20 Most Recent Lenovo 3000 V100 Notebook Questions & Answers
Depending on your Operating system and weather you are using the Lenovo software, you can usually click on the battery symbol on the bottom right of the taskbar to see the percentage, what time is left to charge etc.
If there is no symbol that looks like a battery it should be in a box that pops up when you click the arrow symbol on the bottom right. Hope this helps.
Leo
Lenovo 3000 V100... | Answered on Nov 21, 2013
hmmm there might be a preloaded software like 'QUICKPLAY'
Run this software, and click on Music/CD/Cam icon.
Then double click on your cam name wich will be display in a list after double clicking on the Music/CD/Cam icon.
This will open your cam, and you can take your Photo and Videos..
Thanks
Iqbal
Lenovo 3000 V100... | Answered on Oct 05, 2012
It seems that your laptop is holding webcam loading problems. Check whether the webcam driver is compatible for the OS which you use.
You can also try re-installing the webcam driver once again. This should do.
I hope this helps., if so, rate me..
Thanks - billa
how to downlod
Lenovo 3000 V100 PC Notebook camera
Lenovo 3000 V100... | Answered on Sep 14, 2012
Go to this website consumersupport.lenovo.com.
1. Choose United States.
2. Enter the serial number of the laptop.
3. Choose the Operating System under the webcam driver.
Hope this help. Thank you for using FixYa!
Lenovo 3000 V100... | Answered on Jul 25, 2011
Welcome to fixya
You can try this step
press FN+F6
Hope this helps
Lenovo 3000 V100... | Answered on Jul 15, 2011
Hi
you could try downloading the driver for it from here this may install it correctly and give you the icon for it ( Maybe )
http://www-307.ibm.com/pc/support/site.wss/migr-63656.html
Lenovo 3000 V100... | Answered on Jul 07, 2011
Here is the link from where you can download both the Foxconn bluetooth driver plus enhanced data rate for bluetooth.
http://www-307.ibm.com/pc/support/site.wss/MIGR-64290.html
That's it.
Lenovo 3000 V100... | Answered on May 29, 2011
You can download all drivers for your notebook here
Lenovo 3000 V100... | Answered on May 02, 2011
hi,
you can download the latest driver on the lenovo website: consumersupport.lenovo.com just select the family and the model of your machine on the drop down menu. And select the driver for your operating system
Thanks for using Fixya
Lenovo 3000 V100... | Answered on Jan 25, 2011
check if the fan is working!!. If its dirty clean it with a painting brush & vacuum cleaner
Lenovo 3000 V100... | Answered on Jan 01, 2011
aside from manual of this pc, you may check the base system device by right clicking the Computer and click Properties. In this you mat check the other stats of your device.
Lenovo 3000 V100... | Answered on Dec 12, 2010
Welcome to Fixya
Inorder to use your webcam for chatting, you should need a chatting/messaging software like Yahoo messenger or Skype. Download and install the Yahoo messenger and Skype to you computer and create an account to their website so that you were able to login to their chat program. The other individual should be using the same program also so that you can communicate with each other.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Lenovo 3000 V100... | Answered on Nov 30, 2010
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether
Lenovo 3000 V100... | Answered on Oct 07, 2010
windows 7 should be automatic at doing a lot of stuff including installing your camera automatically. Try updating your version of windows 7. I'm pretty sure that it will require a lot of updating because of your fresh install. Just go to control panel and then update manager. see if that helps
Lenovo 3000 V100... | Answered on Sep 28, 2010
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-64290
Those are the drivers, even the bluetooh.
Lenovo 3000 V100... | Answered on Sep 23, 2010
go to device manager,then network adapters,then double click on the wireless card icon , then you should see on top wireless on and off little tap select on then restart your pc. you should be good to go
Lenovo 3000 V100... | Answered on Aug 31, 2010
Lenovo 3000 V100 Notebook Logo
95 questions posted
Top Lenovo Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
Ekse
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
3000 Lenovo
  • 3000 Lenovo
Most Popular Question
lenovo 3000 v100 pc notebook
  • Computers & Internet
