20 Most Recent HP G60-535 Laptop Notebook Netbook Computer 450gb Hdd,2gb Ram Excellent Questions & Answers
To do a power reset, unplug your laptop, remove the battery and hold the power switch down for 30 seconds.
otherwise it may be problem with your screen back light...
HP G60-535... | Answered on Apr 10, 2013
Larry Ng writes
Jun 19, 2020
Must we beg you what PC? NOR what OS this is.
failure to boot has vast causes.
Do you want them all, ?
Take the PC to any shop get it fixed.
clear to causes.
1: HDD bad, no bad HDD on earth can boot your OS, is that clear? We test this HDD first.
2: A Corrupted unstated OS. endless ways, reload it and cured.
There are more, but I want to keep it simple.
HP Computers &... | Answered Yesterday
download and install bluestacks, it is a android emulator and the only way to access smartphone/tablet apps on pc
Follow the online prompts after installing the hp software.
HP Computers &... | Answered on Jun 17, 2020
Instal the motherboard drivers first.
HP Computers &... | Answered on Jun 16, 2020
Windows failed to start. A recent hardware or software change might be the cause. To fix the problem:
1. Insert your Windows installation disc and restart your computer.
2. Choose your language settings and then click "next."
3. Click 'repair your computer'.
If you do not have the disc, contact your system administrator or computer manufacturer for assistance.
File: \Boot\BCD
Status: 0xc0000225
Info: An error occured while attempting to read the boot configuration data.
HP Computers &... | Answered on Jun 11, 2020
you can recover lost files from computer with Asoftech Data Recovery program. here's the good guide
http://www.youtube.com/watch?v=vZDCrKzNl6w
HP Computers &... | Answered on Jun 05, 2020
If this issue started with a motherboard error that appeared to be a faulty CMOS battery and then it started incorrectly detecting your memory and now is asking for a password it could be a faulty motherboard. If you are 110% you or anyone else has set a password on that laptop then I would say your motherboard needs to be replaced. It is a difficult process to reset admin passwords on most laptops due to a security chip that will prevent the trick of removing the battery from working. In all honestly if no one has set a password and the motherboard THINKS someone has then even if you reset the password you will still have issues. There is a small chance your CPU or RAM could be defective. But, again going back to it saying you have a password set that was never set. It just yells faulty motherboard unless someone has set a password without you knowing.
HP Computers &... | Answered on May 28, 2020
If you've got working Wi-Fi but your wired ethernet connection is not working, the first thing to do is turn off the Wi-Fi. Believe it or not, this might tell you that the ethernet is working. ... Right-click on the icon, go to Open Network and Internet Settings, then the Wi-Fi tab, and toggle off.
This Error 1702 problem can occur if all the following conditions are true:
  • You originally installed Office from a network administrative installation.
  • The network administrative installation is no longer available to you.
  • You are trying to use an Office CD-ROM when you are prompted by the Windows Installer for an Office source location.
  • You click Cancel when you are prompted to insert the CD.
Because the files in an administrative installation are uncompressed, and the files on an Office CD-ROM are compressed, the Windows Installer cannot resolve the differences between the two source types. The resolution to this problem depends on whether you can obtain access to a network administrative installation. Use the following methods, as appropriate to your situation.
If the original administrative installation from which you installed Office is not available, you can use a different administrative installation for the Office source file location. To do this, follow these steps:
  1. Click Start and then click Run.
  2. In the Open box, type a command line similar to the following, and then click
    OK new network path\Setup.exe /fvm package name.msi
    where new network path is the full path to the alternative network administrative installation, and
    package name is the name of the Windows Installer .msi package on the root of this administrative installation (for example, Proplus.msi).
  3. Click OK when the update is finished.
HP Computers &... | Answered on May 24, 2020
https://www.youtube.com/watch?v=1_ssncypf_I
Factory reset the laptop! That will clean up the system and it will run as new.
If you have used the 5 allowed changes, then your device is locked at the last one. You may be able to unlock it so it works region free. There are tools on the internet that allow you to do this.
The free way is to just install videoLAN (VLC). If yo use videolan as your video player, it should play any dvd without needing to modify firmware or "hack".
If you want to try to modify your locked DVD region codes, a good place is www.videohelp.com. Here is the direct link to the regon page:
http://www.videohelp.com/tools/sections/region-free-tools
Regards,
Chris
HP Computers &... | Answered on May 07, 2020
Rebooting forever is either memory fault or the HDD have corrupt system files. From the BIOHD-8, it sounds like HDD issue. Try download "HDD Regenerator 1.51" CD ISO, burn to DC and scan to whole Harddrive. This nice software is designed to recover corrupt/bad sectors. I had a friends PC falls into this case. 1 bad sector was found and recovered within 2GB from start where most Windows system files are stored. Then reboot and windows do a chkdsk automatically, and resolved!
HP Computers &... | Answered on May 04, 2020
if the error says Hard disk 1 Quick (303)
then the hard disk must have been in jeopardy or say it is not in normal condition or almost dead.. if you are under warranty then try to contact HP..
HP Computers &... | Answered on Apr 30, 2020
replace the hard drive that failed
HP G60-535 Laptop Notebook Netbook Computer 450gb Hdd,2gb Ram Excellent Logo
2 questions posted
Top HP Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Ekse
Muntejaya Ginting
Muntejaya Ginting
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • HP Computers & Internet
Most Popular Question
never any restore point in ccleaner
  • Computers & Internet
