20 Most Recent
Polaroid ION Digital Camera Questions & Answers
I have a Ion digistal
You should be about to just plug the camera into your computer using the supplied USB cable.
A dialogue box should open asking if you want to import the photos.
From there you can just copy/paste the photo files onto your computer.
Need software and driver for ion digital camera
This type of camera is mostly designed and made in China, and is usually unsupported in vista. For XP you can try installing the driver came in a CD along with your device.
You can also try for alternate way.
If the camera uses a memory card, you can buy a card reader.
Then you do not have to install any of the software that came with the camera.
Any store that sells digital cameras will sell memory card readers.
Prices run from $10 to $20.
You can attach the card reader to your computer USB port and Vista will recognize the reader as being a new hard disk. Vista will load the correct drivers.
After that is done, install the memory card (full of photos) into the card reader.
Then you can use Windows Explorer or My Computer to find the new hard disk (which will be the memory card). Use drag and drop to move the photos to your computer.
My husband set up a
I'm not a huge fan of some software designed to speed up a computer... often causes more problems then it solves.... four programs to download should solve alot of problems... ccleaner.. spybot s&d, auslogics defrag and auslogic registry defrag. if you have troubles finding these programs let me know i'll provide links to each one. after you have them leave a message here i'll explain each one to you.
Robert
Green light flashing on Polaroid iE 6035
The green light flashing on your Polaroid iE 6035 camera typically indicates that the camera is in standby mode or that it is charging. If the camera is not charging, it could be a sign of a problem with the battery or charging mechanism. If the green light continues to flash even after charging, it may be necessary to take the camera to a professional for repair or to have the battery replaced. Before seeking professional help, you can also try resetting the camera or removing and reinserting the battery to see if that resolves the issue.
