20 Most Recent
Cannon Canon FAXPHONE L170 - multifunction copier / fax / printer B/W - 50 sheets - 9400A010AA Questions & Answers
My cannon faxphone L170 has dark lines that come through whenever we receive a fax.
Are the faxes from the same person or different people?
(I have to ask, remember I don't know how much knowledge you have.) If yes, it could be on their end.
Does it do this with copies also? If yes, May be dust on the mirror or
something in the printer getting in the way of the laser.{slight possibility].
How many prints are on the printer? Could be a fuser issue.
My feeder does not work. It is a Cannon Imagerunner 330S. Serial plate XSC24741.Can this part be purchased?
The Cannon Imagerunner 330S has been discontinued for over 20 years, so it may be difficult to find a replacement feeder for it. I recommend contacting Canon's customer support to see if they have any parts or suggestions for repairing the feeder. You can also try checking with local repair shops to see if they have any compatible parts available. Contact information for Canon's customer support can be found on their website.
Cannon Oce 650 error code 16502/printer on start up. How to fix?
Check to make sure there isn't something blocking the paper output on the back of the computer. If not, open up the front door, about the top drawer, and close it. Go the back and open up the rear cover and close it. That may reset the problem. Remove ALL jobs from the queue and clear the set memory.
If that doesn't fix it, there may be a problem with the output sensor. These sensors may not be easily available on any website, so it's best to call you local Oce/Canon dealer for service.
