20 Most Recent Polaroid i1032 Digital Camera Questions & Answers
You don't need any special software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo management program such as Picasa ( http://picasa.google.com ).
Polaroid i1032... | Answered on Mar 11, 2014
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Polaroid i1032... | Answered on Apr 12, 2011
At the time your camera was made, 1GB was the max size standard SD card. Then along came 2GB standard SD, but this card also used the same format as previous cards, so yes it also worked in your camera. Now SDHC is a very different format with different file handling (although externally it looks exactly the same). I'm sorry to say, it is very unlikely that SDHC will work with your camera. Here on Fixya you'll see many folks asking why the brand new card they just bought doesn't work with their older camera. 9 time out of 10, this is the reason why.
Polaroid i1032... | Answered on Mar 22, 2011
Unfortunately, if the batteries have corroded then the chances are extremely high that the contacts (and possibly more of the camera's internal electronics) have also been affected by corrosion. It may be possible to clean the contacts yourself, but if there is corrosion internally then the camera is probably not economically repairable.
Polaroid I... | Answered on Jun 08, 2016
THAT MAY BE COINCIDENCE. I HAD MINE QUITTING WHILE I WAS GETTING INTO POSITION TO SHOOT A PICTURE. I DIDN'T BOTHER WITH REPAIR AND BOUGHT AN OLYMPUS VR-320. MUCH SIMPLER AND QUICKER TO SHOOT.
Polaroid I... | Answered on Jun 18, 2015
If you can't find any decent Sony store, please try an universal charger. Today you can find its of different universal chargers, costing less then any brand own charger. And you can put any rechargeable battery on it.
Please look for a complete automatic one, if you don't have enough tech skills. The great thing about my charger is, when traveling I only need one charger for all the (different) camera's in the family.
Polaroid I... | Answered on Dec 09, 2014
Probably the battery is not charging. If it is older than 5 years, the battery could be bad. See if you can have it checked or replaced.
Polaroid I... | Answered on Aug 11, 2014
Sorry, not even Polaroid seems to have that manual online, only the quick start guide. Try requesting the manual at http://www.polaroidcamerasupport.com/products/IS085/IS085.html
Polaroid I... | Answered on Jul 09, 2014
you dont say what size or type of card you have there? did you previously use the card elsewhere? format the card on a PC using SDFORMATTER (google it) hope that sorts.
Polaroid I... | Answered on Mar 24, 2014
A factory reset will restore your Kindle to factory conditions and removes any content you've downloaded to your device, be sure to back up your personal content to your computer first. You will be able to download all your Amazon purchases from Archived Items after registering a new device or application.
To factory reset your Kindle:
1. From the Home screen, press Menu.
2. Select Settings.
3. Press Menu again and select Reset to Factory Defaults.
Your Kindle will then begin to reset. This may take a few minutes to complete.
Polaroid I... | Answered on Mar 16, 2014
Polaroid i1032 Digital Camera Logo
Popular Tags
8 questions posted
Top Polaroid Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Marvin
Marvin
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
View Most Popular
I Polaroid
  • I Polaroid
Most Popular Question
computer new software old find exe file
  • Cameras
