the Volume up key.
Wait for the "triangle!/Android". Once it pops up you'll need to tap on the bottom right corner of the screen (note: it may take a few attempts). A menu should pop up.
Tap on "wipe data/factory reset", and then tap OK. Another confirmation screen will appear. Tap Yes and then OK.
After the data is cleared the "reboot system now" option should appear and is highlighted by Default. Tap OK.
Note: this type of reset is common on the 2.2 (Froyo) before the tech geeks wised up and removed the need to use the touch screen.
7. This reset is for the same phone, the Motorola Atrix, but one that's running on the 2.3 OS.
Power off the phone, press and hold the Volume down button and Power button simultaneously while powering on the unit.
The "Fastboot" screen should pop up. When it does press the Volume down key to cycle through the choices until you get to "Android Recovery", and then press theVolume up key to boot in this mode.
Wait for the "triangle!/Android" screen to pop up. Once it does press both theVolume up and Volume down keys simultaneously. A Recovery Menu should pop up.
Tap on the Volume down key until "wipe data/factory reset" is highlighted, and then tap the Power button. Another Confirmation screen will come up. Tap on the Volume down key until it highlights "Yes" and then tap the Power button to make the selection.
After it's done make sure "reboot system now" is highlighted and then tap thePower button.
In this method you don't have to use the touch screen any more. So let's say your touch screen isn't responding therefore you can't navigate the phone or go into your settings and do a regular factory data reset. Well now on the 2.3 there is hope. Just power off the phone and perform these steps and the reset should go through.
8. Here is a hard reset for a Sharp Android Smartphone.
While the device is off, hold the Sym button (it's located on the keyboard) and thePower button simultaneously.
Once the Android boot screen appears highlight the Wipe data/factory reset option by using the volume buttons. Then use the Return key (on the keyboard) to actually make the selection.
Scroll down to Yes - delete all user data and then press the Power key to confirm.
Once it is done select reboot system now and press the Power key to confirm and reboot your handset.
Important Note: On some Sharp models (such as the Sharp FX Plus ADS1) if holding the Sym button and Power key simultaneously doesn't take you directly to the Android system recovery screen you might have to do one additional step. If using this hard reset key combination takes you to a screen which shows an exclamation mark within a triangle, then press the Home key (while on that exclamation mark screen) and this should take you to your Sharps Android system recovery options.
Samsung GT-P6200... | Answered on Jul 04, 2014
Call your cell provider. One time my son locked my phone by not knowing my code. they where able to unlock it. I was not happy. Think they may have had me go to the store to do it though can't remember. Hope this helps
Samsung GT-P6200... | Answered on Mar 14, 2014
after 5 tries it will ask you to try later.. but at the bottom you will see forgot pattern... click it and login to google account that you have in you android now draw new pattern
Samsung GT-P6200... | Answered on Feb 09, 2013
Your answer is in this 2 min youtube video
https://www.youtube.com/watch?v=e7wjzPc55tc
Samsung Galaxy... | Answered on Feb 19, 2020
When you are selling off your Android device or passing it down to someone else, you will need to ensure that you have wiped clean all your personal data from the device.
With so many identity thefts and financial frauds going on these days, data privacy is constantly the talk of the town---cyber criminals are especially savvy when it comes to retrieving confidential data on your device long after you have erased it out of your Android device's memory.
There are so many data recovery tools available in the market that a mere factory reset is not enough to keep yourself safe from malicious intent. So how do you protect yourself?
Android Data Eraser will permanently erase existing and deleted files, browsing history, caches and other personal information (pictures, contacts, messages, call history etc.). Its click-through processes are easy to follow---even a technophobic will be able to use it without anxiety. FoneDog - Android Data Erase is also one of the few Android data wipe apps that support all Android-run devices in the market.
See the Full Guide: Android Data Recovery Guide Erase Your Phone Completely and Safety
Samsung Galaxy... | Answered on Jan 08, 2020
You can try GT Recovery to restore deleted pictures! Lost your photos on Android phone & need to recover deleted pictures, try GT Recovery for Android - the World's 1st Data Recovery Software for Android smart phones.
It can directly recover deleted pictures, photos lost due to deleting, restoring factory settings, flashing ROM, rooting, etc., from SD cards inside Android devices. It let you preview the deleted photos before recovery. Watch the video tutorial to learn how to retrieve photos from Android phone easily with simple clicks.
Key features of Data Recovery - GT Recovery for Android:
Preview & selectively retrieve photos and video lost due to any problem
Support all Android phones/tablets, like Samsung, HTC, LG, Motorola...
Only read and recover the data, no personal info leaking, 100% safe
Facebook: www.facebook.com/GT-Recovery-16556868313­68830/
Twitter:https://twitter.com/GtRecoveryapp
You'll be required to take your phone to a local phone repair shop or sending it back to Samsung for repairing
Samsung Galaxy... | Answered on Nov 13, 2019
Goodluck, Searched google Lots out there, give it a try, google (lock samsung galaxy s4 was stolen). Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://forums.androidcentral.com/samsung-galaxy-s4/293153-stolen-samsung-galaxy-s4.html
Reset Locate Or Lock Galaxy Phone From Google Account Tutorials
Remotely Locate Track Lock and Wipe Data on Your Galaxy Device from...
Samsung Galaxy... | Answered on Nov 11, 2019
you need to remove the google account and the Samsung account from your device first, after this the react lock should be disabled
http://theandroiddoctor.com/samsung-account-removal-service-for-at-t-samsung-galaxy-s5-sm-g900a/
Try this link and follow the instructions.
Samsung Galaxy... | Answered on Oct 25, 2019
reflash with latest files
Samsung Galaxy... | Answered on Oct 14, 2019
Try to force restart your unit, by pressing volume down and power button in 5 to 10 sec.
Samsung Galaxy... | Answered on Sep 20, 2019
The only option is to hard reset your unit.
1. Restart your unit
2. Press volume up and bixby button and power button
3. Wait until android logo appear
4. Choose wipe data/factory reset
5. Reboot your unit
wait until set up will appear.
Samsung Galaxy... | Answered on Sep 18, 2019
See this... http://mobilephonerepairguides.blogspot.com/2011/10/how-to-hard-reset-samsung-galaxy-y.html
Samsung Galaxy... | Answered on Sep 16, 2019
It appears you have set up an alarm or reminder in your clock app or calendar app. Check those apps to see the settings.
Samsung Galaxy... | Answered on Jun 29, 2019
Don't know if it will tell you try in support section.
http://www.samsung.com/uk/consumer/mobile-devices/smartphones/galaxy-s/SM-G900FZKABTU
Samsung Galaxy... | Answered on Jun 04, 2019
Samsung GT-P6200 Galaxy Tab 7.0 Plus 16GB, 3G, 3MP, 1.2GHz dual-core, 3.2 Honeycomb 7-Inch Unlocked World Tablet PC Black Logo
Popular Tags
11 questions posted
Top Samsung Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
John Tripp
John Tripp
Ekse
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
Galaxy Samsung
  • Galaxy Samsung
Most Popular Question
messages show phone number not contact
  • Cell Phones
