20 Most Recent Samsung Rv-511-a01 Notebook Questions & Answers
If it is an IDE hard drive, this will be a flat ribbon cable with 40 pinouts. You will plug the cable in the matching socket closest to the CPU (there will always be a few available sockets)
If it is a SATA hard drive the cable is much slimmer with a right-angled connector. If you look really closely at the connector blocks on the motherboard they will be numbered from SATA0 to SATA3 (or higher depending on how many are there) - choose the lowest available number.
Samsung... | Answered on Aug 10, 2013
It is most likely a bad battery. Also, if you can find another charger like the one you have you could check to see if the charger itself is the problem. In my experience, the battery is the likely culprit.
Samsung... | Answered on Sep 27, 2012
make sure you have the right mouse selected click start control panel mouse hardware you will see which mouse is selected
you might have to uninstall the mouse then restart your computer then reinstall the mouse and its drivers
click start control panel administrive tools computer management device manager scroll to mice and other pointing devices you might see a yellow exclamation mark ! or question mark ? or a red x
right click you will need to update the driver
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you have options to troubleshoot also you can select properties under driver you will have options to update driver,rollback driver or uninstall
make sure you have the right mouse selected click start control panel mouse hardware you will see which mouse is selected in xp
I have found that the best way to adjust your mouse settings is to create a control panel in your bottom toolbar scroll to the bottom of your screen right click you will see an array of options select the toolbar option then select desktop
then you will see the desktop in the bottom toolbar select the 2 >>arrow heads then all control panel items then select mouse this is in WINDOWS 7
in XP you will have to select the new toolbar option once you have that a browse option select my computer then control panel then a control panel option will be in the bottom toolbar
for the double click this will be in the folder options follow previous to get to control panel items
click start control panel navigate folder options tick in the double click to open circle
hope this helps
Samsung... | Answered on Sep 16, 2012
Does this all-in-one have the original Windows 7 installed or has the OS been upgraded? This could be a driver issue or a problem with the Ethernet cable (if you are using the wired network). It could also be caused by the distance/direction between your computer and the router, if you are using the wireless network adapter. Try a new cable. Open the Device Manager (right click on Start for all versions of Windows). Find the section with the network adapters and check for entries with a yellow triangle with an exclamation point or red triangle with an x. These indicate the driver that has an issue.
I recently went through some trouble-shooting on a slow computer running Windows 10 2004. After checking everything with the drivers, including launching the system in Safe Mode with Networking, I finally found the Blue Screen of ***** that the user didn't mention. The Windows Driver Verifier was causing crashes. The solution turned out to be using the sfc /scannow command at the command prompt when run as administrator. (Again, use right click on Start for a fast option to find the command prompt.)
On one laptop (with OS updates from Windows Vista, Windows 7, 8, and 10) I dealt with, Microsoft installed a driver for the wireless network under Windows 10 that just didn't work. It would make the wireless network slower than the 10/100Mbs wired network adapter. Every time I did a clean install, I had to specifically install the correct Broadcomm driver for the wireless network adapter. I made a point to save this driver to a CD so that I could speed up restoring the network functions before Windows tried to do any updates.
I hope this helps. Please add a comment with more information about the OS on the DP700A3B-A02US and the internet connection type that you are using. If you see any error messages or had any system crashes, add any key words that you saw. Then I can better assist you in solving the problem.
Samsung... | Answered on Oct 20, 2020
Read this
support microsoft com
Samsung... | Answered on Oct 15, 2020
Resolve the issue of Error Code 0xc0000185 with the help of the Hp Technical Support Phone number. Here the Technical Expert will provide you all possible help for getting out of this issue. Just visit the help website through the link shown below. Link:- https://www.hptechnicalsupportphonenumber.com/blog/fix-hp-printer-error-code-0xc0000185
Samsung... | Answered on Sep 11, 2020
there is a TP link that you can get from places like Jaycar that will turn your house wiring into extension cords for the router
the operation can be explained at the shop but it means that you can extend the wires to any part of the house and by using ethernet cables will connect other computer, printers and tv units easily
cheaper that new modems and routers
Samsung... | Answered on Jul 14, 2020
Well... Yes and No... Does this set have an Ethernet port?
If so then try and plug it in that way.
Try and reset the router and tv
Make sure the connection settings are correct or defaulted
Are you entering the correct password?
Are you close enough to the router?
reset the network setting on the tv
it's possible you may have a bad wifi chip but im not thinking you do. Good Luck and come back it the above does not help we can go more into detail.
Mr.Mike
Samsung... | Answered on May 20, 2020
Download and install this it will allow almost all media to play in your windows media player.
http://download.cnet.com/K-Lite-Codec-Pack-Full/3000-13632_4-64246.html?tag=mncol;2
Or you could download VLC media player, it plays everything.
http://download.cnet.com/VLC-Media-Player/3000-13632_4-10267151.html?tag=mncol;1
Personally I would stick with the windows media player, just because it's half a part of windows, & it's what I've always used. Or if you have a zune, or xbox windows media player is needed.
Samsung... | Answered on Apr 28, 2020
hi. my name is rui i will answer your question regarding your problem about how to setup a compatible dvd decoder for sumsung external dvd drive.
1st of what's the model of yoursumsung external dvd drive?
2nd if you have a internet connection and know the model of your dvd drive you can download a compatible decoder for your sumsung(model)using google.
here is one that you can try out its a NVIDIA PureVideo Decoder (NVIDIA DVD Decoder) 1.02.186 (Samsung Dvd Decoder).
NVIDIA PureVideo Decoder is a combination of a hardware video processor and video decode software for playback of DVD and MPEG-2 videos using Microsoft Windows Media Player and Windows Media Center Edition.
you can download it @ http://samsung-dvd-decoder.fyxm.net/
it's easy to use just follow the instruction...
hope it helps you in anyway.^_^
Samsung... | Answered on Apr 07, 2020
?Makes $140 to $180 consistently online work and I got $16894 in one month electronic acting from home.I am a step by step understudy and work essentially one to two or three hours in my additional time.Everybody will complete that obligation and monline akes extra cash by simply open this link.......
OPEN THIS WEB...>>>>> https://bit.ly/3b9Z7Oq
Samsung... | Answered on Mar 25, 2020
https://www.samsung.com/us/support/troubleshooting/TSG01110761/
Samsung... | Answered on Feb 26, 2020
Check the security settings of your mail server to ensure you're not being blocked.
Here are some 'standard' settings that may work with your system.
Gmail Incoming Outgoing
Access Type Web & POP3 Web & POP3
Email Address Format [email protected] [email protected]
Account Username Format
Full email address Full email address
Server Address pop.gmail.com
Use SSL: yes Port:995 smtp.gmail.com
Use SSL: yes Port:465
Hotmail Incoming Outgoing
Server Address pop3.live.com smtp.live.com
ic24 Incoming Outgoing
Server Address mail.totalise.co.uk smtp.tiscali.co.uk
UKGateway Incoming Outgoing
Server Address pop.ukgateway.net smtp.ukgateway.net
UK Online Incoming Outgoing
Server Address pop3.ukonline.co.uk smtp.ukonline.co.uk
Vippowerent Incoming Outgoing
Server Address pop.vppn.com
Virgin.net Incoming Outgoing
Username Username
Server Address mail.virgin.net mail.virgin.net
Wanadoo Incoming Outgoing
Email Address Format [email protected] name.wanadoo.co.uk [email protected] name.wanadoo.co.uk
name.wanadoo.co.uk name.wanadoo.co.uk
Server Address pop.wanadoo.co.uk smtp.wanadooasdl.co.uk
World Online Incoming Outgoing
Email Address Format [email protected] worldonline.co.uk [email protected] worldonline.co.uk
Server Address pop.
tiscali.co.uk smtp.
tiscali.co.uk
Yahoo.co.uk Incoming Outgoing
Username Username
Server Address pop.mail.yahoo.co.uk smtp.mail.yahoo.co.uk
Yahoo.com Incoming Outgoing
Username Username
Server Address pop.mail.yahoo.com smtp.mail.yahoo.com
Settings - E-mail
You'll need to complete all steps for this to work. Make sure that if you have to enter O2 in the settings you use the letter O and not a zero.
The following settings are if you use O2 Email as your ISP (Internet Service Provider).
If you require different settings eg Yahoo, Gmail etc please click here
1. Tap the Application tab on the bottom of the screen
2. Tap Email
3. Tap Next on the Welcome to Email setup screen
4. Tap on the Email address text box and enter your Email address then tap Done
5. Tap on the Password text box and enter your Password for your Email account then tap Done
6. Tap Next
7. Your phone will now try and download your setting to your phone and set up your account, if this can not be done you will see the message, Setup could not finish. Unable to open connection to server. Tap Edit details to continue.
8. Tap Manual setup
9. Tap the Username text box and enter your full Email address then tap Done
10. Tap POP3 account
11. Highlight POP3 server and tap the text box and enter mail.o2.co.uk
12. Check that Port is default set at 110
13. Highlight Next and tap
14. The phone will now check your settings
15. Tap the SMTP server text box and enter smtp.o2.co.uk
16. Highlight Next and tap
17. The phone will now check your settings
18. Tap Next on the Account options screen
19. You now have the options to add a name for your new account plus add your name to outgoing messages
20. Tap Done
Samsung... | Answered on Feb 25, 2020
who to fix a Samsung home Air conditioner, on computer repair site?
why not ask them first.
read there service manual yet.
no samsung model stated, no answers easy.
https://www.samsung.com/in/support/
my wild guess, replace the now clogged filter.
i see manuals there one states
The filter
clean/
replacement
indicator
is blinking
continuously. then tells you what to do.... RTM
learn to find and read manuals first.,
Samsung... | Answered on Feb 10, 2020
Samsung Rv-511-a01 Notebook Logo
6 questions posted
Top Samsung Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
ThaMp3Doctor
ThaMp3Doctor
Marvin
Marvin
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Computers & Internet
Most Popular Question
get connecting wires connect
  • Computers & Internet
