20 Most Recent Konica Minolta Bizhub C451/c550/c650 Toner Magenta A070330 Questions & Answers
Color registration is off check the sensor under the transfer belt and mite want to have e tech run color registration procedure. black is the reference for the color registration having developer problems with black drum does not help
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Konica Minolta... | Answered on Jan 10, 2016
requires remove of the transfer belt and cleaning of the registration sensors located under the belt on the right side of the machine, with belt out requires knowing what lever to push to expose the sensor to clean them or the have them replaced.
Konica Minolta... | Answered on May 25, 2015
Level Adjustment error. Has the drum and the developer unit and developer been replaced? Has the drum unit/assy. been cleaned including the sensor!!!!!!!!!
Konica Minolta... | Answered on May 04, 2020
alignment in regards to what
Konica Minolta... | Answered on Apr 04, 2020
Did you replace them????? The machine uses the counter to determine certain voltage assignment to those parts so if you say you reset the drum counter to Zero then machine will assume it has a new drum and assign the required voltage for a new drum since its not a new drum because all you did is reset the counter with out replacing it ,you get bad copy issues codes and issues.
Konica Minolta... | Answered on Apr 03, 2020
Was the main board replaced? The NVRAM chip was not properly replaced still mite be on the original board . Was the firmware properly installed
Sir,
Power off the machine. Then remove the toner bottle, be careful the hole might be on the bottom and the toner is going to go everywhere. Then close the toner cover and turn on the machine. Let the machine go through it normal routine. When it asks for toner install the toner bottle correctly. If that does not work, you might have a bad motor or the home sensor or actuator for the toner bottle is bad worse case the control board is bad.
Does it say image unit or drum????????
Konica Minolta... | Answered on Mar 22, 2020
Replace the cyan image unit. Did buy a third party???
Konica Minolta... | Answered on Feb 17, 2020
Did you replace the main board??if so the a Chip is missing which is required on the board, have the old board if so remove from old place on new board.
Konica Minolta... | Answered on Feb 16, 2020
did you mean 3451???
Konica Minolta... | Answered on Jan 28, 2020
A4 paper equals 8 1/2 x 11 paper wrong paper setting
Konica Minolta... | Answered on Dec 24, 2019
Code C3101
Description : Fusing Pressure Roller pressure/retraction failure.
No change is observed in the encoder sensor pulse even after the lapse of 0.5 sec. after the Fusing Pressure/Retraction Motor has started turning for a sequence of the Fusing Pressure Roller's retracting motion.
- No change is observed in the encoder sensor pulse even after the lapse of 0.5 sec. after the Fusing Pressure/Retraction Motor has started turning for a sequence of the Fusing Pressure Roller's pressing motion.
- The Fusing Pressure Position Sensor is not activated (pressed position) even when 30 encoder sensor pulses are counted after the Fusing Pressure/Retraction Motor has started turning for a sequence of the Fusing Pressure Roller's pressing motion.
Remedy :
https://www.manualslib.com/manual/828946/Konica-Minolta-Bizhub-C450.html?page=393&term=c3101&selected=3
Konica Minolta... | Answered on Nov 10, 2019
Konica Minolta Bizhub C451/c550/c650 Toner Magenta A070330 Logo
2 questions posted
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
bizhub Konica Minolta
  • bizhub Konica Minolta
Most Popular Question
iam getting p21 c650 developer
  • Office Equipment & Supplies
