20 Most Recent
Thermador HNW48YS Stainless Steel Kitchen Hood Questions & Answers
Fan light flashing on thermador vent hood model HNW36YS
Grease Filter Saturation LED
The speed 2 LED in Figure 1 in is
marked with an F. This LED will
flash to remind you when the grease
filter needs to be cleaned after 40
hours use. Follow the instructions
for cleaning filters in thisFollow
the instructions for cleaning filters
in this booklet. Once the grease
filters have been cleaned, reset
the display by pressing button A for
10/18/2014 7:29:08 PM •
Thermador...
Answered
on Oct 18, 2014
Replacing the TRD sensor in a Thermador double oven.
Please look on page 40 of the manual for the Thermador SMW272 B Service Manual to find specific directions for removing the sensor. You can text "SUPPORT" to 53730 for quick access to such documents or call 1 (800) 735-4328 to speak to Thermador.
Thank you.
2/24/2023 1:20:05 AM •
Thermador...
Answered
on Feb 24, 2023
Thermador model GGCV30 gas cooktop
The flame spreader in the middle of the hob has a small hole that directs as jet of gas to the igniter. Put it in a pan of water and dish soap and gently heat it to almost a simmer. Be careful, it will want to boil over. Leave it to cool and and rinse it well paying attention to the holes in the edge. Blow it dry and try again.
10/26/2021 11:12:20 PM •
Thermador...
Answered
on Oct 26, 2021
How to change the switch on a thermador UCV36
www.
thermador.com/support
ThermadorThermador customer support is your appliance resource for FAQs, use & care videos, product registration, warranty information, service, repair and more.
www.
thermador.com/faq/categories.php?categoryid=63
ThermadorWe recommend that a Thermador authorized servicer change the seal ... refrigeration appliances, especially when the cooling function is switching on or off.
www.shopyourway.com > Manage My Life > Questions
Get shopping advice from experts, friends and the community! I have a Thermadordowndraft vent model number RDDS30VRS that I need to replace switch part ...
8/31/2021 9:18:11 PM •
Thermador...
Answered
on Aug 31, 2021
I have a Thermador PRSE304SLP
4 burner stove. The front burner on the left will not ignite. It does have spark. All the little holes are clear in the cap/cover.Everything is dry. It’s been like this for quite a while. It does not click like the other three when i push in and turn it and does not get gas. Is this a bad gas solenoid ?
you hear clicking and see sparks as you turn the burner knob, and can smell that gas is flowing okay, but the fire won’t ignite, it’s possible that the gas feed is cloggedThis is a super quick and easy fix – simply lift off the grate (make sure it’s cool to the touch), take off the burner cap, and lift the burner out from the range top. For some models, you may need to unscrew the two screws holding the burner in place – for this, a regular nut driver or socket wrench will do the trick.Have a look at the small, nearly pin-sized hole in the back of the burner. This feeds the gas through to the igniter to get the fire lit, and can frequently get blocked up with grease or any other kind of debris. Just give the burner a thorough clean, sticking a toothpick, needle, or other similarly sized tool through the hole to clear it up, and pop it back on to your stovetop. The gas should feed through and the burner should light as usual.
11/25/2020 3:51:58 AM •
Thermador...
Answered
on Nov 25, 2020
Why doesn't it heat?
Your mystery Thermador appliance is broken. Contact your local service department.Broken elementBroken thermostatBroken Switchor heaven forbid ... A failed mainboard!https://www.fixya.com/cars/r25931461-get_good_answers..
11/23/2020 7:29:03 PM •
Thermador...
Answered
on Nov 23, 2020
Thermador P304CS error code 4 preheat blinks then 3 heat blinks
I wanted to post this up in case someone has trouble finding an answer and what worked for me. I found somewhere else that the 43 code (4 preheat;3heat) blinks was specific to the cooling fan or the temp sensor. I had started to remove the temp sensor off the back wall of the oven but was unsure where the wire ran to. There is a specific Ohm value it should have around 1080 I think (not 100% postive).
What I found during that search is what solved the oven problem for me. On the top of the range, if you pull off the grill grates and remove the center stainless cover you can access under the burners. You can do this without removing any wires or hardware. In the back of this area is a small cover held in by 4 screws. Remove that. Underneath it is the cooling fan switch. It is a mechanical switch that when the fan kicks on it pushes a metal sail that then causes a connection in the switch letting it know the fan is operating. This switch had a little bit of corrosion on one terminal but it is also prone to getting dirty. Clean it off and try to restart the oven. The sail should move forward and the switch makes connection. For me once it was cleaned and any corrosion cleaned off, my oven worked just fine. This is a pretty easy check with the 43 code since it does not involve a lot of invasive work. Hope this helps someone.
11/21/2020 11:12:13 PM •
Thermador...
Answered
on Nov 21, 2020
