20 Most Recent EliteGroup NFORCE 570 SLIT-A Motherboard Questions & Answers
3answers
Can not boot from cd rom...bios boot order is set
Set all in Boot priorty to CDROMSet Other Boot Device to No.
7/27/2015 5:35:56 PM • EliteGroup... • Answered on Jul 27, 2015
Problem on motherboard and it needs replacement.
http://www.ebay.com.au/itm/ECS-MCP61M-M3-V7-x-mATX-MB-AM3-NVIDIA-GF6100-nF430-2-/360381346919?pt=AU_Components&hash=item53e866f467
$54 $12 postage
http://www.ebay.com.au/itm/ASUS-M2N-SLI-Deluxe-AM2-NVIDIA-nForce-570-SLI-MCP-ATX-/330595100597?pt=AU_Components&hash=item4cf900e7b5 You $78.89 free postage might get these on Ebay im not sure which country you are in this might guide you to one you could get this on Ebay if you dont have an account you will need to create one Add Email adress Add Bank Acc Add Credit Card also add your postal adress also add a paypal account when you get to the paypal login page at the bottom you will see new to paypal sign up tab paypal to create an account paypal registration password ,bank card /credit card,phone numbers home/mobile ,email adress and a postal adress be very specific when you type in the search always ask questions? before you make a purchase and keep the email/s for security reasons if the item arrives and its not as described you will even see the pictures of your item so you cant make a mistake and get them home delivered hope this helps
8/1/2011 10:13:22 PM • EliteGroup... • Answered on Aug 01, 2011
I replaced the memory and turned the computer on
Assuming you tried putting the old ram back and had the same result?
No beeps are indicative of a failed Power supply (check the PSU fan is working and the CPU fan is turning), Then check the ram modules are firmly inserted. Check the small 4 pin Black and yellow power rail that powers the cPU is tight.
After that, unplug, remove the CMOS battery, leave for 30 seconds and re-insert, try booting now.
If that fails, you have either got a fault on the mobo, or a dead CPU.
Testing the board with a known good CPU will confirm the latter.
Check the motherboard for blown and bulging capacitors, see if you can smell any burning from the board, either will indicate damage to the motherboard
2/12/2011 6:12:22 PM • EliteGroup... • Answered on Feb 12, 2011
2answers
I have a NForce 570 ****-A. I went on vacation and
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ? hope this helps
1/18/2011 3:53:56 AM • EliteGroup... • Answered on Jan 18, 2011
2answers
My onboard sound wont work, i tried downloading
Try going to the motherboards manufacturers web site and downloading them from there. That should help you out.
12/8/2009 1:19:32 AM • EliteGroup... • Answered on Dec 08, 2009
Widows vista want start so that i can load the
Use the motherboard support cd to install all the necessary drivers for your motherboard.
11/8/2009 11:30:02 AM • EliteGroup... • Answered on Nov 08, 2009
Best Sli card for my motherboard
Any cards that support SLI will work perfectly fine on your board.
9/12/2009 11:19:02 AM • EliteGroup... • Answered on Sep 12, 2009
I cant get the system booting process.
Reset your bios settings pull cmos cell from motherbord for 10 minutes then put it again it's position .Then pull out ram then refit again it.
then check .
If still issue then Change ram may be your ram has issue.
if after change RAM memory same issue then you have to repair your motherbord.
Also check key bord num lock key if it on and off after satrt computer then it is screen resolution issue.
For that when you power up the computer press F8 key then enter in enable vga mode .
Then change display proeprty settings change scren resolution to 1024*768 then aaply and ok.then check.
Also refix processor and processor fan .
Clean all dust from mtherbord and all parts.
8/22/2009 8:47:10 AM • EliteGroup... • Answered on Aug 22, 2009
I am trying to upgrade processor to a core 2 duo
please read this article it will help you and give you idea upgrading your cpu...
http://www.hardwaresecrets.com/article/427
6/23/2009 6:14:39 AM • EliteGroup... • Answered on Jun 23, 2009
Got a trojan
You will have to run a full Virus Scan in safe mode with an Anti Virus program with up to date Virus Definitions.
Tap the F8 key on boot to get to the boot option screen that will allow you to select "Safe Mode", then select your operating system, then click yes on the pop up. Once in safe mode locate your Anti Virus program in your program folder and run the full/complete scan and that should fix you up.
5/22/2009 9:05:57 AM • EliteGroup... • Answered on May 22, 2009
2answers
Can't connect to internet after reformat
Here's something you can try WinSock XP Fix
Good luck getting connected!!
3/23/2009 8:24:47 PM • EliteGroup... • Answered on Mar 23, 2009
No video output
I'm glad resetting the CMOS fixed it. (Posted as solution so you can rate the response.)
3/23/2009 1:10:44 AM • EliteGroup... • Answered on Mar 23, 2009
The system boots up the moment power and becomes unresponsive.
Try resetting your BIOS.
To do this, depending on your board, there will be a small battery. Make sure the power connector is removed, and then remove the battery from the board. Wait 30 seconds, and then reinsert the battery, taking care to make sure it is in the right way round.
Try powering up your computer again, and see what happens. You will almost certainly have to reset the clock afterwards, however the computer should automatically detect the drives, allowing you to reinstall the operating system etc.
If that doesn't work, then it sounds like you have a failed motherboard.
3/5/2009 1:56:02 AM • EliteGroup... • Answered on Mar 05, 2009
I need sound sriver 4
Go To UpDrivers.com/Drivers/MotherBoard/EliteGroup
to Download your Drivers
Please Rate My Response! Thanks!
1/31/2009 8:53:55 AM • EliteGroup... • Answered on Jan 31, 2009
The system fails to boot up after a new power supply was added
There should also be a brand - the nVidia just relates to the chipset that the board uses, but its OK, lets check the wiring first.  If we still have trouble I'll get you to double check for the brand name.
Lets just check that you have the following plugs in place:
  1. The 24 pin plug from the PSU (blue) to your motherboard - this powers the board itself.
  2. A 4 pin 12v P4 connector plugs into the motherboard (near the CPU).  This is the CPU power.  It runs from the 8pin blue socket on the PSU.  Make sure that the end plugging into the motherboard is only 4 pin.
  3. No power cables required to run the 8600GT so the red sockets on the PSU are empty.
  4. Power cables going to all your peripherals (hard drives and CDroms).  These run from the black sockets on the PSU.
Does your current setup match that?
11/12/2008 5:28:32 AM • EliteGroup... • Answered on Nov 12, 2008
3answers
Bios don't boot at start stays at Black screen
i had a same problem too. but i know the real problem is the motherboard. it should be replace with the same model of motherboard.
9/18/2008 1:37:14 PM • EliteGroup... • Answered on Sep 18, 2008
I'm not getting video neither keyboard
Nothing less than a 600 watt power supply for the reason PCI-16 video cards need more power .
7/30/2008 9:51:01 PM • EliteGroup... • Answered on Jul 30, 2008
SATA drive stops or hangs . . .
Hi fadetoal, it's not you or you're drives. It's the onboard SATA controller. When a board is SATA compatible & the bios does not see the SATA drive (List the SATA drive), the fault is the board. You're board goes one farther than normal. Bios see's the drive but can't run. All you're going to do is pull you're hair out trying to get the board stable. Hope its still in warranty.
RMA time: http://www.ecsusa.com/ECSWebSite/Support/rmamb.aspx?MenuID=25&LanID=9
Best of luck!
Mike
5/3/2008 5:12:47 PM • EliteGroup... • Answered on May 03, 2008
2answers
Ecs 671t m3
The ECS website.
10/19/2018 1:20:10 PM • EliteGroup... • Answered on Oct 19, 2018
EliteGroup NFORCE 570 SLIT-A Motherboard Logo
23 questions posted
Top EliteGroup Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • EliteGroup Computers & Internet
Most Popular Question
replaced memory turned computer
  • Computers & Internet
