20 Most Recent HP PHOTOSMARTD7160 Photosmart D7160 Q7046D Ink Jet Photo Printer Questions & Answers
First change the old head with the new box pack head if the problem persist then change carriage unit the problem will be clear.
HP... | Answered on Jan 02, 2013
Basically, as long as your printer is wifi enabled or network compatible, you just go into setting and add your wifi router SSID name, mine is bell598 and the WPA password.
Google
make model connect to wifi
Here are the details to set up mine
https://www.google.com/search?safe=off&bih=937&biw=1920&rlz=1C1QJDB_enCA643CA644&hl=en-GB&sxsrf=ALeKk00L2eLR_IeDPCfTMx0uZQ_QSDE2nA%3A1593790036366&ei=VE7_XtLjFaym_Qaz4KPoDw&q=canon+mg7120+wireless+setup
HP Office... | Answered Yesterday
Instal the supplied software and follow the prompts.
HP Office... | Answered on Jun 24, 2020
Use the software supplied with your printer and computer/smart phone/laptop device. Pair the printer with your router.
HP Office... | Answered on Jun 23, 2020
If you are looking for an affordable HP laser Printer repair in Manhattan then take the help of this information and get in touch with a certified third-party expert. We repair your printer and this might even take a few days as well. Hence, we hope that you get the best service by our printer technician expert for your printer.
Contact us : +1(802)722-2574
or for details you can visit to our website :https://www.instanttfn.com/blog/hp-printer-technician-repair-in-manhattan
HP Office... | Answered on Jun 11, 2020
Tip
Hp Printer Error "Carriage cannot move paper jam" when non exists.
The printer made strange noises this week. Assuming you are certain there is no paper jam and tipped the printer upside down as well. You have an error that leaves the print heads in the middle near the middle or left or right.
This is for you. "Carriage cannot move paper jam"
Whats happening is the print heads slide and are moved by a motor and belt.
To know whereabouts the print head is there is a resistance strip.
This is a strip of what looks like old real to real magnetic tape.
Its stretched as a strip in line with the print heads and is hidden from view.
Under the plastic see Arrow, is the location of this strip.
A sensor similar to a magnetic tape head which reads its position.
look at the image and just below this you will feel it. Clean this length of tape with some nail varnish cleaner and a non lint cloth.
You can slide the print head to clean the hole length.Your pint head will now position and park correctly.
re
on Jun 10, 2020 | HP Office Equipment & Supplies
Check in your device manager list to uninstall any listed as not installed properly then rerun the setup program. Only plug the printer usb in when the program prompts you.
The noise is normal as the printer is seting the head position and cleaning the print head, it is also running the rollers to check if there is a paper blockage or any paper in the load tray.
I get to the device manager by using the explorer for windows files, then on the Left side where the hard drivers are listed right click on This PC, choose properties.
A new screen will open that is labelled System.
On the top left you will see Device Manager.
Hope that helps :)
HP Office... | Answered on Jun 10, 2020
Printer Offline Error on the desktop screen shows that it failed to communicate with HP Officejet 3830 printer. The printer offline error mainly occurs due to a faulty driver, if you are facing any problem with your HP OfficeJet 3830, then you must follow these Steps to fix Officejet 3830 Printer Offline Error.
HP Office... | Answered on Jun 07, 2020
If your printer's status displays "Printer in error state," there may be a problem with the printer itself. Make sure the printer is turned on and connected to your PC by Wi-Fi or cable. Check it for low paper or ink, and be sure the cover isn't open and the paper isn't jammed
HP Office... | Answered on Jun 01, 2020
Usually, Error Code 0x07a74dd6 occurs when users try to start printing via connection to the computer. The Error Code 0x07a74dd6 could refer to anything from the product needing a basic reset to reinstalling the printhead or cartridges.
HP Office... | Answered on May 29, 2020
How to Completely Delete and Uninstall the HP Printer Deskjet Driver Software. HP printers ship with several printing applications and drivers.
https://www.cpprinter.com/how-to-remove-and-completely-uninstall-hp-printer-deskjet-driver-software/
First, be sure all four toner cartridges are seated properly as is the transfer belt. Close the front panel, then the top panel, power-cycle the printer and try again. If that doesn't solve the issue, it sounds as if either the actuator for the front door switch is broken off (which is highly unlikely) or the door switch itself is out of position. Getting to the switch involves removing most of the panels just to get to it; not impossible, just involved and a LOT of screws, plus a small black spacer for the top-left panel hinge. If you have any kind of a warranty or maintenance agreement on the printer, DO NOT TRY THIS, you WILL void it!! You have to unplug the printer, remove the fuser from up top, then the top panel, lower the front panel and remove the transfer belt and keep it out of the way in a dark area. Remove the hinged rear panel at the rear bottom followed by the rear panel (which fits inside a side panel, something to remember when reassembling). Now the side panel. If the switch is out of position, reposition it. If it's broken, it will need to be replaced. Reassembly is in the EXACT opposite of disassembly. You may wish to forego this and get an HP authorized tech in to do this for you. Worst Case Scenario: the DC Controller board is bad. But that's also unlikely ... possible, but unlikely. Let me know how it turns out!
HP Office... | Answered on May 24, 2020
go to start menu, choose printer & faxes, click the printer icon properties and find the printer resolution to adjust the dark printing capability
HP LASER PRINTERS 2, 2D, 3, 3D
1. Defective cable laser scanner to dc controller.
2. Defective laser scanner assembly.
HP LASER PRINTERS 2P, 2P+, 3P
1. Bad scanner motor.
2. bad dc controller.
HP LASER PRINTERS 3SI, 4SI, 4V
1. Faulty cable assembly.
2. Scanner motor problem.
3. Defective laser scanner assembly.
4. Defective dc controller.
HP LASER PRINTERS 4, 4+, 5
1. Faulty laser scanner cable.
HP LASER PRINTERS 4L, 4P, 5P, 5L, 5SI
1. Temporary error. Scanner startup failure.
2. Improperly fitted scanning assembly.
3. Scanner cable problem.
4. Defective laser scanner assembly.
5. Defective dc controller board.
HP LASER PRINTERS 1200, 2200, 3100 FAX, 3200 FAX, 4100
1. Temporary error. scanner rotation error.
2. Replace contact image sensor.
4. Replace laser scanner.
5. Replace cables to laser scanner and engine board
HP LASER PRINTERS 1100, 2100, 4000, 4050, 8000
1. Scanner start up error
2. Replace scanner cable to the D.C. controller and back to scanner. Or replace scanner cable from engine board to scanner ***'y.
3. Replace scanner ***'y.
4. Replace the engine board.
5. Replace the D.C. controller only on the 8000.
HP LASER PRINTER 2300 ERROR 52.X
1. A temporary scanner start up error.
2. This can also be the shutter tab on the print cartridge. Replace the toner cartridge.
3. Replace the scanner ***'y.
HP LASER PRINTERS 4200, 4300 ERROR 52.XX
1. Printer scanner speed error has occurred.
2. Replace laser scanner ***'y
3. Replace the D.C. controller ***'y
HP COLOR LASER PRINTER 4600, 5500 ERROR 52.XK, 52.XC, 52.XM, 52.XY
1. Error code K - No Black Color.
2. Error code C - No Cyan Color
3. Error code M - No Magenta color
4. Error code Y - No Yellow color
5. Replace laser scanner ***'y
6. Replace the D.C. controller ***'y
HP LASER PRINTERS 5000, 5100
4. Replace cable ***'y from scanner to D.C. controller.
HP LASER PRINTERS 8100, 8150
1.Laser scanner error/start up/rotation error
2.Replace laser scanner ***'y.
3.Replace D.C. controller board.
4.Replace cable ***'y from scanner to D.C. controller
HP LASER PRINTER 4500, 4550
1. Temporary error. Laser scanner error/start up/rotation error
2. Replace laser scanner.
3. Replace D.C. controller ***'y
HP COLOR LASER PRINTERS 4600, 5500
1.Laser scanner error/start up/rotation error.
2.Take the toners out and reseat them, or replace them
3. Replace laser scanner ***'y
4. Replace D.C controller board.
HP LASER PRINTER 8500, 8550
2. Replace laser scanner motor.
HP LASER PRINTER 9000
1. Temporary laser scanner error/start up/rotation error
3. Replace upper cable guide assembly.
4. Replace DC controller.
1) Go to control panel->printer and faxes.
2) Right Click on the paused printer
3) Select resume printing.
HP PHOTOSMARTD7160 Photosmart D7160 Q7046D Ink Jet Photo Printer Logo
8 questions posted
Ekse
efs_perpends
efs_perpends
View Most Popular
  • HP Office Equipment & Supplies
Most Popular Question
hp d7160 caridge won 39 t undock
  • Office Equipment & Supplies
