20 Most Recent Lenovo ThinkPad X60 Notebook Questions & Answers
Try to go into safe mode by pressing F8 as soon as you turn on the laptop.
If you get into safe mode then go into system restore and choose a date when the laptop was working properly. Let it rollback to that date and reboot the computer and let it go and see if it goes back into windows.
If you get a blue screen even when trying to go into windows then the operating system is corrupted and you'll need to do a factory restore on the laptop, meaning the hard drive would have to be wiped out and the operating system put back onto the hard drive.
Lenovo ThinkPad... | Answered on Dec 01, 2018
Please explain further what your issue is.
Lenovo ThinkPad... | Answered on May 13, 2016
Ok, it could be a few things. The power setting could be wrong or the laptop lid switch is faulty. I would change the power settings to always on and recheck the issue. Also, when the video is on move the lid until the video goes out. You should almost get to the close position before it goes off. Also tap or burp the back of the LCD display. Sometimes a bad display ribbon causes this too.
Lenovo ThinkPad... | Answered on Dec 27, 2012
This site tells you how to do it. http://www.insidemylaptop.com/replace-broken-lcd-screen-lenovo-x60s-laptop/
And this site sells the screens.
http://www.amazon.com/gp/product/B003TPZ7WY?ie=UTF8&tag=pct07-20&linkCode=as2&camp=1789&creative=390957&creativeASIN=B003TPZ7WY
Screen replacement is delicate and time consuming. As a service tech, I would expect the cost to replace to be around $100.
Lenovo ThinkPad... | Answered on Aug 04, 2010
To get the screen to display on your external monitor instead of on the lap top?
Press the Blue FN button with F6
or maybe it's Blue FN button with F7 until your monitor shows the image.
I've had the most success by pressing this key combination once and waiting 3-5 seconds to see if the display changes.
Press again until the desired display comes up.
Good luck !
Lenovo ThinkPad... | Answered on Feb 08, 2010
I suggest to check the power options in the Control Panel and try to change the settings. This would resolve the issue.
Lenovo ThinkPad... | Answered on Apr 06, 2009
you got a desktop hacker installed on your pc.
http://www.superantispyware.com/superantispyware.html?rid=3007
download the spyware and run a scan. it should solve the problem
Lenovo ThinkPad... | Answered on Mar 30, 2009
Yes you can download Whatsapp on your Laptop by follow simple steps.it is very easy to download it on your PC by using some emulator WhatsApp FOR PC WINDOWS AND MAC .Download Whatsapp from this link..
Also download fresh Android App on your PC Such as Asphalt 9 from this link.. Asphalt 9 FOR PC WINDOWS AND MAC
Lenovo ThinkPad... | Answered on Jul 31, 2020
Error code 36 means a ley is stuck. Only you can find out which one. Press each key in turn to feel if there is a dodgy key.
Lenovo ThinkPad... | Answered on Oct 09, 2019
remove the battery large.
then run on AC pack only
#1 top failure of all mobile PC is that battery, so unplug it
then test with AC pack only.
work now.? and all vents must be clean, end to end. not just fan.
there i no fuse it uses current regulator, imagine genius magic electronics fuses that never blow out, and bingo.
OK big battery out, an RTC coin cell fresh.
then fan blows.
next is BIOS, do the BIOS screens work if not the mobo is dead.
have 2 RAM stick on the 2 slots>? try one at a time
run the PC with all modules removed, (options)
remove hdd?
remove, dvd drive.
think like this. Get bios working first
learn that modules can short, and when they do the power regs shut down.
so we unplug all things to the mob,
until only 1 ram and cpu remains.
see? (this is called power overload fault isolation tactics)
even the screen only can be dead, you never mention text showing
you can test the mobo with external screen via that rear (?)_ VGA jack what if that worked, did you learn something here, sure.
this pc has tons of modules to pull, even bluetooth. wifi, sound and more. if you look at all parts inside or sold by ebay, bingo. lots
Lenovo ThinkPad... | Answered on Aug 14, 2018
It helps to know what device model and OS you are using though the following steps for changing from pattern lock to slide are for Android OS 4.0 (Ice Cream Sandwich):
1. Unlock your Android device
2. Find the Applications menu and select "Settings"
3. Under the "PERSONAL" group, select " Security"
4. Under "SCREEN SECURITY" group, select "Screen Lock"
This will ask for the security pattern first.
5. The options for screen lock will appear, select "Slide" and you are done!
Hope this helps.
Lenovo ThinkPad... | Answered on Mar 14, 2017
Press Ctrl and PrntScr together. That will grab the screen then open your document programme, (Open Office, Word or whatever you use to compile letters etc) press Ctrl and V.
Lenovo ThinkPad... | Answered on May 23, 2016
Lenovo ThinkPad X60 Notebook Logo
8 questions posted
Top Lenovo Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
Toby Lee
Toby Lee
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
ThinkPad Lenovo
  • ThinkPad Lenovo
Most Popular Question
lenovo x60 laptop blue screen
  • Computers & Internet
