20 Most Recent
Epson Stylus Sx445w Inkjet Print Scan 5760 X 1400 Dpi Print 33 P Questions & Answers
I installed a new printer: Epson Stylus SX445W.
Any number of possible reasons why the drivers didn't install properly but that's basically what seems to have happened.Try uninstalling the driver, downloading the latest version (for your operating system) from the Epson Support section of their website and then reinstalling.Remember to have the printer turned off and the usb cable disconnected until prompted to do so.Might also be worth disconnecting from the internet (for safety) and disabling any of your anti-virus or other software while you install the drivers as they can sometimes cause problems.Obviously once you're done, re-enable anything you disabled and reconnect to the internet as normal.With a little luck that should cure the problem.
Why am I getting double or treble spacing on the printed lines
It could be that the disk located to the left side of the paper feed (when looking inside from front) is soiled with ink.
The disk has tiny lines on it that are read by a sensor like steps so the printer counts the "steps" to work out how far the paper has progressed through the feed. If this is dirty with ink, grease or similar, it will not be read properly and result in the paper feeding further than it should.
This assumes that the issue is printer related however. It could be that your source document/editor is causing the problem by not displaying what you want to print. You can identify if this is the case by printing from some other application like a web browser or similar to see if the spacing still takes place. If it does the printer is the fault... if it doesn't it's your software.
Hope that helps.
Epson user guide
You might have disconected your printer without shutting it off nor asked your computer to disconec the printer. You might have damaged your usb connection. Taking the precaution measures try another usb connection
Epson troubleshooting
What you have I highly suspect is a highly clogged print head. Even if you continue to clean your print head you will use ink to do it, so you will be spending a lot of ink and trust me it wont fix the problem. I have two epsons 1400 and had the same problem and used cleaning solutions but at the end it helped but did not fix the problem.
So at the I decided to use a cleaning solution that comes in cartridges specific for your printer. Its name is UNBLOCK UNCLOG CARTRIDGES, Its seller in E-bay is Sy1507. It worked. but for example it took me around three days. I printed a job and let it sit for a couple of hours until the page printed all white. After the page prints all white then you change the cartridges with ink and do a test print and if prints right, do a print job, You will be amazed at the results. Good Luck.
Epson Stylus SX445W printing pictures with a red tint
Dear Kate,
please run the Epson maintenance software and check your printer cartridge.
i think printer head cleaning is the solution.
please run 1 or 2 cleaning cycles and give a try again.
if problem still there its time to go to technician.
regards,
nuwan.
Epson lq-690II printer reflects the paper when printing
Troubleshooting Paper Reversal in Printers:
*Confirm that options related to paper handling are set correctly by checking for specific buttons or switches that relate to paper handling or reversing.
*Ensure that paper is loaded properly to avoid feeding problems.
*Remove any dust, particles, or paper remnants from the rollers, as they can impede paper flow.
*If other measures fail, reset the printer to its initial settings to resolve potential software glitches.
EPSON 15140 error 034019
Try a hard reset of the printer. Oddly, the 034019 is not an error code, I have reason to think. It is a contact number, I believe.
Reset my Epson printer L382
Follow the steps given below to reset Epson L382 printer.
Step 1: Turn the printer off.
Step 2: Press and hold the reset button which is on the back of the printer using a paper clip or tip of a pen.
Step 3: Turn on the printer by holding the Power & reset button and continue to hold both the buttons.
Step 4: Wait for 5 seconds and a warning sheet will print. Release the reset button.
Step 5: After 5 seconds, another sheet will print which will show the IP address of the printer.
WHERE IS RESET BUTON? I CANT FIND IT.
