20 Most Recent MSI P4M900M-L (7255-060(P4M900M-L)) Motherboard Questions & Answers
Hello try this site:
http://www.msi.com/product/mb/MS-6533.html#/?div=Driver&os=All
Select your windows first.
Unzip the file before you install.
Here is some driver to look for:
Intel INF update
Intel 10/100 Ethernet Drivers
Cmedia Sound Drivers
Visit INTEL:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng
But i guess it`s a HP/compaq oem mainboard read
more here:
http://h10025.www1.hp.com/ewfrf/wc/document?lang=en&cc=us&lc=en&dlc=en&docname=bph07557
Visit the HP site and seach for drivers:
http://www8.hp.com/us/en/support-drivers.html
Enter the full model number or machine.
This is how you find it:
How do I find my product name / number?
Sounddriver:
http://download.cnet.com/Realtek-AC-97-Driver-Windows-98-Me-2000-XP-2003/3000-2120_4-10238712.html
Lan card:
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?cc=us&lc=en&dlc=en&tmp_geoLoc=true&softwareitem=ob-18404-1
Good luck
MSI P4M900M-L... | Answered on Nov 06, 2012
http://computerpartdiscounters.com/microstar-p4m900m2-ms-7255-motherboard-version-2-1-socket-775.html
Dennis, quit fooling around with that OnBoard audio on that mobo.
Just install an economical sound card.
One example,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1747731&CatId=2771
This baby will S-M-O-K-E the onboard audio you have now. (Or did)
Just install in any available PCI (White) slot.
Regards,
joecoolvette
MSI P4M900M-L... | Answered on Jun 26, 2012
This is your board:
http://www.newegg.com/product/product.aspx?Item=N82E16813130084
It is almost all Via with P4M900/VT8237A chips, VIA S Chrome 9(video), and VT1708 for sound. You can try MSI here:
http://www.msi.com/service/download/
or you can try VIA here:
http://www.via.com.tw/en/support/drivers.jsp
You can change the operating system but, it does seem to have support of Windows 7.
MSI P4M900M-L... | Answered on Jul 10, 2011
Look for jumper labeled JFP1. On this jumper are the following pinouts:
Pins 1&3 = Hard disk drive LED
Pins 2&4 = Power Indicator LED
Pins 6&8 = Power on/off switch
Pins 5&7 = Reset switch
MSI P4M900M-L... | Answered on Jan 08, 2010
open your keyboard and cleans the key pad keys . If you using your keyboard more then 2 years its better to change it
MSI Computers &... | Answered on Jan 07, 2020
i want webcam driver for windows7...?
MSI Computers &... | Answered on Sep 12, 2019
I suppose, you won't be able to fix it that easily. Something is wrong with the keyboard and most likely you'll have to replace it. But I'd say that it is pointless. I mean, the laptop is a bit outdated so why not to get something better? There are so many options out there. If you need a laptop for doing job, here you can take a look at these laptops for quickbooks and daily accounting which can handle basically, any taks besides resource intensive ones like gaming, 3d rendering, etc.
MSI Computers &... | Answered on Aug 28, 2019
Although I've got a different type of MSI but I have where the "official guys" say there should be: at the back of it, maybe you need to remove the battery and look there under "S/N: xxxxxxxx"
MSI Computers &... | Answered on May 11, 2019
that 1996 is not correct (its series name only)
MSI N1996 Motherboard P6NG Neo-Digital MS-7505
the bottom sticker on the mobo tells what it really is.
MSI motherboard, just bought ? used"?
ever see it work before.
did you go to msi.com and the manual on setups"?
are you using the onboard VGA port to a VGA monitor.
The monitor shows no signal means exactly that.
This motherboard has 1 power jacks, the big one 24 pins
and the 4pin at top left of the fan.
you must use PSU v2.2 or newer to get that 4 pin power.
covered on page 24 in your manual, here.
https://www.msi.com/Motherboard/support/P6NG_NeoDigital#down-manual
and CPU and fan, (correct)
and memory
and a power switch to the power switch jack.
next time post all stickers on mobo so we can see what it really is.
they made vast numbers of motherboards. a fact.
MSI Computers &... | Answered on Apr 12, 2019
Well, you could uninstall anything related to the sound device. If you can, I suggest using the sound driver provided by the manufacturer. Let me know how it went, thanks.
MSI Computers &... | Answered on Jan 26, 2019
Beeping mostly means it's trying to give an error code along. Listen to the amount of beeps and the duration of them. This is the error code that it tries to give on. Look up in the manual what the beeps mean and how to solve it.
MSI Computers &... | Answered on Jan 17, 2019
Cheers!!
Need to replace the display flex ribbon cable to solve the flickering and color lines problem. This cable gets damage over the time of long usage.
MSI Computers &... | Answered on Nov 20, 2018
MSI P4M900M-L (7255-060(P4M900M-L)) Motherboard Logo
11 questions posted
Top MSI Computers & Internet Experts
Ekse
Thomas F. Schneider
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • MSI Computers & Internet
Most Popular Question
need vga drivers
  • Computers & Internet
