20 Most Recent Samsung PS42E7HD 42 in. HD-Ready Plasma Television Questions & Answers
good luck
Samsung PS42E7HD... | Answered on Jul 17, 2012
have you tried calling your sky+hd provider for code updates for there remote
Samsung PS42E7HD... | Answered on Nov 01, 2009
please follow the steps below:
TV
RED + SELECT (flashes twice)
TV
0060
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
Samsung PS42E7HD... | Answered on Sep 17, 2009
Could be a failing power supply
Samsung... | Answered 2 hours ago
Disconnect from the power for 1 hour. Go to settings - Picture - scroll down to Reset to Factory Defaults.
If that doesn't fix it, look for bad capacitors, or give it to a technician.
Samsung... | Answered on Jan 18, 2021
Make sure that all remotes are using same technology. Most remotes use infrared but many modern remotes are bluetooth and they cannot be programmed in infrared remote.
Check the capacitors well. You could also check other components. This could be caused by a partially faulty component that is failing after some time. Read more on this at https://www.electronicsqa.com
Samsung... | Answered on Jan 16, 2021
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ .
https://elektrotricks.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site by type in the brand name of your TV, at its search box at the right column...
Samsung... | Answered on Jan 14, 2021
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
https://homenol.blogspot.com/
Blinking codes details to many popular brand TVs are given. If blinks continue without any pause, the main board is faulty. Search the sites by type in the brand name to your set, in its search box on the right side.
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
Samsung PS42E7HD 42 in. HD-Ready Plasma Television Logo
Popular Tags
9 questions posted
Muntejaya Ginting
Muntejaya Ginting
Demonic-2011
Demonic-2011
View Most Popular
  • Samsung Televison & Video
Most Popular Question
factory reset
  • Televison & Video
