20 Most Recent
Intermec CK31 Portable Terminal Questions & Answers
How to reset factory defaults to CK31?
Restoring Default Settings
You can restore the CK31 to factory default settings from
Intermec Settings.
Note: Using the Restore Defaults option restores all parameters
including network settings. When you choose to restore defaults,
you erase the registry. As a result, you may lose network
communications.
To restore factory default settings
1 From Intermec Settings, select Device Settings > Restore
Defaults.
2 Select Restore Defaults and choose the Run App button. A
Run Application dialog box appears asking if you want to run
the restore defaults program.
www.portablesolutions.com
THE HAND HELD DOESN'T TURN ON
This could be coused by a stocked key, bad battery connector, sofware corrupted etc. there is no fuse inside but I can help you repair this properly
You can always contact me directly [email protected] or 630-622-2024 toll free 866-271-9891 Ask for Andrew
Unit will not boot. Screen reads
"Check serial Input" is just part of the cycle on boot up. It checks for a key press on boot up so that it can access a hidden menu. A cradle, serial null modem cable and hyper-terminal is required to bring up this menu
You can try and re-install the operating system.
Download the latest image from Intermec (you will need to register) and then load the image onto an SD card.
Remove the front cover just above the scan engine; 2 slot head screws and insert the SD card. Cold boot the device. Take off battery and hit the reset button a few times. Re-install battery.
Image will begin to reload.
Detailed instructions are available with the download.
NOTE: The latest image downloads from Intermec not longer have the Telnet application pre-installed. If you require the telnet client then select a previous version, but then also not that there are usually 2 versions EX25 and non-EX25 scan engine type.
If you need any more help then please do not hesitate to contact us:-
[email protected] or TEL 01202 620955
http://www.biastechnology.com/
Ck31
Here at Legacy Global we can help you. Call Diana at 1-847-750-9231.
How we can get MAC and IP address on Intermec CK30 units?
hi
o obtain the MAC address on a CK3X, CK3R,and 70 Series Handheld computer, follow the steps below:
- Tap the 'Windows' button on the lower left hand corner.
- Scroll towards the bottom of the Windows screen to the "ISpyWiFi" application and tap to launch it.
- ISpyWiFi will open up in the ISpy tab.
- At the top of the screen, look for the 'WiFI NIC' quadrant which displays the MAC address.
11/23/2021 3:57:20 PM •
Intermec...
Answered
on Nov 23, 2021
How do you fix a 910 code on intermec cn70 hand held
hi
The newest versions of the firmware are on the intermec website. You will have to register in order to download, but a fake name/address will work...if it is a 740/750 the newest firmware is 4.51 PSM 3.93.1, and if it is a 741/751 the newest firmware is 4.95.1 PSM 4.06. the 760 and 761 have different versions of firmware depending if it is GPRS or CDMA.
11/23/2021 3:54:26 PM •
Intermec...
Answered
on Nov 23, 2021
