20 Most Recent Lenovo ThinkPad T41 Notebook Questions & Answers
Itu menunjukkan yang laptop kamu boot menerusi rangkaian.
Kamu harus tukar pilihan boot dalam "BIOS setup" dan pastikan Hardisk ditempatkan pada boot yang pertama. Selamat mencuba.
______________________________________________________
It looks like the laptop is trying to boot on network,
you need to enter the bios setup and make sure the hardisk is assigned as 1st boot. Good Luck.. :)
Lenovo ThinkPad... | Answered on Dec 24, 2013
Video card failure replace your video card
Lenovo ThinkPad... | Answered on Oct 18, 2011
There might be loose parts or connection inside the laptop. Is your laptop still under warranty. If it is still under warranty, i suggest that you have it repaired at our depot repair department. Opening the laptop on your own will void the warranty.
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Lenovo ThinkPad... | Answered on May 30, 2010
This is a common problem but there may be more than one fix
The easiest is to go to your bios and set the boot device order.
It is quite conceivable that it is set to try and boot from network first
You should select HARD DRIVE or CD DRIVE as you first option and then reverse that order for your second boot device
Lenovo ThinkPad... | Answered on Aug 20, 2009
dear friend this series is having this kind of many problems so i suggest please do any r n d on it please take it to service center cause there is problem with motherboard
Lenovo ThinkPad... | Answered on Jun 09, 2009
If you have XP SP2 or later.
You already have bluetooth.
http://support.microsoft.com/kb/883259#41
Hope this helps
Regards
Richard.
Lenovo ThinkPad... | Answered on Apr 22, 2009
THe heat issue would shut down your laptop or turn it off. This sounds like either a CPU problem or a motherboard. Most likely a motherboard problem.
Unfortunately, you need similar working parts to test physically.
Lenovo ThinkPad... | Answered on Mar 13, 2009
Yes you can download Whatsapp on your Laptop by follow simple steps.it is very easy to download it on your PC by using some emulator WhatsApp FOR PC WINDOWS AND MAC .Download Whatsapp from this link..
Also download fresh Android App on your PC Such as Asphalt 9 from this link.. Asphalt 9 FOR PC WINDOWS AND MAC
Lenovo ThinkPad... | Answered on Oct 05, 2020
remove the battery large.
then run on AC pack only
#1 top failure of all mobile PC is that battery, so unplug it
then test with AC pack only.
work now.? and all vents must be clean, end to end. not just fan.
there i no fuse it uses current regulator, imagine genius magic electronics fuses that never blow out, and bingo.
OK big battery out, an RTC coin cell fresh.
then fan blows.
next is BIOS, do the BIOS screens work if not the mobo is dead.
have 2 RAM stick on the 2 slots>? try one at a time
run the PC with all modules removed, (options)
remove hdd?
remove, dvd drive.
think like this. Get bios working first
learn that modules can short, and when they do the power regs shut down.
so we unplug all things to the mob,
until only 1 ram and cpu remains.
see? (this is called power overload fault isolation tactics)
even the screen only can be dead, you never mention text showing
you can test the mobo with external screen via that rear (?)_ VGA jack what if that worked, did you learn something here, sure.
this pc has tons of modules to pull, even bluetooth. wifi, sound and more. if you look at all parts inside or sold by ebay, bingo. lots
Lenovo ThinkPad... | Answered on Aug 14, 2018
It helps to know what device model and OS you are using though the following steps for changing from pattern lock to slide are for Android OS 4.0 (Ice Cream Sandwich):
1. Unlock your Android device
2. Find the Applications menu and select "Settings"
3. Under the "PERSONAL" group, select " Security"
4. Under "SCREEN SECURITY" group, select "Screen Lock"
This will ask for the security pattern first.
5. The options for screen lock will appear, select "Slide" and you are done!
Hope this helps.
Lenovo ThinkPad... | Answered on Mar 14, 2017
Lenovo ThinkPad T41 Notebook Logo
Popular Tags
13 questions posted
Top Lenovo Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
ThinkPad Lenovo
  • ThinkPad Lenovo
Most Popular Question
bluetooth dont
  • Computers & Internet
