20 Most Recent ASUS P5P800-VM Motherboard Questions & Answers
1. Check if something like power supply wire have bangin in there. 2. Clean : Try to use lighter fluid to loosen and clean the dirt inside the processor fan but first disassemble the fan from the heat zinc of the processor. flip the fan and you will see the bearing and motor, drown it with fluid, and rotate the fan so the dirt will loose, after some spins, try to spill the fluid inside the fan. then assemble and test.
ASUS P5P800-VM... • Answered on May 04, 2014
http://www.nodevice.com/driver/P5VD2-MX/get34077.html
or
if your computer came with a motherboard disc the sound drivers could be on it click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers if you dont have a motherboard disc you will have to download the drivers cnetdownload.com if these drivers are not suitable on the home page you should see the download software finder under that there will be a list platform, category sub category price fromthe category drop down list select drivers then from the price drop down list select free or which ever applies to your need or you could try some of these http://download.cnet.com/Realtek-AC-97-Driver-Windows-98-Me-2000-XP-2003/3000-2120_4-10238712.html Realtek AC
ASUS P5P800-VM... • Answered on Sep 14, 2012
I tried different power supply but its still not powering up. But when i remove the 4 pin 12V cable from power supply the cpu fan is rolling, it means that the power supply is working but when i tried to connect the 4 pin then the cpu fan stop just a second and never rolled on. The main problem is the 4 pin, the model is Asus P5P800-VM. I tried to reset the cmos and replaced the battery but it wont work out. Please help me!!!
ASUS P5P800-VM... • Answered on Sep 04, 2011
Hi, you can download the driver here at asus:
http://www.asus.com/Motherboards/Intel_Socket_775/P5P800VM/#download
This is the driver for windows xp if you are running another
operating system just select it in os.
Select audio and select global and download the driver.
The driver needs to be unziped before installation.
Right click and choose unzip here.
Here is a free unzip program:
http://www.7-zip.org/download.html
Just click on the exe file and download.
Hope this was helpfull.
ASUS P5P800-VM... • Answered on Aug 14, 2011
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions IDE,SATA
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error If your computer came with a motherboard disc the drivers could be on it or you might have a dirty graphics card remove the graphics card and clean the socket hope this helps
ASUS P5P800-VM... • Answered on Jun 10, 2011
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ? hope this helps
ASUS P5P800-VM... • Answered on Mar 25, 2011
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this will help don
ASUS P5P800-VM... • Answered on Feb 20, 2011
RAM Installed ( Max ) 0.0 MB / 4.0 GB (max)
hope this helps
ASUS P5P800-VM... • Answered on Feb 16, 2011
Hi friends ,
un install the audio driver .install driver again.I think audio driver did not install that is the problem for vedio
if dont have the driver
download
http://support.asus.com/download/download.aspx?SLanguage=en-us&model=M2N-MX%20SE%20PLUS&product=1
think it will help you
ASUS P5P800-VM... • Answered on Nov 24, 2010
Go to the BIOS. Just restart your computer and while restarting, keep on pressing "f2" key or the "del" key, sometimes "f8" until you see the option that you can go to setup/bios. On the Bios menu, just find there the option to disable the Chassis Intrusion detection.
ASUS P5P800-VM... • Answered on Oct 07, 2010
Put the new video card in, connect the monitor to it, boot in the BIOS and in there set the video card to Auto.
ASUS P5P800-VM... • Answered on Sep 27, 2010
there are 2 notches at either end of the ram module with 2 levers adjacent.
press down firmly on top of the ram until the levers secure into the slots
ASUS P5P800-VM... • Answered on Sep 15, 2010
check SMPS providing power to Mboard to start(see mother board light on or not<green LED>) then do all this things if smps is ok then check soun d beep if no beep take your board to hardware shop
ASUS P5P800-VM... • Answered on Jun 23, 2010
Here is the Asus site where you can download the board drivers
http://www.asus.com/product.aspx?P_ID=oP18OIoOjkinxNiI&content=download
ASUS P5P800-VM... • Answered on May 29, 2010
Hi, I'm not going to go into a guessing game of why I believe the "Audio" isn't working; I just going to give you a quick and direct solution to the problem. Click on this site, and see if you can get your drivers "Updated." Next thing you can do is go to the [Start Menu], click on "Windows / Microsoft Updates" and have the necessary (Updates installed). "If this helps, let me know by Rating the Help, thanks." http://www.nodevice.com/driver/P5P800-VM/get34074.html
ASUS P5P800-VM Motherboard Logo
83 questions posted
Popular Products
Top ASUS Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Roy May
Michael Thomas
Michael Thomas
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • ASUS Computers & Internet
Most Popular Question
motherboard power problem due atx 12v
  • Computers & Internet
